Question about Kitchen Ranges
Whirlpool 28" drop-in stove replacement
I have a 28" Whirlpool drop-in stove that needs to be replaced. The problem is the opening between the cabinets is only 28 1/4 inches. I have not been able to find a replacement stove. There is enough cabinet wall to cut, but that seems to be a professionals job and not mine. Am I correct or is there a better solution? I tried runnng the model number on the internet, but I think the stove is to old (20 yrs). Help!!
  • hal2954 Apr 28, 2009
    We have a Kenmore drop in 28" gas stove.
    Same problem as Rstegall311's. Don't want to cut the cabinet.
    Also afraid of ruining the floor.
    Any suggestions? Tired of using my toaster oven!
  • ob1_2269 May 23, 2009
    Same problem, need replacement for 28" drop in kitchen range. Any help would be greatly appreciated..
    Ron May 09
  • 943 Answers
SOURCE: installation of kitchenaid range - KGSS907SSS
hi every stove that i have worked on and believe me that's a few and all gas or electric were all right up against the counter tops with no space at all so i would install the cabinets thanks please a positive feed back and accept please the appliance doc
Posted on Sep 23, 2008
  • 9098 Answers
SOURCE: GE Spacemaker Microwave Oven
You can download GE owner's manuals and installation instructions here.
Posted on Aug 18, 2008
  • 93 Answers
SOURCE: re-ignition when cabinet below doors open/close
Seal all holes on the underside of cooktop. This is called the burner box. Seal all openings with aluminum tape. This should stop the back draft effect.
Posted on Oct 29, 2008
  • 530 Answers
SOURCE: opening top of cabinet
you have to use a putty knife. It is a pain in the neck. there are two clips where the top of the cabinet is there is a slot you can see the clip if you use a flashlight push theputty knife in and pull up. Then do the other side. They are directly in the frontt of the unit
Posted on Jan 04, 2009
  • 1214 Answers
SOURCE: wall mounting needed for a top mount microwave/hood combination
Is there a wall behind where the microwave is to fit?
Most of these ship with a mounting plate and instructions for mounting to the wall. In fact, the wall bracket carries about 1/2 the weight, and the overhead cabinets carry the other half. The plates come with a good set of instructions for how to install.
Whirlpool is sending you to a distributor because they have to watch liability in this litigous world we live in..
Posted on Jan 29, 2009
I have a Whirlpool drop in stove. I had food in the oven baking and all of a sudden the timer started going off. F-1 was displayed on the front of the stove. Can you tell mean what F-1 means?
F1 - Control Board Failure - Replace control board (clock).
F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. ...
F3 - Open Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
F4 - Shorted Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
Whirlpool Google Search
Dec 15, 2016 | Whirlpool Ovens
I have a loc message on my whirlpool stove. The oven works but the stove top won't ignite.
double problem burners spark box or control switches or just one of them oven door lock is not open all the way for oven may need replacement
Oct 23, 2016 | Whirlpool Kitchen Ranges
Bottom oven drop drops down when open
not sure what you mean
but do you have the anti tip bracket installed?
it keeps stove from tipping forward when door is opened
connects to wall and stove leg or adjuster
Jan 03, 2015 | Whirlpool RBD305PD Electric Double Oven
Where can I find an electric range with depth less than 28 inches
Bertha, most stoves are going to be anywhere from 26" deep to 29" deep. Most any stove that I have used or worked on has never been a counter depth stove unless it was a slide in or a drop in stove. When I went to GE's website, I did not many stoves that were less than 28" deep until I got up to $1000 in retail pricing. The only one under that price that was less than 28" was also only 24" in width. Hope this helps!
Dec 08, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Stove top works oven wont heat on 465
the ignitor needs replacing, that's the glow that you see. it's not getting hot enough to open the safety valve.
Dec 07, 2008 | Whirlpool GS460 Gas Kitchen Range
Whirlpool gold stove (wd sensor open)
on my stove i pushed the lock button for my oven now it want unlock. it is like it is froze up, it want let me cook or anything
Oct 04, 2008 | Whirlpool GY396 Electric Kitchen Range
Whirlpool accubake oven troubleshooting
electric oven heats to correcect temp then drops and does not get back too appropriate temp. For example, set at 400, gets there then drops to 275-300
Dec 18, 2007 | Ovens
Whirlpool glass top stove
The glass top can be change, but be aware that if you have all your cooking element fixed togetter, this could cost plenty of $$$. If your heating element can be remove easyly, you are a lucky owner.
Dec 10, 2007 | Whirlpool ED2FHEXN Side by Side...
Kitchen Ranges Logo
1,573 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
