How to reset lamp hour meter in Samsung Projector SP-D400
SOURCE: lg llp xg22 lamp reset
These instructions are taken from page 44 of the User Guide.
Turn the power off but keep pluged in. Press the buttons on the control panel in the sequence as below.
Press "Up Arrow", Press "Down Arrow", Press "Left Arrow", Press "Right Arrow", Press "Menu", Press "Enter".
Lamp time will be initialized
Posted on Mar 01, 2008
Marrie
  • 563 Answers
SOURCE: RESET LAMP HOURS
Hi Greg147
The resetting is not done in the menu.
Plug in your power cable - Machine is now in standby mode.
Then Hold down the left and right arrow keys on the Projector and press the power button. You'll see a indicator light on top of the Projector flashing twice - Lamp hours is now reset.
Hope this is of help.
Posted on Apr 01, 2008
  • 3 Answers
SOURCE: Reset Lamp Hours Timer
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "VOLUM -" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
This works for Toshiba TDP T-9
Posted on Jul 11, 2008
SOURCE: Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
Posted on Feb 25, 2009
projdoc
  • 2237 Answers
SOURCE: Cannot Reset Infocus LP 350 Projector after replacing a bad lamp
that model has a history of bad ballasts. you'll need to replace it.
Posted on Mar 09, 2010
Testimonial: "Of all the comments on lamps failing to power up, only this answer fits my circumstances. I eliminated other "solutions" posted on FixYa. Thanks!"
How do i reset lamp hours on samsung SP-L220
Hello
There is no explanation given with its user manaul aboug the lamp reset process. Just contact the authorised service center for Samaung at your town. They will reset the lamp hour. OK.
Oct 11, 2011 | Samsung SPL220 Projector
Replaced XD300U projector lamp. Need to know how to reset lamp timer. Won,t turn on because lamp timer has expired to 0. Needs to be reset. Lost our manual. Please help.
"Reset the lamp counter
i. Press and hold Exit on the projector
for 3 seconds to display the total used
lamp time.
ii. Press Menu on the projector or on
the remote control to access the lamp
hour timer. An adjustment message
will appear.
iii. Press or to reset lamp hours
and press EXIT to leave."
Apr 21, 2008 | Televison & Video
How to reset lamp hours lt265 nec
Select the Menu [Reset] → [Clear Lamp Hour Meter] to clear the Remaining Lamp Time and the Lamp Hour Meter
Mar 05, 2011 | NEC LT265 Multimedia Projector
We have a samsung SP-a400B DLP Projector which we need to set the lamp hours to Zero following a lamp change. How do you reset the lamp usage hours to Zero ?
Not a good idea. It is better to just use a tab for the new installation. Hourly usage is not an exact science and the lamp life is approximated based upon tests. The true life of the system with the tab of the time and date of replacement is much better suited for a technician...
Jun 10, 2010 | Televison & Video
Replaced the bulb yesterday- the projector does not recognize the change- getting a default message to change it... And there is a strange smell (we also changed the filter (after 5 yrs)
copied from manual
select the menu - default - clear lamp hour meter to reset lamp usage hours.
Note when the lamp exceeds 2100 hours (3100 in Eco mode) the projector cannot turn on and the menu is not displayed if this happens do the following while in 'standby' to clear values for Remaing lamp Time and lamp hour meter for vt670/470 press the help button on remote control for a minimum of 10 secs When the lamp clock is reset to zero the lamp indicator goes out.
May 14, 2010 | NEC Replacment Lamp Projector Lamp for...
Lamp burned out on X1 infocus projector, Replaced lamp, new lamp stopped working in about 5 hours, got another new lamp and it does not light at all. Still blinking 3 red blinks(saying the bulb is bad)
make sure the colorwheel is spinning. if it is not, replace it. also, blow the dust out of it with canned air. excessive dust kills lamps quickly. you'll also need to reset the lamp timer. are you using an sp-lamp-009? the sp-lamp-018 looks exactly like it, but is used in th x1a and x2. the x1 only uses the sp-lamp-009. if all else fails, replace the power supply.
Jan 08, 2010 | InFocus X1 Multimedia Projector
The Lamp won't strike
if the inside of the lamp has bulges, black spots or fogging, replace the lamp. otherwise, if you have a dlp projector, it may be the colorwheel or the ballast. if you have an lcd projector, it may be the ballast.
Dec 21, 2009 | InFocus In Focus SP-LAMP-021 Replacement...
How to check for lamp life of my mitsubishi multimedia Projector xd 450u (DLP)
This should work:
How to reset the operation time meter
Plug in the power cord, switch on the projector, and
reset lamp time by pressing the (left and right arrow) and POWER buttons on the control panel simultaneously.
Important:
• If the 3 buttons was not pressed at the same time,
the lamp time may not be reset.
• Please confirm the TEMP indicator illuminates
about 2 seconds and the lamp time has been
reset.
• The projector will not turn on if you do not secure
the lamp lid.
• You must reset the operation time meter after you
replace the lamp.
• Do not reset the operation time meter unless the
lamp has been replaced.
Jul 14, 2008 | Office Equipment & Supplies
Replacing bulb
hold the volume up/down in ,switch unit on while holding these in for 30 secs, if that fails, flash unit with new software.
Dec 01, 2007 | InFocus In Focus SP-LAMP-021 Replacement...
513 people viewed this question
k24674
jasbo
jasbo
