Question about Honda Garden
How do i remove flywheel on honda 5hp xr2500
Hi, there is a severe oil leak behind the flywheel. I need help in explaining to me how to remove it. I want to learn as I go. Is there a schematic showing parts of this engine? The engine is overhead cam. Thank you. Regards, Rick E.
  • 211 Answers
SOURCE: i need to remove the flywheel on a 288 husqvarna chainsaw
you need a rope with nods on it ,put it on the sparkplug gauge to block the piston in the cilinder,after that try to unlock the clutsch and the flyweel.Then disassembly the engine and change the seals.
best wishes Mihai71
Posted on Nov 28, 2008
  • 211 Answers
SOURCE: Honda GC160 5HP engine
Hi
9 ft-lbs .Now about the timing marks.If you look at the top you can see 4 gears:2 balancer shafts,the crank shaft and the cam shaft.There are two possibilities for timing marks:the first is balancer to- camshaft timing marks,balancer-to- balancer timing marks and the second one iscamshaft-to crankshaft timing marks and balancer-to-balancer timing marks.Ignition coil-to-flyweel gap is 0.016 inch.
best regards savumihai71
Posted on Feb 15, 2009
SOURCE: I need an IPL for Honda GC160 5hp engine
This may help. Get the name and number off from the carb such as walbro or zama to name a few and go to that indivdual web site and print out a parts list. I have done it many times and it works for me. I hope this will help. Donnyb60
Posted on Mar 19, 2009
HondaAl
  • 72 Answers
SOURCE: Honda stationary engine hunting 5HP
The IAC, (Intake Air Control valve) is a rotary valve that binds with carbon build up. the valve is usually on the bottom of the throttle body, has two small coolant hoses going to it.
Posted on Apr 23, 2009
  • 37 Answers
SOURCE: Need to know how to change the oil in my Honda
take out the drain plug under the lawn mower drain it put the plug back fill it with oil then you done
Posted on Jun 06, 2009
Governor pivot shaft leaking oil
over filled or bad seal. or someone tilted over engine, 90 degrees. or more.
Dec 11, 2013 | Gx140 5hp Engine
The pump is leaking some gray fluid
Gray fluid is usually indicative of old oil with water mixed into it. First you have to determine if the fluid is coming out of the motor or pressure pump. Then change the oil in that, or both, and then watch the condition of the oil when you use the washer. With new oil, it won't turn gray but will get a milky coloration to it. There shouldn't be any way for water to get into the motor oil short of the engine being sprayed directly with high pressure water. If water is getting into the pump oil you'll have to check the seals inside the pump.
Feb 14, 2013 | Honda 5hp 5 Hp Engine Motor Xr2500 Xr 2600...
Oil leak front engine timing chan
1995 Tracker would have a timing BELT. Normal oil leak points (in order) on a Suzuki G16 engine are the distributor base (rear of motor), valve cover (top of motor), front main seal (behind lower timing belt cog) cam seal (behind the upper timing belt cog) and rear main seal. (behind the flywheel). I'd suspect the front main seal or cam seal. I use foot power to help find oil leaks.
Dec 24, 2012 | 1995 Geo Tracker
82 Goldwing 1100 Interstate weep hole behind oil drain plug
Hi, Kevin the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
82 Goldwing 1100 Interstate weep hole behind oil drain plug Google Search
Oil leak near GL1100 water pump
Honda GoldWing GL1100 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda Gold Wing GL1100 Owner Manual
Jun 23, 2017 | 1982 Honda GL 1100 Innerstate Gold Wing
Leaking at front of transmission
Hi Clifford, Any leakage from the front, or for that matter the rear of a transmission is a big job! The leakage if its from the transmission, will probably be behind the torque converter if the vehicle is automatic, or behind the clutch release bearing on a manual box. If the vehicle is consuming engine oil the leakage may well be from the rear crankshaft seal, which is situated behind the flywheel. If you need to remove the flywheel, keep in mind that the bolts are tightened to a specified torque which must be adhered to when refitting. Wherever the leakage is from the removal of the gear box is required. Regards John
Jul 14, 2012 | 1999 Lincoln Continental
Troy built mower honda 160 engine oil leak around governer shaft. no oil seal but shows one on parts breakdown. Can not find part number for shown seal.
Drain oil from mower until proper level. Remove spark plug and pull starter rope several times to blow out cylinder. Spray starter fluid in cylinder pull rope several times to clean out. Replace fouled plug with new spark plug. Remove air cleaner, ensure no oil present, replace filter as needed. Clean air filter box with carb cleaner. Install new air filter reattach filter cover. Prime engine, pull starter rope 1/2 way 4 times to help prime, then pull starter rope fully up to 10 times to start.
May 24, 2012 | Troy Garden
How do i remove the flywheel from my honda xr250 1987? it has an oil leak, i need to get at the seal behind the flywheel. thanks
take a long crowbar fit it between the bolts and crack the bolts with a breaker bar in an opposing or star pattern use a mapp gas or propane torch VERY CARFULY hit the area around the bold for 4 seconds to overcome any loctite if you cant break with a bar by hand first there is a better way but it involves a specialty tool or two
Mar 11, 2011 | Honda XR 250 R Motorcycles
Pressure washer with 5hp Honda will ONLY run with choke on
It sounds like it has been tipped or too much oil has been put in. This would explain the oil in the air filter. First check the oil level. Then you need to clean the oil out of the carburetor. It is dirty or plugged and that is why it only runs when choked. You can try a spray-in carb cleaner but the best thing is to remove it (if you are handy enough) and soak it in varsol for 24 hours. Good luck
Aug 10, 2009 | Karcher 2500 PSI Pressure Washer
Oil leak
the pcv valve gets plugged up those building up pressure in the crank case and blowing out the oil pump seal on the front of the motor!
Jan 24, 2009 | 1992 Honda Accord
Garden Logo
85 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
