Question about Asrock M266A Motherboard
Troubleshooting for usb - Asrock M266A Motherboard
  • Asrock Master
  • 27,725 Answers
Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Posted on Feb 19, 2012
I have a sanyo 32inch usb and hdmi vga and mroe but i wonder if a usb mic would work
I don't think so. The tv must have the hardware and the software in order to recognize the USB as a microphone. I believe the USB in the TV is for Troubleshooting and data purposes. Just my two cents.
Jun 29, 2017 | Sanyo Computers & Internet
Tip
USB DEVICE DOES NOT recognize
Issue:: USB DEVICE DOES NOT recognize
___________________________________
Manual Troubleshooting for this issue::
-Open device manager
-Right Click on USB Root Hub
-Choose Properties >>Selet Power Management
-Remove the Tick Mark Before "Allow the computer to turn off the power if device is not in use..."
-Do the same for all USB ROOT HUB
-Then Uninstall all USB ROOT HUB
-Restart your computer , USB device will be working.
on Jun 21, 2010 | Computers & Internet
No sound while attaching to my mp3 player via usb and aux pin cable
No Sound? Don't Worry! Troubleshooting Tips For Your ...
www.makeuseof.com/.../no-sound-dont-worry-troubleshooting-tips-for-...
Apr 23, 2013 - Using your computer seems like a purely visual experience, but the aural experience is surprisingly ... There's no sound coming from your speakers. ... Which is weird, because my hearing isn't that great. ... MP3 Player/Phone ... If they are USBspeakers, check your USB drivers while you're in there. no ...
Why won't my system recognize my USB device? - Ask Leo!
https://askleo.com/why_wont_my_system_recognize_my_usb_device/
Oct 26, 2005 - My system won't recognize anything that is connected into USB unless ... Why is my USB device asking for a CD when I attach it? .... Follow-up: I plugged a 4-port USB hub into my computer and then attached my MP3 player to it, .... sounddetecting any usb device but in my computer there's no sign of it. i ...
My laptop does not recognize my mp3 player [Solved] - CCM.net
Dec 29, 2015 | Cell Phones
Comment resoudre l'erreur 03130031-2618
Here's a troubleshooting guide. The error has something to do with the voltage to the carriage unit. http://www.tdo.se/pdf/Scania/iPF-Troubleshooting-Guide-Level-2.pdf Don't know if this will help, but this PDF is pretty detailed in troubleshooting.
Jun 19, 2014 | Canon imagePROGRAF iPF755 Large Format...
DANE-ELEC So Ready 500GB USB 2.0 Portable SO-MUJ1KP853371 Harddisk troubleshooting (Code 43)
This is a Driver issue. Search for updated drives.
If that doesn't work you probably need to contact a disk recovery specialist such as DATA365. http://www.datastor.net.au
Dec 06, 2013 | Dane Elec DANE-ELEC SoMobile 500GB USB 2.0...
M2n68-la beep codes
Whenever electronics devices give high pitched beep, it generall means a future failure . There could be reasons for the same.
1. Static built up on the motherboard
2. Conflict on the USB ports.
Troubleshooting 1 :
1. Diconnect all the wires from the tower, including the power cable. Press and hold the power button in the front to remove any static from the motherboard.
2. Check and try again the devices on the USB port.
Troubleshooting 2:
1. Check USB ports for damage , try connect the device to the back of the tower.
Troubleshooting 3
Clear the motherboard setting , use the link attached and see clearing the BIOS settings
Thanks for using fixya
Proton
Jul 07, 2012 | Computers & Internet
Bluetooth device not working and not detected in device manager
Good day. In regards to your issue when it comes to your bluetooth device you can try the following steps. Usually these will resolve your issue
1. If your Bluetooth device uses batteries, make sure that your batteries are charged. 2. If your Bluetooth device uses a transceiver that connects to your computer through a USB port, try connecting the transceiver to another USB port on your computer. 3. If there are multiple Bluetooth devices connected to your computer, temporarily remove the devices that you are not troubleshooting. If there are additional USB devices, try removing any USB devices that you do not have to have installed during the troubleshooting process. If you h have multiple devices that are connected by using USB, this can interfere with a Bluetooth transceiver. 4. Verify that the Bluetooth device that you are troubleshooting is powered on and that it is enabled.
If these steps didn't resolve your concern, you can try to update your windows version like installing updates that can be found on the microsoft.com website or go to http://update.microsoft.com. You also have the option to contact HP for them to help you with issue but most probably they'll be charging you for this specific problem. Hope this information will be helpful in resolving your concern. Have a great day and thanks for using Fixya.
Jun 25, 2011 | HP Pavilion DV9500T 17" Notebook Laptop PC...
I have a WD passport 320gb, at first it worked one of my usb. then all of sudden, it stop recognizing my WD Passport with one usd port, so i plug it in another usb then it works. and after a couple of days...
Are you using an external power supply for the disk? If not, you might be overloading the USB port. It should not happen, but USB ports are limited in the amount of power they can output. Especially laptops might face such problems.
Do other USB devices still work on those USB ports? If so then the port is at least not broken.
Sometimes you can uninstall and reinstall the USB hubs and controller devices in the Device Manager to fix USB problems.
For other ideas on troubleshooting external hard disk issues, you can check: www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Jun 13, 2009 | Western Digital Passport WDXML800UE...
Wii wireless connction has error code 51040
rror Code: 51040 Please try the following troubleshooting for the Nintendo Wi-Fi USB Connector
  1. Verify that the Nintendo Wi-Fi USB Connector is installed correctly and that the PC is turned on (the USB Connector will not work while the PC is turned off).
  2. Try our interference troubleshooting steps.
  3. Are you using any security programs (firewall, anti-virus, anti-spyware, anti-adware, etc.)? If so, you may need to add the Nintendo USB Registration Tool software to a list of "allowed" programs or "exceptions." If this is unavailable, you may need to disable yousecurity program before the Nintendo Wi-Fi USB Connector can access our servers. See Nintendo Wi-Fi USB Connector "Firewall troubleshooting" for more information.
  4. Try uninstalling the Nintendo Wi-FI USB Connector software, and installing the newest version. To get uninstalling instructions and the latest version of the software, please click here.
Nov 29, 2008 | Nintendo Wii Console
USB Troubleshooting - Windows
Many problems relating to camera connection issues relate to hardware other than the Nikon camera. There are numerous compatibility issues between USB Controllers, motherboards, main CPU chips and different versions of the Windows operation systems. Below are some helpful links. The Microsoft web site has information regarding USB Troubleshooting for Windows 98, Windows 98 SE and Windows ME. http://support.microsoft.com/support/kb/articles/q263/2/18.ASP The Microsoft web site also has information regarding general compatibility between Windows and different USB controllers. Select "USB controllers" on the link and then find your USB controller on the list, if your controller is not listed as compatible or "logo" with your current operating system you may need to upgrade your OS, or work with alternate hardware. http://www.microsoft.com/hwdq/hcl/default.asp The Compaq web site has information regarding issues with their Deskpro 2000/4000 USB and Windows 2000. http://www.compaq.com/support/techpubs/customer_advisories/DG000117_CW01_0.html The Microsoft web site has information regarding issues between AMD Processors and Windows SE. http://support.microsoft.com/support/kb/articles/Q240/0/75.ASP One method for restoring USB functionality is to remove the currently installed USB Controller (from the Device Manager). Be sure to have the Windows installed disks available as you may be prompted for them. To accomplish this: Open the Device Manager (right click on "My Computer" and choose "Properties" Windows 98 and ME have a "Device Manager" Tab Windows 2000 and XP will have a button in the "Hardware" tab Click the "+ " sign next to item named "Universal Serial Bus controller" and highlight the "Unviversal Host controller" found beneth it. Once the item has been highlighted press "Delete" on the keyboard Refresh the Device Manager With Windows 2000 and XP choose "Scan for Hardware changes" from the "Action" menu. With Windows 98 or ME click "Refresh" If you were prompted for the install CD or to restart the computer there were definite driver changes made and any USB issues may be resolved.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Asrock M266A Motherboard Logo
96 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
