Question about Garden
Mini mac 35 no spark how to test
I have a mac 35 i got it started with start fluid but only ran for few seconds had it apart ,now it wont fire at all how to check for spark will bad plug be it or is it the megnetto,damb it did fire now it wont,useing start fluid please help
  • mhetrick56
    mhetrick56 Feb 20, 2012
    i took care of the problem it was the points underneath the flywheel there is a black shaped componate take lid off and there she was points were touching,i used a back of match pack to get it gaped about .015 ,note look around in the area there is a screw that comes threw from out side in of the case that holds ground wire and condencer wire to kill switch on in side of case there should be a small nut that the screw goes into mine was laying along side bottom of black case,
  • mhetrick56
    mhetrick56 Feb 26, 2012
    yea thank you,sorry did not mean answer my own problem ,just worked out that way,hope it helps some one else
    Sergeant:
  • 316 Answers
Hello. well thank you for taking care of the problem,,
Posted on Feb 20, 2012
4 Suggested Answers
  • 211 Answers
SOURCE: McCulloch mini mac 35. Badly worn chain
Hi
You need a chain with these carracteristics:3/8 ,PM,1.3 and the chain bar has 14" length.Hope this helps.
regards savumihai71
Posted on Dec 09, 2008
  • 154 Answers
SOURCE: i NEED TO KNOW SPARK PLUG GAP AND POINTS GAP FOR
spark plugs are usually .35 on chainsaws
Posted on Aug 23, 2009
  • 509 Answers
SOURCE: I was given a mini mac 30 chainsaw. it ran great ...
Most chainsaws in the United States operate on a 50:1 oil to unleaded gasoline ratio. Some manufacturers recommend a 40:1 mixture.
Posted on May 20, 2010
96 ciera 2.2 ran fine. parkedat night next morn wont start.its getting fuel and fire but sounds like its not even trying to start
Check for spark.. pull one spark plug out set it on bare metal(away from cyl hole fuel could light from spark) turn vehicle over and look for spark should be a nice lightning bolt looking spark... blue spark is weak spark.. and see if it's getting spark...,, if not,,."try new plugs.,wires,distributor cap&rotor " also first.spray a little starting fluid down the injection system turn it over and see if it fires.if it does then it's a fuel issue prob not electrical... try that.hope it helps
Dec 31, 2016 | Cars & Trucks
Why wont my 2011 jeep grand cherokee wont start
Okay, the possibilities are great. need to narrow it down a little.
If it fails to crank over it is likely the battery.
If it cranks over ok, but fails to start it is either lack of fuel or lack of spark.
the Quickest way to identify lack of fuel or lack of spark is to spray in a 2 second dose of starting fluid into the air intake. If it fires up then dies in this test it is lack of fuel most common suspect is fuel pump relay or fuel pump.
If it fails to fire up on the starting fluid test it is lack of spark. Electronic ignition trouble shoot procedure from your shop manual for your VIN number will be required.
Jul 05, 2014 | 2011 Jeep Grand Cherokee
Why won't my jeep start after replacing the battery & the spark plugs?
Need four basics to start the engine; timing, spark, fuel and air.
Is the engine cranking? If so, have someone to spray 'starter fluid' into the immediate air induction port. If it doesn't fire and run for a few seconds, check the distributor source. If it does fire and run for a second or two, you may have a fuel pump down.
May 06, 2014 | 2000 Jeep Cherokee
Cranks but will not start
Spray some starting fluid in the airbox inlet while cranking the engine with the throttle open. If it starts for a few seconds, your problem is with the fuel. If it does not fire still, You need to check for spark at the spark plugs
Feb 16, 2014 | Yamaha YZF-R1 Motorcycles
98 silverado intake gasket swap...truck ran now wont start
check all connections where you did the work and make sure no wires are loose or were barely plugged in possibly.
Dec 27, 2013 | Cars & Trucks
95 Cadillac fleetwood wont start does not seem to be getting spark what should i do?
What is engine size? Use a gage and check proper fuel pressure. My info says 41--47 psi, 5.7L engine.
Can you park on level ground to do testing? Visually check for spark at the plugs. Can you check if system is running rich or lean? How long since overall tune-up?
May 07, 2017 | 1995 Cadillac Fleetwood
Ran out of gas,put 4 gals in wont start tried starting fluied wont start
Sounds like the ignition system is not firing the spark plugs if starting fluid and gasoline doesn't solve the problem.
Verify by putting a spark tester on one of the spark plug boots and attaching the spark tester to the engine block or ground.
Dec 18, 2010 | 2006 Nissan Frontier
Wont start 1995 bmw 525. just stopped on me pushed out of road day later it started and ran fine for 15 min. now it wont start unless it sits for a few days and is cool outside. when it starts last few...
next time it wont start, spray some starter fluid into the air intake on the engine, if it fires then you have spark, if not.....prolly a spark issue.
Jul 13, 2009 | BMW 525 Cars & Trucks
Onece in a while turn over wont fire. runs great other wise
your injector or fuel pump may be going out, next time when you check the issue, check your distubutor again and making sure you getting sparks, if you do have sparks than it has to be your fuel problems.
Jun 25, 2009 | 1991 Honda Civic
Garden Logo
164 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
