HP compaq nc6400 does not turn on charging light just flashes orange
Charging light flashes orange after left charging and flashes for several hours after
SLitWrists
  • 35 Answers
SOURCE: Hp compaq nc6400 shut down
Hi there Sounds like its youre laptop Power Supply Or the Battery It Self
Kind Regards
SlitWrists
Posted on Apr 24, 2009
philmik
  • 107 Answers
SOURCE: where can i download recovery CD for hp compaq
Some info on recovery. Sometimes they make hidden Recovery HDD partition. If you won't be able to recover get new OS a put a fresh copy it's always a better way for your PC. If you need to save some files from previous installation you can use some of the Linux live CD's. My favorites are Knoppix, Ubuntu, Mandriva One.
Posted on Apr 26, 2009
parrotheadpc
  • 2600 Answers
SOURCE: my hp compaq nc6400 doesn't turn on. the green
Laptop is dead. How to troubleshoot the problem.
In this post I’ll explain how to troubleshoot a dead laptop and find the problem. The following troubleshooting tips are not model and brand specific, they should work for most laptops.
Let’s take a look at two different scenarios.
Example 1. The laptop is absolutely dead.
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead.
What you can do in this case?
1. Make sure the wall outlet is working and the laptop DC adapter is getting power from the outlet. Try another wall outlet.
2. Test the laptop DC power adapter, make sure the voltage output is correct. You can test the DC power adapter with a voltmeter.
3. Let’s say the DC adapter is fine and the adapter outputs correct voltage. In this case unplug the power adapter from the laptop, remove the battery, wait for 1-2 minutes, plug in the adapter and try turning on the laptop again.
OK, you tested the adapter and it’s bad. If you decide to replace the original DC adapter with a generic one, you’ll have to follow this rule:
The voltage output on your new adapter has to be exactly the same as on the original adapter. The amperage on the new adapter could be the same or higher.
If nothing helps and the laptop is still dead, apparently the motherboard is fried or there is a problem with the DC power jack. It’s possible the DC power jack is broken and the motherboard is not getting any power from the adapter. In this case you’ll have to disassemble the laptop and replace the power jack.
Example 2. When you plug the DC power adapter and press on the power button, the laptop starts making normal noises, the LEDs work properly but noting appears on the screen. The laptop will not start.
First of all, take a closer look at the LCD screen. Look at the screen under bright light. It’s possible that the image is still on the screen but it’s very faint.
If there is no image on the laptop LCD screen, test the laptop with an external monitor. Connect an external monitor to the VGA port on your laptop and turn the laptop on. You can toggle video output between the internal LCD screen and external monitor by pressing Fn and F4 keys simultaneously on HP laptops, Fn and F5 keys on Toshiba laptops, Fn and F7 keys on IBM laptops. Other laptops may use different key combinations.
Let’s say the external monitor works fine but the internal LCD screen has no image at all. If that’s the case, your problem could be related to the LCD screen or the video cable. Also, make sure the video cable makes good connection with the motherboard and the LCD screen. Try reconnecting, reseating the cable.
In my case, both internal and external monitors were absolutely dead. Neither of them had image. That means the problem is not related to the LCD screen or the video cable. From my experience I know that this problem could be related to the laptop memory.
Try reseating the memory module, maybe it’s not making good connection with the memory slot. Try cleaning contacts on the memory module with pen eraser. Try moving the memory module into another slot. Try replacing the memory module with another known good module, it’s possible that your original module is dead.
If you have two memory modules installed you can try removing them one by one, it’s possible that one of the modules is bad. Try installing different memory modules into different memory slots.
In my case reseating, swapping the memory module didn’t help. I was pretty confident that my problem is not memory related and I moved on.
Try removing battery, hard drive and DVD drive and turning on the laptop without these components.
Also, try turning on the laptop with an external monitor when the video cable is unplugged from the motherboard. If the laptop start with video on the external monitor, apparently there is something wrong with the laptop display panel.
Finally, disassemble the laptop and removed the motherboard.
1. Motherboard. Like on most laptops, in my case the video card is integrated into the motherboard
2. CPU with heatsink and cooling fan.
3. Known good memory module.
4. The power button board witch you need to turn on the system.
5. Working DC power adapter.
Still cannot get any video on the external monitor. The system turns on, the cooling fan starts spinning but there is no video.
At this point I’m 95% sure that the motherboard is dead. CPU failures are not very common, so it must be bad motherboard.
Posted on Oct 12, 2009
walesarumi
  • 6993 Answers
SOURCE: HP Compaq 6735s battery light orange blinking
Have you tried another power cord? If you try another power cord, and it still does the same thing, then I think your laptop is having a power problem. You need to take is to a technician to fix the problem for you.
Best wishes.
Posted on Dec 03, 2009
Testimonial: "awesome, thanks, i'll try that :)"
  • 553 Answers
SOURCE: Battery on HP nc6400 does not charge - new battery
If the computer will run when plugged in then the battery may charge while the computer is running. You might try cleaning the contacts in the computer with a white plasting eraser, other erasers could damage the contacts or leave residue behind causing more trouble.
If the compuer will not run while plugged in you either have a bad power supply or a damaged charging system in the computer.
If the computer runs and charges while running then you have a damaged charging system, depending on the age of the system it may not be worth repairing just charge the battery with the computer running.
Posted on Mar 24, 2010
I wan to reset jumper on hp compaq nc6400 laptop
refer to manufacturers site for correct positioning.
Jun 20, 2012 | HP Compaq nc6400 Notebook
When i play video in my hp Compaq nc6400 laptop, the picture stuck and play. also it late to display when i turn it on.
open task manager by pressing ctrl+alt+del at same time.
check performance tab
if indicate CPU usage above 50% constant mean some background application is working, could utility or virus.
scan with good and light antivirus.
Mar 08, 2011 | HP Compaq nc6400 Notebook
HP Compaq nc6400 won't keep any BIOS settings
HP Compaq nc6400,,is the bios pin on correct jumpers?
https://support.hp.com/rs-en/document/c00363478
Dec 30, 2017 | HP Compaq nc6400 Notebook
Orange light comes on then off, battery not
1. Try to charge your battery for atleast 6 Hours.
2. Check your battery, whether it's in good condition!
3. If not replace it with the compatible one!
Jan 02, 2010 | HP Compaq Presario 2200 Notebook
I have a HP550 laptop and it has just shut down and won't restart, and I have a flashing orange light where the power adapter connects, any ideas?
That usally means you are charging the battery or your trying to charge a bad battery. Remove the battery and leave it unplugged for an hour. After that leave the battery out and plug it up try and boot it.
Dec 28, 2009 | HP Compaq nc6000 Notebook
Nc6400 - charging light stays on solid and battery does not charge - battery and charger are good
use a clean pencil eraser to clean up the contacts, then try charging again. also be sure the outlet u r plugging into is live.
Jul 11, 2009 | HP Compaq NC6400 Business Notebook
Battery shows charge, works on other computers but not my hp
you got a bad connection in the battery compartment on the lap top try taking a Q-tip and cleaning all the contacts in the battery compartment. hope it helps.
May 12, 2009 | HP Compaq NC6400 Business Notebook
Compaq NC6400 Turns on but will not display anything on screen.
hi thanks for using fixya!
I recommend that you bring your laptop to a service center to further check the hard ware of your laptop.
Best Regards!
Apr 12, 2009 | HP Compaq nc6400 Notebook
Computers & Internet Logo
208 people viewed this question
David Payne
David Payne
