Question about Denon Dns1000 Table Top CD Player CD Player
CDs get scratched when instered/ejected in the players
I have noticed that the players damage the cds when these are inserted and/or ejected. The scratches are in the radial direction of the cds, so it cannot be the laser or anything related to the rotation of the CDs.
THe weird thing is that both players do this!!! Has anybody ever had this problem, how did you solve it?
I use Traxdata cds, burned at 6x.
thanks
    Problem Solver:
  • 17 Answers
Sounds like something inside the deck is out of place, and is scratching the cd. Please bring your decks to an authorized service center to be checked out.
Posted on Mar 10, 2009
Hi ..I have Pionner PD-M701 CD Chanager .the player works so fine and recognize all cds in the trays but the issue is in the reading .
hi Sam.
you could try this.
Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lens cleaner.
Why does a CD player skip? They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.
.or try this link for more info.
cd player skips Google Search
Dec 03, 2017 | The Audio Players & Recorders
I have a 2005 Jeep grand cherokee...with a 6 disc cd player. It has worked fine for 3 years since i bought the vehicle...(i used burned cds in it usually) and all of a sudden it will not play or read the...
this is a typical problem with the factory stereo. usually there is nothing you can do for the Cd player, because most likely a cd got jammed and broke or bent some internal components. however try usig a credit card to help eject. insert it partially into the slot and pull out if the cd tries to come out. if this doesen't work then you will have to have the cd removed by tearing it apart. this usually ends up with at least one or two scratched cds and a deck in a million pieces.
Jan 18, 2011 | 2005 Jeep Grand Cherokee
My jvc player rejects my cds when I put them in. what do I do?
The mechanism that controls opening and closing of the tray is bad, that is why it keeps ejecting cds when inserted in.
Unplug the player and unscrew it open then plug it after opening the cover and try to insert a disc and see the how far the cd goes before ejecting, be sure not to touch any metal part in the player to avoid shock.
After trying to play a cd, you will notice where the tray ejects the cds from, it is located try to unplug the player and disassemble the mechanism, you will see either a worn out rubber or teeth on the mechanism, then replace them and reassemble it back together, after doing that, the player will be able to hold a cd.
Take care and good luck
Dec 02, 2010 | JVC KD-S640 CD Player
After jumping a dead battery (hot shot) the CD player died. It gave an error: it thinks that there are no cds inserted when in fact there are 5. It will not eject and I cannot insert. My hope is that I...
After my car battery went dead my cd player is stuck. It won't play, or eject and it thinks there are no cds in it when in fact it is full. HELP!
Oct 31, 2010 | Car Audio & Video
Cds are stuck in the default cd player of 2001 Dodge Intrepid. How do I get them out?
The first step is turning the car off. Then before turning the key back on, push and hold the Eject button then turn the ignition on. If the CD fails to eject then you can use a old CD and try to insert it into the CD Player, just as it try's to take your second CD pull it out and hit the Eject button again. This will usually get a Dodge CD player to Eject.
If this fails then the CD player must be removed and a manual eject can be performed.
May 15, 2010 | 2001 Dodge Intrepid
Two CDs stuck inside Cambridge Soundworks 765i
I have the same problem. Did you find a solution? Thanks.
Feb 08, 2010 | Cambridge Soundworks 740I CD Player
CDX keeps ejecting CDs some seconds after insertion
Replace the drive!!! I have six and this is the ONLY problem I see with these units!
Oct 08, 2009 | Nu Mark Numark Cdx Table Top CD Player CD...
CMT-BX1 won't play CD's - "No Disc"
If they're clean (i.e. not scratched up or dirty) store-bought CDs (burnt CDs can be iffy in some players), then yes you should return it.
Sep 16, 2007 | Sony CMT-BX1 Shelf System
Tray error
I saw on another JVC systems manual that its an error message that shows when the tray isn't fully open due to an obstruction. If you can locate a manual eject button(usualy you'll need to insert some tip into it) it will help you eject the tray and look for any obstructions, anything looking out of the ordinary there. at least that way you'll be able to take your cds out... You can also try disconnecting the system from all power sources for a few days(including an internal battery), maybe the reset will jog it back to working order. If you're out of warranty and know your way around those things, try taking it apart, cleaning as much as you can, and look for anything out of the ordinary, like broken gears or pins, bent parts, a cog, etc. Good luck
Feb 12, 2006 | JVC FS-S77 System
Denon Dns1000 Table Top CD Player CD Player Logo
239 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
