Question about HP Computers & Internet
How to resolve that chassis fan is not detected
When I start my pc a beep sound appear and it shows that chassis fan 512 is not detected
    New Friend:
  • 84 Answers
HI
CHECK YOU FAN IS REALY CONNECTED OR NOT
IF SHE DOEn't WORD REPLACE YOUR FAN
Posted on Feb 18, 2012
What makes 511-cpu fan not detected and 512-chassis not detected
Are you seeing this error on a system you built or a pre-built system? If it is a pre-built system, check that the fans are running. Next check where the fans are plugged in, the CPU fan must be connected to the CPU fan connector on your motherboard. The chassis (rear case fan) only needs to be connected to the motherboard if you want the monitoring/PWM (modulated fan speed) option. If your CPU fan is powered directly from the power supply, change this.
If this is a system you built or recently updated the case, check your fan power connections, as above. Next check the fan speed. My ASUS board will give the "CPU fan not detected" error if the CPU fan speed is too slow. A different CPU fan will solve the problem. (I got my fan with the CPU; it works fine.)
I hope this helps. Please add a comment with more information about your system for more assistance.
May 12, 2013 | Computers & Internet
512-chassis fan not detected
The fan may be disconnected or it may be faulty.
Remove the computer cover. check the fan connections and then power up the computer to see if the fan operates. You may have to wait awhile if the fan is controlled by a temperature sensor.
May 30, 2011 | HP Compaq Evo D510 PC Desktop
WHEN BOARD BOOTS ERROR 512 - CHASIS FAN NOT DETECTED APPEAR LET ME KNOW HOW TO DISABLE THIS ERROR it does it every time i start, or restart the computer, and i have to hit F1 to get it to boot, what...
hi this is a setting in the bios/ cmos you have to press either del or f2 to enter the menu, when in the menu look for a setting that will disable the chassis fan speed do this when booting up...hope this helps
Jan 14, 2011 | HP Compaq d530 SFF PC Desktop
hi this is a setting in the cmos or bios you have to hit delete key or F2 depending on make of system to get into the menu, locate the setting for the chassis fan speed then disable that and you should not see the error on boot again...hope this helps
Jan 14, 2011 | Computers & Internet
Received 512 - chassis fan error on HP Compaq dc5100 ff - I replaced the front chassis fan after detecting fan was not working now when I attempt to log into windows - windows screen appears than...
if you download and install tune up 2010, it may fix your registry automatically for you however if it fails to, your operating system will continue to fail to shutdown or keep causing your system to hang at the f5 window which is the one your describing. Device drivers are very well known for causing this error and if you have installed a new device and your computer is not picking up the new device properly, then the computer will not shut down. There are several forms of viruses that cause the system to stay on, power problems may cause the system to crash during a storm and thus damage the computer registry. A system defragmentation, cleanup, along with a registry clean would be the first best ideas.
Jan 12, 2011 | Computers & Internet
if you download and install tune up 2010, it may fix your registry automatically for you however if it fails to, your operating system will continue to fail to shutdown. Device drivers are very well known for causing this error and if you have installed a new device and your computer is not picking up the new device properly, then the computer will not shut down. There are several forms of viruses that cause the system to stay on, power problems may cause the system to crash during a storm and thus damage the computer registry. A system defragmentation, cleanup, along with a registry clean would be the first best ideas.
Jan 12, 2011 | HP Compaq dc5100 Small Form Factor PC...
By enforcing the option to return BACK TO THE LAST KNOWN GOOD CONFIGURATION you have nothing to lose. Respond if you have already selected that option with no success?
Bruce
Jan 12, 2011 | HP Computers & Internet
512. chassis fan not detected the meaning
means that you need to go into the bios setting and go to hardware manager i thing on hp and dissable the fan monitor or open case and make sure system and cpu fan are pluged in and running
Aug 15, 2010 | HP Compaq d530 SFF PC Desktop
How to fix error 512 for evo d310 I replace chassis, rear chassis, or front chassis fan but still error I wont to fix it not show any error thank
Error 512 is a common Windows error. Error 512 is usually caused by missing system files, wrong system settings or a corrupted registry file. Run a registry scan to check for registry errors & other system problems. 90% of the time this will fix the cause of the error.
Optimize PC programs might do the trick, some are free to download.
Jan 13, 2010 | HP Compaq Evo D310 PC Desktop
HP D530 SFF CHASIS FAN NOT DETECTED
tell me the wright way to remove 512 chassis fan error i am very depressed on this
Mar 17, 2009 | HP Compaq d530 SFF PC Desktop
Computers & Internet Logo
130 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
