Question about Kenmore 700 6972 Dryer
My Kenmore 70 Series Model # 110.74732400 Gas Dryer will attempt to heat (I can see the carbon element glow, fade, and repeat) but will not ignite the gas....what part should I replace?
4 Suggested Answers
  • 103 Answers
SOURCE: heating element or coils not glowing and getting
Bad Thermal High limt,
Bad Thermistor,
Bad heat element.
Need model number, located on inside of door, usually.
Posted on Oct 01, 2009
erpaalai
  • 999 Answers
SOURCE: I have a kenmore 70 series gas dryer. It won't
Check the thermal fuse and thermostats first, then the ignitor and the valve coils are the next possibilities.
Eric
Posted on Jan 24, 2010
  • 3074 Answers
SOURCE: My 70 series dryer the heating element is not
your voltage is not right as it should be 220 volts, check the outlet to see if you have 220 if you do then its the cord, if not then it is either the outlet or the breaker-panel, to check panel remove panel and test both legs of the breaker you should have 220 if not then replace the 30 amp breaker. Tim
http://www.ehow.com/how_7403710_replace-kenmore-70-series-dryer.html
Posted on May 27, 2011
Kenmore series 500 gas dryer not heating up. model # 77542600 Other than the ignitor what could be the problem?
Check the coils on gas valve. If igniter glows bright & no CLICK sound heard after a few seconds of igniter glowing, coils are bad, or flame sensor if so equiped
Feb 13, 2011 | Kenmore 500 6952 Dryer
I have a kenmore heavy duty 70 series gas. not heating up. were is the heating element. could you send a technical manual.
Your dryer does not have a element. The problem is either with the igniter, or the gas valve coils. I would replace both of them. I think they would run about $35.00 for both. Here is a link to the parts.
http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/Dryer-Igniters-and-Gas-Valve-Coils/index.aspx
Nov 22, 2010 | Dryers
My kenmore dryer series 70 is not heating, i replaced igniter, thermo sensor, and still does not heat....there is no glow from inside please help....
Check the fuse Note: Gas dryer thermofuse is linked to the gas assembly and blows whenever the temp exceeds 350f rapidly. Remove all air restrictions15f9d55.jpgbefore replacing that fuse or you will just need to keep buying em.f8e11bb.jpg65c991e.jpg
May 08, 2010 | Kenmore 62602 Electric Dryer
Kenmore 70 series gas dryer does not ignite I chenge the coil still not heating
Check for burnt out glow ignitor. If okay then check thermal fuse and all other thermostats with ohm meter..... all must be in closed position.
Mar 21, 2010 | Kenmore 73952 Gas Dryer
Kenmore series 80 dryer, ryns with no heat. i
that is ur glow bar or igniotror that is common,, check ur ignitor, thermal fuse, or secondary gas coils, those are what are usually wrong with no heat on gas dryers
Feb 03, 2010 | Kenmore 62802 Electric Dryer
Gas dryer heat is intermediate
does the igniter glow white or orange? if it is orange you need to replace it. has to be white hot to ignite. if the igniter is white it could be the coils not opening the gas valve all the time - an intermittent problem.
Oct 04, 2009 | Kenmore 73952 Gas Dryer
Heating element or coils not glowing and getting no heat model is a kenmore 70 series and is electric
Bad Thermistor,
Bad heat element.
Oct 01, 2009 | Kenmore 62882 Electric Dryer
Kenmore dryer not heating
Check the following-- Gas valve coils Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Jun 05, 2009 | Kenmore Dryers
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
Kenmore series 70 gas dryer no heat, where is the glow plug located and how do I get to it?
its a heating element and its in the back of the dryer...it could also be the limit switches that are bad they are at each end of the heating element. you have to take it out of the dryer and replace it
Jan 29, 2009 | Dryers
Kenmore 700 6972 Dryer Logo
48 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
