Question about Health & Beauty
Rascal power chair runs backwards.
When you are setting in chair the joystick has to be pulled back to go forward.what can i chek for this problem?
  • Agrajag May 11, 2010
    Does it run forward if the seat is swung around the other way?  If so your seat position switch has likely got a wire loose, or the switch is bad(very rare).
    Problem Solver:
  • 17 Answers
Check your controller program using PP1programmable for PG drive controller ( VSI,VR2,and Pilot+) or using Dynamic wizard for Dynamic Controller (DX,DL,Commando,SHARK, and RHINO)
Regards,
mas Didiet
Posted on Nov 13, 2008
I have to push joystick back to go forward. An forward to go back. Much faster in reverse too
if you look under the seat and see that there are little black switches, one of them maybe broken. if there are no switches on the seat post. then your joystick thinks you are a front wheel drive instead of a rear wheel drive chair. Someone with a programmer can reverse this. get ahold of these people at this link I give you to find a technician close to you.1-800-257-7955 or Mobility Parts and Service Official Rascal Parts Supplier
or http://www.meritsusa.com/
May 02, 2016 | Rascal 318 Electric Scooter
How to unlock Jazzy Select chair so it can start up and run
Turn on the PWC
Push the joystick forward and hold for 2 seconds or until you hear a chirp.
Push the joystick backward and hold for 2 seconds or until you hear a chirp.
Release and there should be a long beep tone, signaling that it is unlocked. Since there are different joystick controllers on these chairs and I don't know exactly which one you have this is my best guess.
Dec 20, 2015 | Pride Mobility Products Jazzy Select
How do you reset the chair when all the lights are flashing?
Hand control is locked. turn chair on push joy stick forward til it beeps then pull it back until it beeps then put it in neutral ( joy stick in the center) then it should be unlocked.
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
May 30, 2014 | Pride Jazzy 1103 Ultra Standard Power...
What does my tss300 power indicater keep flashing left to right but won't move. batteries are fully charged and reset is set?
The chair is more than likely in free wheel. There are two levers under front of the seat (yellow). Pulling them forward should place the chair in freewheel and pushing the levers back should place the chair in drive. Once in drive mode, turn power on to reset joystick.
Apr 27, 2014 | Pride Mobility Pride TSS300 Power Chair -...
I have a Quickie S646SE wheelchair with a Qtronics Pilot+ romote controller. I charged the chair last night. When I turned it on today the profile lights scroll left to right and the chair does not move. I...
Press and hold power button til beep then push joystick forward and hold joystick til beep then pull the joystick back and hold joystick til beeps. turn power off then on. should be unlocked now
Mar 17, 2014 | Quickie Wheelchairs Quickie S-646 Power...
Rebuilt motor installed in Pronto m50 power chair, now joystick forward, takes chair to right, joystick right takes chair forward, joystick to left, taks chair back, joystick back takes chair left, HELP
u need a programer o reset that joystick to the new motor,so call the dealer have them send out a qualified tech with a programer to check error codes and reprogram
Sep 26, 2013 | Health & Beauty
How do i reset a jet 7 mobile wheelchair
did you put it in lockout accidentally? try this! turn off chair, press and hold the on button till a beep is heard, push and hold the joystick forward till a beep is heard, then pull back and hold joystick till beep is heard, turn off, and turn on. it should work now?
Sep 04, 2012 | Jet 7 Portable Power Chair
The charge indicator lights flash left to right..when moving joystick the chair does not move.
chair is locked out. turn on then push joystick forward till it beeps then pull backward till it beeps then it is unlocked
Jun 15, 2010 | Invacare Pronto M51 Power Wheelchair
Won't move forward or reverse. all other
Sounds like your joystick is damaged. This chair probably has a PG Drives Technology joystick that serves as both the joystick control and acts as the power control module. If it has been damaged by say, running into a wall or doorway or table, this can be the cause, or if it has gotten moisture inside it, that will hurt it as well. Other possibilities are overloading the chair past its weight capacity or driving it over unstable terrain like sand, gravel, much etc.
Aug 28, 2009 | Pride Mobility Products Health & Beauty
Health & Beauty Logo
493 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
