Question about Technics Audio Players & Recorders
I have amplifier Technics SU V9 and I have problems with silver platted selectors for Input, Phono and Rec. They have part No ESA 2682 and ESA 26523. Where can find new ones or how to fix them?
I suggest that the problem is in the silicon grease inside the selectors.
robotek
  • 1512 Answers
SOURCE: TECHNICS SU-V50
Hi max
I have done a followup with Technics Parts agents in the US, they will get back to me and then me to you shortly :) A vote as FixYa would help improve my ratings. Thanks
Graeme
Posted on Feb 09, 2008
robotek
  • 1512 Answers
SOURCE: technics su-v45a
Hi ferrariman
For sure, even though a manual is a bit hard to find for free, we may be able to help you solve the problem. I have worked on alot of technics amps over the years. What is happening to the amp?
regards
robotek
Posted on May 20, 2008
paulm10
  • 73 Answers
SOURCE: Missing Operating Manual Technics SU-V4X
http://www.eserviceinfo.com/downloadsm/35463/Technics_SU-V4X.html
Paul
Posted on Jun 13, 2009
petraman7
  • 1175 Answers
SOURCE: Technics su-Z750 Intergrated Amplifier stays in Standby
HI...
This happens when one or more components in the power amplifier section has failed.
The protect circuit keeps large DC voltages off the speakers.
The only thing you can check for before finding a tech is that the speakers are firmly connected at both ends. If they are ok, you need a tech
PLease rate my help if this helps
Posted on Nov 09, 2009
Grubhead
  • 5158 Answers
SOURCE: Looking for S4 input selector switch for a Technics SU-V4 amplifier
You can try Willow Vale. Also CPC. And SEME.
Posted on Apr 02, 2013
Does a technics stereo amp su-g90 have a stereo to play music
This device does not have an internal tuner. It is simply an amplifier. The buttons on the front labeled TUNER - TAPE - PHONO - DAT/VCR 1 - VCR 2/TV are selector buttons for additional components that hook up to the respective connectors at the rear of the unit. If you want to play a radio with this device, you must buy a tuner and attach it to the tuner inputs in the rear of the unit.
Oct 03, 2016 | Technics Audio Players & Recorders
Technics su z2
HI
2 things can do this
1.input selector is dirty and needs to be cleaned.
2.the power module is damaged.
Hope this helps
Dec 28, 2013 | Technics Audio Players & Recorders
Technics SU-X302 Problems
Greetings
Is there any indicator on or its all off?
anyway i will assume that there is none
1.check power fuse if blown.
2.check power transformer if there is any output voltage
3.check internal fuses
more information will give a better idea.
try these steps and hope this helps.
Dec 25, 2013 | Technics Audio Players & Recorders
Hi, |I have technics su-c909u and the problem is that when I set it on tuner, for example, it changes on phono or cd, and keep changing several times. It usualy hapens when it works for a while. do you...
Hi
are you living in a humid place.
ex: like close to the sea?
first impression is this :)
there is another thing can do the same problem
if the selector chips is damaged or over heated its can do the same thing.
hope this helps
Dec 23, 2013 | Technics Audio Players & Recorders
The input selector switch has a mind of its own and changes when it likes to what it likes. There is a clicking relay sound when it occurs. Is this a faulty relay or a dirty switch. (Sorry about previ
I havd the same issue. u need to get a good contact cleaner and spray the selector rod( remove knob first with preamp facing up), the liguid will find leak into selector and clean contacts.
after doing mine, the slector knob feels more solid when turned and does not change input anymore.
Junior
Jan 04, 2013 | Technics Audio Players & Recorders
Re: Technics HD51 home stereo system (amp, tuner, CD, and cassette player) - I'm told it needs a pre-amp in order to get any reasonable amount of sound out of lp's on the Linn Sonex LP12 turntable. At the...
The Amplifier must have a high impedance input for the turntable to be connected. Now most of the present day amplifiers do not have this input but only the regular aux input which is designed for a larger signal . But the turntable outputs is quite low and so it requires an amplification of high order. What you can do if you need to play the turntable is to have first a preamplifier with a high impedance which is available even inkit form and can be fitted on to your system. The preamp output can be shared into the input of the source selector maybe with a switch and you willl be able to fix two RCA sockets to accept the input of the phono. This will work fine provided the shielding is done well to avoid the high feedbacck to oascillate and cause noise, the premap must be housed in a shielded cabin. On the other hand you may have to buy a universal amplifier so that the phono input is present. Definetely nothing better than a designed input. So think and decide. hope I could help; Good day
Aug 10, 2010 | Technics Audio Players & Recorders
SUV500 2-Channel Amplifier: Hi! can I connect another technics cd-player,sl...
yes you can connect another cd player to the DAT input of your amp.
input connections like DAT, TUNER, CD, AUX etc (except phono) is just to differentiate between what sources are connected, the amp cannot tell what source is connected and will output the sound no problem.
as for the remote operation, if the 2 technics cd players are switched on at the same time they're going to do what you command from the remote together but you'll obviously be listening to 1 at a time.
May 17, 2010 | Technics SUV500 2-Channel Amplifier
Not a good sound
you can't...the technics need to be pluged into phono..because the signal has to be amplified for it to play...phono channels on amps and dj mixers have an amp built in....
Apr 06, 2008 | Technics SL-1200MK2 Turntable
276 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
