Question about Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer
The washer stops in the middle of rinse cycle screen says LR
  • 2 more comments
  • Richard Greaves
    Richard Greaves Aug 08, 2012
    7 year old - LR A&E can not fix 3 months out of service, no one cares!
  • Richard Greaves
    Had to order rebilt board, Back ordered new board, rebilt board did same thing, sometimes complete cycle most times no wash LR signal pops up all the time on several different settings.
  • Richard Greaves
    Called for Maytag Repair, got A& E Service, they will not work with you, found company that had rebilt board, A&E would not order it, had to call and place order myself, didn't help. Looking for a fairly new used Neptune wiith the oval display board.
  • Virgil Watts Apr 30, 2013
    LR means locked rotor in motor. Make a good check on your motor unplug it and use a jumper cord to the right connections & see if motor runs ok. Sounds like intermittant though. Could be motor board.Check all connections on motor and board.
    President:
  • Maytag Master
  • 2,651 Answers
LR == locked rotor, which translates to a bad motor and motor control board( usually depending on age sold a 1 set. Neptune repair kit. retails for about $200 part number 12002039
Posted on Oct 26, 2008
Yes I just want to know I it's worth fixing this prob. I have a maytag Neptune tl washer model fav6800aww it's starts fine but after 3 minutes it stops on wash cycle an after 5 minutes Lr shows on...
Lr error code is locked rotor. Could be a couple different issues.
Google this phrase and read thru the post ""[FIXED] Maytag Neptune Top Load FAV6800AWW -- tub/motor will not spin""
Post in that forum if you want to DIY I do not offer DIY help here any more.
Jul 12, 2011 | Maytag Neptune FAV6800AW Top Load Washer
The washer will not complete the wash cycle. Lr
http://www.servicematters.com/maytag_library/docs/TDL-0044B-B.pdf
If all else fails, replace motor control board, and/or motor.
Jul 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
Code LR keeps coming up on my Maytag Neptune TL every time it starts to rinse and I have to stop the washer, wait for it to unlock and start it over again.
can't find lr code open it up inside there is a tech sheet stuck to the side inside the washer put it back when u r done so it will allways be there
Dec 25, 2009 | Washing Machines
Maytag neptune error? message
Unplug for 10 min to reboot the curcuit board. This will reset the system. Sometimes selecting numerous cycles or pushing buttons a lot in a short period of time can overwelm the little brain in the curcuit. This action will clear the memory of any unwanted comands in the curcuit.
Apr 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
CODE SYMBOL " LR" (MAYTAG NEPTUNE SERIAL # MAH6500AWQ")
LR usually means that the the signal from the board is not getting to the motor either because of a bad connection at either the motor or the board or the motor itself is no good. Need to check the connections first.
Dec 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer shutting off on rinse cycle
If the washer is not completing the Rinse cycle there may be problem with:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Let me know if you need further assistance.
Regards
Ellin
Sep 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune MAH4000
Are you getting cold water to fill ?How is the water pressure?Timer maybe at fault here.
Jun 09, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
448 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
