Question about Samsung Televison & Video
SAMSUNG AV-R610. When turning on displays a HeadPhone Mode and no audio is heard in speakers. Can somebody help me with the solution..?? TKs..
No sound in speakers... It displays that the receiver is in HP (HeadPhone Mode)...
likha
  • 790 Answers
SOURCE: Sound Problem
ok paola! the problem is the headphone connector inside the TV.. maybe did not turn back the switch to speaker mode. check the headphone connector (at inside the tv). small problem goodluck paola!!!
Posted on Sep 14, 2007
SOURCE: has a high tone sound (about 3KHz) from speaker after power on. The sound level decrease and become to disappear after half an hour warn up.The problem occured at both TV and AV modes. At AV mode, it
there is a problem with audio section there may be failure of transistor/capacitor
Posted on May 24, 2009
Th3_uN1Qu3
  • 47 Answers
SOURCE: Using different speakers for TV
If it does not have anything besides optical it will not work unless you have a system capable of optical input (some Logitechs have it, but don't remember which ones, i know that the Z-5500 does certainly have it but that's not too cheap).
Weird that it doesn't have a a headphone jack indeed. But if it doesn't, that optical digital out is the only way to connect it.
Posted on Jul 02, 2009
  • 1039 Answers
SOURCE: samsung ps50c96hdx.headphone symbol appeared on
Bad headphone jack in tv. Switch in jack is making contact.
Posted on Sep 02, 2009
  • 11 Answers
SOURCE: headphone jack fault on 32" samsung TV
I don't know about replacing a jack but BN94-01208C fits LNT1953HX is the main pcb that has all of the av inputs on it and it is a snap to change.
Posted on Mar 09, 2010
AV-R730 stuck in headphone mode?
Try a quick blast of compressed air into the headphone jack area. Worked great for me.
Apr 14, 2013 | Samsung Av-r730 A/v Surround Receiver...
How to find JVC AV27320 headphone jack? I've plugged into the avs(red & white) in the front panel as well as the extra ones in the back. Altho - I CAN hear the sound thru the headphones, The external...
This model doesn't have a headphone jack. The only JVC TV in the series that does is the model AV-20D202. For the JVC AV-2732, use the RCA audio out jacks with an RCA to 3.5 mm adapter to connect to the headphones. The front audio jacks are audio in (for the audio from a video camera for example).
When you use any external speakers or headphones through the audio out jacks, make sure to turn off the TV speakers. Press Menu and navigate down to TV Speakers (up/down arrows). Then use the right/left arrows to select Off and then Exit the menu. Make sure you scroll the TV volume before doing this. Note: if your headphones do not have a volume control they are a bad choice for this type of audio output.
You can find the manual for the TV here: http://books.jvc.com/booklist.asp?Model=AV-27230 .
I wish that I had better news for you.
Jan 06, 2011 | JVC AV-27320 27" TV
Sony's STR-DE675 5.1 Channel Receiver - Speaker OFF problem
There's a button that turns the speakers OFF right above the headphone jack.
Get the manual: retrevo.com
May 21, 2010 | Sony STR-DE675 Receiver
When audio jack is plugged into mac a high pitch whine is heard across speaker system
I'm thinking it could be a feedback loop. Maybe for some reason when you plug in the headphones it does not turn off the speakers but ramps up the mircophone. Clean you your jack to make sure it detects the headphone plug right and turns off the speakers. If that doesn't help you may have a logic board issue. If you want to replace it yourself, Here is an Macbook Repair Guide that shows how to open a Macbook. If you want somebody else to do it for you go to Macbook Repair.
Jan 07, 2010 | Apple MacBook Air
Jul 02, 2009 | Televison & Video
My sony dav-s-400 system keeps activating headphone port output.
Just had and fixed the same problem that hundreds of people are suffering with this system!!
Sony DAV s400 - same problem, won't play though speakers and display indicates that headphones are plugged in - when they are not. Fairly easy to fix and took me less than an hour from start to finish:
1) Remove top cover
2) Remove circuit board that has Audio In/Out phono scockets (to get access to Amplifier Circuit Board)
3) Remove Amplifier circuit board (has the speakers attached)
4) Turn it over and remove copper heat shield
5) Resolder joints where the big brown capacitor is and where the wires go to the front headphone socket...and any other dodgy joints that you find
6) Reassemble.
Feb 03, 2009 | Sony DAV-S400 System
Samsung av-r610 av receiver. noisy cooling fan. can it be replaced with a quieter/more efficient one?
Hi i have same unit. If you keep the volume anywhere below 31 the fan is not intrusive (you can hear a quiet hum but not a bother) I also give it plent of ventilation ie 1 foot at back and a little less to the sides. The problem is the unit is so slim the fan has to work harder to dissipate the heat build up.
Oct 08, 2008 | Samsung Audio Players & Recorders
Nakamichi AV-7 5.1
in this case the centre speakers are the main route to the sound. 5.1 is for movies, where the centre speaer takes predcedence.
Aug 29, 2008 | Nakamichi AV-7 Receiver
No sound when on pc mode
Check if your PC can play audio on some other speakers or headphone. If yes, check your monitor audio cable connections. If no something's wrong with your PC audio drivers. Try re-installing them or could be a hardware issue with your PC. Get it checked.
Sep 29, 2007 | Samsung SyncMaster 940MW 19" LCD Monitor
Sound Problem
Sep 14, 2007 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
32 people viewed this question
Henry  Thomas
Henry Thomas
