Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint washer dryer
I've a hotpoint washer dryer. It stays filling with water even when switched off. I have been told there is a blockage somewhere. Any idea how I might go about fixing this?
  • Cathy Hewitt Aug 21, 2006
    Thanks. Will get details to you tomorrow.
    President:
  • 878 Answers
Daidan, If you unplug the washer and it still fills you have a bad inlet water valve. If you post the complete model number we would be able to help you better...Catriver...post back
Posted on Aug 21, 2006
Hotpoint TDC32P condenser tank not filling
you should read the catalogue.
Mar 26, 2013 | Dryers
Empty water light flashing on hotpoint ctd40 dryer even with no water in it can you help
this could be just a sticky switch staying stuck on, telling the dryer it has a full tank try soaking the switch in switch cleaner or wd40 may work
Jul 23, 2010 | Hotpoint Dryers
Drum keeps filling with water even in dryer mode
Open up the top of the machine. Plug off the wall mains. Turn off the wall faucet. How is the wire connection for the inlet valve, the water inlet. Fine? If not unscrew the inlet valve from the corner of the machine after disconnecting the hoses, & dismantle to clean it up, re-assemble, refit back to machine.
Mar 27, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WT540 1400 spin Washing Machine stuck on cycle
Could be a sticking water level switch, which controls the water level, or a blockage in the hose to the switch, or a trapped or split hose to the switch. the hose in question is about 6mm in diam,and goes from the sump hose to the pressure switch,if u remove the hose from the preesure switch chamber, check for a blockage there, and blow down the hose to see if it is clear, u should hear the switch click if it is clear, if no click and hose is clear, then I wud say the switch is faulty.
Plz rate my comments.
Thanks
Dec 31, 2008 | Hotpoint Aquarius WD63 Front Load...
I have a Plain Hotpoint washer,and it keeps filing with water on large load,but will stop on small load.Will continue to fill even with it unplugged, what could it be?
No it will not keep filling when it is unplugged.
The problem is probably due to a sticking water level switch, or a partial blockage in the water level sensing system. \you will probably need to call an engineer.
Dec 06, 2008 | Frigidaire FEX831CS Top Load Stacked...
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint ultima 1200 washer/dryer
Have suffered the same problem. Suggest you remove back (after turning off electrical supply) and look at the water outlet pipe - you may have a sock or two in this - remember to reattach outlet and secure in position.
Aug 15, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
