Question about Honeywell Programmable Thermostat Heater
Installing Honeywell RTH7000 - I have too many wires!
I am replacing a Honeywell dial thermostat from 1995 on a gas fired forced air system with an airconditioning unit attached, with a Honeywell RTH7000 programmable thermostat. The house has two zones and I am only replacing the thermostat on the first floor. When I removed the old thermostat I have 6 wires - R-red, Y-blue, G-green, B-black, W-white, O-brown. The manual does not show where an O wire is connected. The old thermostat has a fan setting for On - Off and Auto on one side and on the other side it is Heat Off Cool. Any help would be appreciated!
  • MegBarnes Oct 26, 2008
    Thanks, I'll try connecting it that way and see what happens!
    Sergeant:
  • 359 Answers
Check to see if the B terminal is on the new t-stat if connect to it , but this terminal refers to heat pumps and is normally use to energize the reversing valve on the outside unit and not used on ac units , but normally the tag O/B is the same terminal on therostats
Posted on Oct 26, 2008
No digital read out from Honeywell digital thermostat and no heat from oil fired forced air furnace
Check/replace the batteries in the thermostat. They last about a year, and it won't work without.
Dec 14, 2016 | Heating & Cooling
I have a red and a white wire only. I am installing a honeywell thermastat rth111. The heater is an electric air forced one. Where do I connect the wires?
These are not enough for you to install this thermostat properly. You could try hooking red to R and white to W2/E, but an electric furnace requires 4 wires for modern thermostats to run properly. If there are more wires in the line then it's a fairly easy task for a technician to add proper connections in, if not a new thermostat wire will need to be put in place.
Sep 25, 2011 | Honeywell Programmable Thermostat Heater
Three wires not marked for new Thermostat!
You will need to go to the heating system and see what color wires are hooked to that. Typically the black and white wires will be used unless they used another color due to a bad wire. Hook the colored wires to the R or RH terminal on the thermostat and the other wire to the W terminal. You can also try taking the wires you have and one by one twisting them together and have a second person inform you when the heating system turns on. Take those two wires and hook them to the terminals I mentioned above.
Jan 14, 2010 | Honeywell Programmable Thermostat Heater
RTH7000 thermostat won't maintain the heat I've
if the thermostat is wired correctly, your problem is likely in your furnace.
My first guess would be a faulty limit switch, but without seeing your furnace, it would be hard to say.
Have a qualified service person look it over... It would likely be a good time to have it cleaned and tuned also (once per year is best, or every other year reduces your chances having problems)
Jan 03, 2010 | Honeywell Programmable Thermostat Heater
I had an old two wire system, red and white. gas
Check for a bad thermostat and wire by jumping the red and white wire together at the thermostat. If the unit fires, you have a bad thermostat. If it does not, jump the R and W terminals at the furnace (or where ever the thermostat wires are connected to). If the unit fires you have a bad wire. If it still does not fire, you have an issue with the heating system not the thermostat or its wires.
Dec 06, 2009 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
417 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
