Question about Alpine MRD-M605 Car Audio Amplifier
ALPINE amps cutting out
My current set up consists of line signal converter (LC6i) matched up to two alpine V12 amps powering 4 alpine type r speakers, splits at the front coaxials at the rear.
my problem lies with this, when the sub is just about to kick, the 4 channel amp cuts out and only the sub produces sound.
Does anyone know what the problem to this is, or a solution to solve it?
any help would be greatly appreciated.
localwonder
  • 6784 Answers
SOURCE: alpine v12 amp no power
its your fuse box. i would bypass the fuse box and wire this amp directly to the battery via monster cable. make sure you attach a 30wieght fuse to the monster cable that is running from the battery to your amp. ground the amp against the trunk. scrape the paint of a section and drill a hole in the trunk. use this for the ground for you amp. this will fix the no power issue.
Posted on Feb 12, 2009
artbesio
  • 55 Answers
SOURCE: want to bridge my alpine 3555 amp to run my sub.
I'm assuming this atleast a 2 channel amplifier all you need to do is hook the negative side of the speaker wire coming from the sub to the negative channel one. and the positive to another positive on channel 2. Should indicate on your amplifier channel one and two. most amps provide a diagram right on the amplifier over top of the speaker inputs. let me know if this helps.
Posted on Mar 08, 2009
SOURCE: why my alpine v12 amp is getting hot and melting fuses
You may have to big of a load. The speakers may be to low in ohms and the amp cant push speakers that low or there is a short in the wire going to the speakers
Posted on Apr 09, 2009
  • 150 Answers
SOURCE: alpine pdx 1.000 keeps cutting out
You are going to want to make sure all your power wires and grounds are 4 gauge as well as the wire leads to and from the capacitor-4 gauge also. make sure you have a very good ground - the power wire from the battery should hit a distribution block-from the dist. block a 4 gauge should go to the capacitor another 4 gauge to the mono amp and another to the 4 channel amp -every component should have a good solid ground even if you have to bust out a grinder and a drill and some self tapping sheet metal screws and go nuts on it- see if that helps you
Posted on May 27, 2009
rteemon
  • 578 Answers
SOURCE: Alpine PDX 1.1000 low power output - sub not loud
system not configurate properly go to a pro and let them do for you you have good equipment just need to put together rite.for wht you have you can get better sound than that,,good luck
Posted on Jun 26, 2009
I need to know how to hook up an alpine v12 amp 2 ohm i have two tens
This really depends if your 10" subs are 4 ohms each or 2 ohm - for this exercise, I'm presuming they are 4 ohm each.
You already know your amp can deliver 600W RMS (@ 2ohm), so you need to be careful you do not exceed the maximum RMS input power of your subs.
Normally you would wire subs in "parallel", which would reduce the circuit load to 2ohms - however, the 600W RMS power may be too high for your subs to handle.
In this case, it may be safer to wire your subs in "series" - this will increase the circuit load to 8ohms, which will effectively decrease the amps RMS power output.
Cheers,
Sep 05, 2011 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
Ok i got a mtx 12' 500 sub matched to a alpine mrd-m500 mono amp. The deck powers the 4 speakers, as i turn the volume up on my deck (alpine cde 100) the sub/amp cuts out at around volume 20-22 and E-3...
Sorry,after rereading your problem,I gave a wrong answer.Do you have the deck sub RCA pre-amps connected to the amp,then the wires from the amp to the sub?If you do,you need to check what the sub and amp are rated as such as,peak or rms.They are 2 completely different meanings.Greg
Feb 11, 2011 | Alpine MRD-M500 Car Audio Amplifier
Amplifier displays "CUR"
Hello anwbrown,
The "CUR" display means that the amp is drawing excessive current and the protection circuit is activating. Too low impedance or shorted speakers will cause the amp to draw excessive current.
The Alpine V12 is a Class D mono amp with only one set of speaker outputs. All versions, M301, M501, and M1001 are only stable to 2ohms. Assuming that all 6 of your connected subwoofers and speakers are 4ohm and they're all connected in parallel, the amp sees a .67 ohm load, far below it's rated impedance.
When brand new, the amp could probably operate at low to moderate volume levels without drawing excessive current. But as electronic components age, their tolerances change and they become less able to withstand excessive current or mismatched impedances.
I'd get a 4-channel amp and drive the 4" speakers off the front channels and the 6X9's off the rear channels. And just power the subs off the V12 making sure that they are connected to show a minimum load of 2ohms.
Hope this helps.
Jul 27, 2009 | Alpine MRV-F345 Car Audio Amplifier
System Cuts Off
your amp is tripping out because the subs a drawing to much power get a better amp alpine subs demand a lot of power try a high current amp
Jun 30, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Bostom tweeter cutting out
get a new tweeter. really, if its starting to cut out, or static, then its prabably old and need a new 1
hope i was help :)
Apr 28, 2009 | Car Audio & Video
Alpine v12 amp no power
Feb 12, 2009 | Alpine MRV-T707 Car Audio Amplifier
Alpine v12 amp displays CUR and cuts itself out when i turn up the volume????
I'm not specifically familiar with that model but I'm pretty sure the"CUR" is indicating under current or not enough current. what's happening is your amp is under load and doesn't have enough power so it shuts down rather than smoke. I would suggest you run heavier cable from the battery to the amp and add a giant cap so that when the amp surges the cap will compensate for the sudden draw. This is not a cheap fix but if you install heavy duty power cable and a quality giant capacitor (2 farad) you will be able to push the amp until your speakers catch fire and your amp will be fine.
Rob
Dec 12, 2008 | Alpine Car Audio & Video
V12 MRV-1507 or Xplod? Amplifier - XM-ZR1252 good quality sound
Alpine is just a better brand in general. I have the older MRV-1507, sounds GREAT, i have had friends who has had the Explode line, but it was always a temporary system until they got something better, like the alpine or kenwood.
Aug 14, 2008 | Car Audio & Video
No power to amp
soundsto melike an underrated ground system. make sure that your ground cable is clean and is connected to the frame.
Sep 02, 2007 | Alpine MRV-F545 Car Audio Amplifier
Alpine MRD-M605 Car Audio Amplifier Logo
73 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
