Question about Sony D-EJ011 Personal CD Player
Sony d ej011 ac port not working
Sony D-EJ011 ac port not working
3 Suggested Answers
rommelalilin
  • 2178 Answers
SOURCE: I purchased a Sony Walkman
It's designed just to use batteries.
Posted on Feb 24, 2011
welcomejee
  • 10594 Answers
SOURCE: Walkman Model D-EJ011. Been
Yes, its toast. Sled mechanism seems broken and complete optical lens will be replaced that would cost more than D-EJ011 worth.
Thanks.
Posted on May 02, 2011
Testimonial: "Thanks for your confirmation! Product overpriced and lasted <1yr. Now see many people expressing same. Unethical, actually. Thanks again."
Charger from main suppy not chargeing
The Sony D-EJ011 should run from the mains power unit and is capable of charging a set of rechargable Ni-Mh batteries.
Alkaline batterys do not take kindly to being recharged and may leak causing possible damage to the battery bay.
Feb 26, 2014 | Sony D-EJ011 Personal CD Player
I have sony vaio vgn-cr 353 model suffering for abnormal shut down problem. what are the posible cause? pls help me.
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Jul 22, 2011 | Computers & Internet
Where do you insert the battery on the D-EJ011 Sony walkman portable CD player
Slide OPEN to open the player lid and open the battery compartment lid inside the CD player.
Feb 19, 2011 | Radio Communications
Keeps on saying there is no disc in walkman when there is?
This is a confirmed ffault of either the optical head being dirty or faulty. First use a good swab, or a good earbud to carefully wipe clean the lens to shine well. check if the disc turns or tries to turn. open and check if the cd is free in rotation on the spindle. If so your optical head needs to be replaced with the same type. Proceed to change if the cost is resonable to you and a true replacement is available.
Helpful? Good day
Jun 10, 2010 | Sony D-EJ011 Personal CD Player
Cdplayer says no disk but disk is loaded
Most common problem is that the laser lens in the cd is dirty. You can clean it with 90% alcohol and a q-tip. If that doesn't work, try another disk, the one you have might be bad. After trying those things, it's going to take someone to service and analize the problem, which can be a lot of things. Get an estimate first before getting it serviced. The cost of repair often exceeds the cost of a new unit..
Mar 23, 2010 | Sony D-EJ011 Personal CD Player
Purchased a car plug for player. message "Hi dc in" comes on scrren and cd will not turn.
I suspect the message means the input voltage is too high to safely run the motor and control circuits. You'll probably need to replace the adapter with a lower-voltage model.
If this car adapter is the manufacturer's own version made for the player, take it back to the store. If the adapter is a generic one, you'll need to find one closer to the player's voltage requirement.
Mar 08, 2010 | Sony D-EJ011 Personal CD Player
Sony D-EJ011 Personal CD Player Logo
23 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
