Trane split type air condition show E4 - Heating & Cooling
SOURCE: remonte controls for Hisense air condition
hi , you can bring a universal remote and this one can work for many air conditions look at the codes for the kind of ac.
Posted on Mar 04, 2010
InMrFixIt
  • 121 Answers
SOURCE: e4 in an innovair a/c
Hi! jorget67
Sound like the compressor overload is tripped. Make sure the condenser is clean then reset the breaker on this circuit.
Sincerely, InMrFixIt
Posted on Jan 12, 2009
  • 14 Answers
SOURCE: trane split air conditioning -XIL 14 MODEL- no
shot of freon or loose signal wire between condenser and wall unit
Posted on Sep 03, 2009
toy_ladi
  • 484 Answers
SOURCE: i have waves split air condition its cooling is
The e4 that displays on your air condition come up simply because there is an error during the operation of the system. E4 means Error 4 which is a code that is interpreted as low pressure switch.
E4 simply means there is low pressure switch, the pressure switch turns on automatically inside the air condition, so when you turn it on sometimes the switch jams and does not open so the air condition will be on but would not get cold because the switch jammed and it displays an error signal to let you know there is a problem in the system.
Take care
Posted on Jul 09, 2010
hvac1960
  • 2133 Answers
SOURCE: Yonan Split Air Conditioning System
F6
ambient temp.
sensor of outdoor
fault
1?Check whether the resistance of sensor is normal,
otherwise replace it.
2?Check whether the sensor wire is short circuit or open
circuit, and whether the plug is well contacted, whether
there is welding off or rosin joint on the electric control
board, repair it if there is any above.
3?When the 1 and 2 are both normal, then the components
or integrated circuit is damaged, the electric control
board should be replaced.
Posted on Dec 02, 2010
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Error e4 sir air split unit
We have a SirAir Split unit Airconditioner, It's not cooling and shows e4 error.
Feb 27, 2013 | Heating & Cooling
I have waves split air condition its cooling is good but some time in the display e4 is coming and that time my ac is not giving cold air what is this.tell me some one.
Take care
Jul 09, 2010 | Heating & Cooling
My unit fan not working and show E4, what this means
The E - 4 error code means the system is low on refrigerant type: (R-410A)
Jun 12, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
We were getting an E4 but now we get an E2 but
I do know that the owners manual should show you what each and every code means? Some times the manufacture will paste a strip located on the panel of the indoor unit showing what each code means. If not, I would contact the factory on this. I know on Bryant, Mitsubishi splits, Day and night, (Bryants), Tranes, Lennox and most all others, do show in the manual and on the unit behind the panel. Try looking for them there.
Sincerely, shastalaker7
Oct 19, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Panasonic Split System Air Conditioning.
we have a old national air con cassette model cu-5chv11p , works for three days , then controller comes on e4 error ,and then switches off , and will not reset .
Dec 28, 2007 | Heating & Cooling
Heating & Cooling Logo
745 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
