Question about Directed Dei Valet 561r Remote Start/Keyless Entry
I replaced the battery on my remote starter and now it won't work. The lights come on but it won't turn over.
There looks to be a phone number on the remote. 1-800-274-0200, but I'm not sure about the 8. Its worn off. Help!
  • 3 Answers
Not in backwards (battery) but led should not show as they are polarity dependant, didnt format the remote by accident somehow? any error msg on dash?
Posted on Feb 18, 2012
Car won't start just click
Have you checked to see if you can turn the crank with a wrench ?
And are the cables good from the battery to the starter ?
Jun 20, 2013 | 2001 Oldsmobile Alero
Won't turn over
Even though all your other electrical bits are working it could be that your battery doesn't have enough juice to crank the engine. It doesn't take much power to run the radio, lights, etc, but cranking the engine requires the battery to have a very strong charge. If your battery is more than 5 years old, that's very likely the issue. I'd start there. Also, be sure to check the battery terminals and ground for corrosion and clean if necessary. If replacing the battery doesn't solve the problem it could be the starter solenoid or a loose electrical connection somewhere.
Apr 30, 2013 | 1999 Volkswagen Beetle
Disconnected battery in 2007 gmc Yukon. Dash lights and radio work. Engine won't crank. Remote won't work. How to reset?????
kindly pls check the BCM which is located under the left side of the dashboared i hope that will help.
Mar 30, 2013 | 2007 GMC Yukon
2001 GMC jimmy won't start. New starter, new
If the starter motor is turning the problem may be a broken flywheel tooth. If starter is not engaging the solenoid may be bad or not hooked up but that seems unlikely since starter was replaced. The problem's down there. If solenoid not clicking then problem may be further back.
Jan 15, 2013 | Cars & Trucks
My 2008 silverado won't start battery is charged
No, it isn't an ignition issue.
Check power to the starter motor solenoid.
If this is getting power when cranking, then the issue is with the starter motor solenoid or starter motor. Replace.
Nov 12, 2012 | Cars & Trucks
MY PLYMOUTH GRAND VOYAGER 'S HEADLIGHT'S AND DASH LIGHTS WORK, BUT THE ENGINE WON'T TURN OVER. THERE IS NO SPARK COMING FROM THE ELECTRICAL WIRES.
When you say no spark, are you talking about the spark plugs, or just the general wiring?
If the engine won't turn over, then it isn't moving, and if it isn't moving then you need to check the following in this order:
1) Does the battery have power i.e. around 12.4 volts or over?No? Charge, test or replace battery.
2) Do the car's head lights dim considerably if turned on when attempting to crank? Yes? Possible lack of battery charge or faulty battery.
3) Assuming the battery is fine, can you turn the dash warning lights on and off with the key? No? Faulty ignition switch.
4) Is there a click sound when you turn the key, but no starter motor spin? Check starter motor connections or replace starter motor.
If none of the above prove to be of help, then please report.
Oct 31, 2012 | Plymouth Cars & Trucks
My daughter 2004 Kia won't hold a battery charge.
voltage regulator. it may be in the alternator, or remote mounted. ((the alternator can be charging, but if voltage regulator is'nt working then it won't allow voltage to get back to the battery to keep it charged
Sep 07, 2012 | Cars & Trucks
Replaced battery on my 2006 Ford Escape. Still won't start but everything else works
Figure by everything else you mean the radio,lights,etc? Is the engine turning over? What happens when the key is fully engaged? If the engine does not turn over the first place to look would be your fuses. Ensure that none look to be burnt or blown.If so replace and try again.If fuses look good Next step would be to ensure starter connection is good and starter is turning over.If the starter is not turning over then I would focus on it.Hope this helps.
Apr 15, 2012 | Cars & Trucks
Bike won't start, starter soliniod clicks but starter won't roll over, it will hum and not turn over.
Those are the typical symptoms of a weak battery. Try either to charge the battery, try a jump start or replace the battery. Lights or horn working do not give an indication of the battery charge status.
Jun 13, 2011 | 1984 Yamaha XJ 400
Directed Dei Valet 561r Remote Start/Keyless Entry Logo
384 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
