Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Saeco vienna plus brew group is jammed and wont come out
  • 1089 Answers
SOURCE: need to take out brew group jammed
Hi
Look on the left side where the box should be. In the left side towards the botton there is a long opening. Take plastic knife and slide it in while the machine is on and blinking and see if the brew unit will cycle. The drip tray has to be in for this to work. There is a metal bar that has to be pushed toward the rear of the machine to cycle the brew unit.
Posted on May 22, 2009
WaltK
SOURCE: Saeco Vienna gear jammed
This has happened to me. If the problem is the brew group gear is in the wrong position, you can manipulate the brew group until it matches up with the drive gear in the machine. You'll know it matches if you can insert the brew group back in the machine full until it clicks.
Posted on Dec 08, 2007
  • 40 Answers
SOURCE: Saeco Vienna Digital Expresso Maker - brew group will not line up to fit back into espresso machine
Could be a number of reasons. If you "hear" the brew group moving in one direction, stop and then move again, then the microswitches are o.k. If the sound of the movement is low and/or slow ( slower that normal), the CPU/power board may be bad and needs to be replace. If the movement is as before (same sound and movement) but not lining up, perhaps the brew drive motor is bad.
To remedy this situation, an authorized SAECO Service Center would have to open your machine and replace damaged components. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 19, 2008
  • 1089 Answers
SOURCE: saeco vienna saying brewunit blocked !
Hi There is a test mode for the Digital and we can see if you have a bad power board. Turn the machine off in back. Push and hold the small coffee button and the menu button (top left) at the same time and while you are holding the buttons turn the machine on. Release the buttons and you should have numbers in the display. If you can push the bottom left button and the machine makes a sound like the motor is moving, turn it off and then back on. If you don't get the message now you should really clean and lube your brew unit.
Posted on Jun 09, 2009
  • 18 Answers
SOURCE: cannot release the brew group for, saeco
Group is stuck in mid cycle due to some obstruction. You will need to have it serviced. Though it's possible to jiggle and pull it out. The machine will not likely reset itself, preventing you from re-inserting the group. Still requires a service to manually remove obstruction and reset it.
Posted on Feb 10, 2010
Leaking saeco plus vienna machine
I have had a similar problem. Don't know whether it was the same. Take out the brew group and low behind that is a V-shaped opening, with a small mouth pointing towards the front of the macine.
Take a large paperclip and open this small outlet. Then clean with a wet cloth the V-shaped opening behind it.
Thus MY problem was solved.
From your info it would seem that you already tried this.
Good luck! Bob Hempenius.
Apr 01, 2014 | Saeco Vienna Espresso Machine
Saeco Vienna grinds too much coffee.
Hi
If you have the Delux or Digital there are 2 knobs in the bean hopper. Turn the small knob back 1 mark and see if that will help.
Jul 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Need to take out brew group jammed
Hi
Apr 23, 2009 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna deluxe brew group was jammed
If you have the box the machine came in there is a key that kinda looks like a wine opener, use that to set the little arrow on the brew unit to the "N" letter, then the unit will fit into the machine.
Dec 26, 2008 | Saeco Vienna Digital Coffee Maker,...
Saeco Vienna delux
The brew group is out of place.
--> --> The brew group cannot be taken out.
--> --> Turn on the machine and close the service door. The brew group will automatically go back into place.
The brew group is out of place -Turn on the machine and close the service door. The brew group will automatically go back into place.
May 07, 2008 | Saeco Vienna Deluxe
Feb 18, 2008 | Saeco Vienna Digital Coffee Maker,...
Saeco Vienna wont turn on
dont worry if it was working good before the clean up the brew group is not install all the way in remove it push it in untill you here a click the brew group is not all the way in and doesnt push the on switch when you push it in wiggle it
THANKS FOR USING FIXYA
PIERRE
Feb 17, 2008 | Saeco Vienna Espresso Machine
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
803 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
