Question about ASUS P5LD2-VM Motherboard
Asus p5ld2-wm and coroe
I just got a new system, there was suppose to kick A.. But after mounting everything... I got nothing..... The system powered up. hd spinnd up.. light in board LED...black screen. (NO bips) System is comprised of asus p5ld2-wm (onboard graphics) intel core 2 duo cpu (conroe) 1 gig kingston kvr667d2n5/1g ram... Im not sure if one of these components are busted, or if it might be a problem with the bios. Thanks....
  • 1 more comment
  • Andreas Olsen Oct 20, 2006
    The problem was rooted in two things.
    First of all the bios vertion, and also the board rev.
    Conclsusion: There was no solution other then to return the board, and get a new rev. of it.
  • Anonymous Dec 14, 2007
    installed the motherboard and powered up. Everything appeared to work except the video. Tested the PCI-E card and it was ok. Doesn't appear to be any signals to the PCI-E card.
  • Bretton24 Dec 27, 2007
    I have the exact same problem. I had a system that worked fine and then
    I installed a Intel Core 2 Duo Conroe and everything turns on but there
    is no video. I figured the best way to troubleshoot it would be to just
    unplug everything and start from scratch. So all I had plugged in was 1
    stick of RAM that I know to be good, the processor, and the power to
    the board; still nothing. I then tried 3 different video cards still
    nothing. I then went back to my old setup with my old processor and
    when I turned it on viola it worked fine.
The answer to the problem is that the Dual core compatible motherboard is only dual core compatible with revisions 2.0G and above. This information is stated on the page describing the board and I only found this out through tech support. I am currently filing a complaint and seeing what I can get done.
Posted on Dec 28, 2007
    Scholar:
  • 116 Answers
Hello akolsen, The first thing you want to do it to reset the CMOS. 1. Turn off the computer and unplug the power cord. 2. Remove the onboard battery. 3. Move the jumper cap from pins 1-2 (default) to 2-3. Keep the cap on pins 2-3 for about 5 to 10 seconds, and then move the cap back to pins 1-2. 4. Re-install the battery. 5. Plug the power cord in and turn on the computer. 6. Hold the DELETE key down during the boot process to bring you into the BIOS setup. If you are not getting any video after this, try unplugging your hard drive. If you still are not getting any video, it could be your RAM. If you have more than 1 stick, pull the ram out and try them one at a time. If you only have 1 stick, try a different slot. And, very important, if you are using two sticks, make sure you are in the yellow slots or the black slots, NOT side by side. Please let us know how this works for you, and if you have any additional concerns. Best regards, nightdiver
Posted on Aug 22, 2006
  • 29 Answers
Sounds like a RAM or power supply problem to me, check the ram... even if it is brand new
Posted on Aug 21, 2006
I need all drivers for ASUS P5LD2 SE. Support cd motherboard.
Here is the link for Asus P5LD2 SE. Just click the download button below, select your operating system and all the drivers for Asus P5LD2 SE are there ready to download. Have a nice day.
Apr 15, 2011 | ASUS P5LD2 Motherboard
I have Asus P5ld2-vm motherboard, when i install vga driver screen resolution come only 600 x 450 4 colour
Have you changed the bit settings? Suppose if it's 16 bit, change it to 32 bit and see the affect. Updating the driver to the latest version will also solve your problem, if there's no mistakes with the internal settings. If you still have problem, do let me know.. Good luck.
May 19, 2010 | ASUS P5LD2-VM Motherboard
P5ld2-vm/s mother board lan drivers
i have a LAN Driver of model no. p5ld2-vm/s is the branded computer of HCL, that motherboard name is ASUS
Mar 23, 2010 | ASUS P5LD2-VM Motherboard
I need to find aan asus p5ld2 support cd
Visit this site:
Hope this helps!!!
Dec 23, 2009 | ASUS P5LD2 Motherboard
My cpu dont see new hdd wd5000avvs ,motherboard Asus P5LD2 SE. i trying omost everything. help;/
are you using ide or sata connection? if your using sata conection between your motherboard and harddrive, you must enable it in your bios, just reboot your pc and keep pressing F2 while its booting to prompt your bios. There you can look for IDE/SATA configuration. After enabling your sata, save any changes before you exit and reboot... Just give it a try...
Jun 22, 2009 | ASUS P5LD2-VM Motherboard
Asus p5ld2-v motherboard
Har ikke sett manual ennå/ trenger også bedre bilde av
Aug 15, 2008 | ASUS P5LD2 Deluxe Motherboard
MOTHER BOARD DRIVERS
All drivers are available here but chose your OS & download
http://support.asus.com/download/download.aspx?modelname=P5LD2%20Deluxe&SLanguage=en-us............sodeep
Jul 01, 2008 | ASUS P5LD2 Deluxe Motherboard
Sound problem with asus p5ld2-vm series motherboard
Vista 64bit drivers: http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5LD2-VM/RealtekALC888_Audio_V6015384_Vista.zip
XP 64 bit drivers: http://dlsvr01.asus.com/pub/ASUS/misc/audio/RealtekALC888_Audio_V51005294.zip
Dec 14, 2007 | Intel D865GBF Motherboard
Pc restart problem
Yes, your mobo Asus P5LD2-VM support CPUs with Conroe-core ("Core 2 Duo"). http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5LD2-VM But for new CPUs strongly recommended use last BIOS version - 1401 from 2007/08/14. http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5LD2-VM/P5LD2-VM-1401.rar
Oct 03, 2007 | ASUS P5LD2-VM Motherboard
ASUS P5LD2-VM Motherboard Logo
529 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
