Question about Cadence Z8000 Car Audio Amplifier
Sub cuts out
Whenever i turn my car on and the stereo is at a low volume the sub works fine but as soon as i turn the stereo up even a little bit the sub completely cuts out. im guessing its something in the amp but i have no idea what!
thanks for the help!!
  • 631 Answers
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, the sub may be damaged. You'll need to measure the resistanace of the voice coil. It shouldn't read less than ~85% of the rated impedance.
Posted on Oct 26, 2008
When i have the stereo on radio my amp/subs work fine, but as soon as i switch the mode to USB ( built in ipod connector) it cuts out the power to the amp/subs. It only works on tuner mode (radio) why?
use the blue/white wire (amplifier remote turn on) instead of the blue wire (power antenna remote turn on) to turn your amp on. the power antenna wire shuts off when leaving tuner mode.
Mar 02, 2011 | Sony DSX-S100 Car CD/ MP3 Player
1000 w sony xplode works at low volume then red lights at volume5
Most likely one of your subs are blown, or the Ohm's are too low for the ampliphier. Try hooking up one speaker at a time to the amp and see if it does the same thing. If it shuts off on one of the two speakers, that speaker is most likely blown.
Apr 19, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Ive got no power to the amp trough the rem wire unless i connect.
You need a bigger amp and make sure its a two channel. Four and five channel amps are for mids and highs. If you want real bass get a two channel. If you dont want to buy a bigger amp, Go get a capacitor. It acts like a battery charge storage for when your sub needs to hit those real low notes. It takes a lot of power. Also if you get a capacitor your altinater that charges your battery will not have to work so hard keeping your battery charged, Thus not wearing out your altinater and not having to replace it so soon because it will happen.
Another quick fix is turning your gain down. I turn my gain up half way, maybe a little past half way. You might not get the bass hitting as hard but at least it wont shut off on you.
Nov 20, 2008 | Kicker 01C8VR4 Car Subwoofer
Amp not functioning right
Check the wires for a lose connection or corrosion. You may need a capacitor.
Basically, at low power the amplifier is not asking for a lot of power from the electrical system to power your sub woofer. For lack of a better term and probably the best way to explain it is. It uses up all the power in the wires leading to it at a high volume, and has to wait for more. Kind of like when someone squeezes a garden hose2_bing.gif when your trying to use it. That would be the high volume, starving the amplifier. The capacitor stores power in it to power the amp at high volume. 2 farads would probably be bulletproof on a single amplifier system, but 1 farad should work well enough. Or seek help from an expert on exactly what size capacitor you should use. If you find yourself saying: My amp cuts out.
If this assisted in solving your problem, please take the time to rate it. Thank you.
Oct 08, 2008 | Jl Audio 500/1 Car Audio Amplifier
Gigaworks S750 Sub - Pops and Cuts Out
There is obviously a problem on the amp board with 3 STA575 amplifiers. It may be that one of the diodes is shorted or one of the capacitors has dried up or shorted. For more information I have posted a link to a forum thread that contains all of the information you would need to fix the Gigaworks S750 system. If the information has not already been posted there then you can ask on there and the people there will point you in the right direction.
http://forums.creative.com/creativelabs/board/message?board.id=speakers&thread.id=8037&view=by_date_ascending&page=1
Aug 17, 2008 | Creative Labs Gigaworks S750 Computer...
HELP STEREO CUTS OUT!
ok , ive found the problem with mine. I checked the voltage between the earth wire on the head unit and the battery in the car. I found that when i turned the headunit up to around 17-20 there was up to 3volts differance, which is when it would cut out. So ive run a new earth wire and she's all sweet . Even the cd player works now.
Aug 11, 2008 | JVC AM FM CD DET FACE CAR STEREO
SUBS
Hi , you need to replace with thick wire , if possible attache fuse or circuit trip overload protection you may ask to thew radio store .
May 07, 2008 | Polk Audio EX12 Car Speaker
Intermittent Subwoofer
the wire from the coil to post is probably severed.you might have to take the dust cap off..
http://www.mwaspeakerparts.com/
this is a speaker part site
Jan 13, 2008 | Kicker CVR12 Car Subwoofer
Subwoofer works at high volume, doesnt work at low volume
You had the settings set incorrectly and overdrove it. The voice coil leads are burn't open. If you look at the little flexible braids by the terminals I'll bet they are black/brown and maybe even burn't in half. It's toast.
Sep 17, 2007 | Kicker 02S10L74 Car Subwoofer
Cadence Z8000 Car Audio Amplifier Logo
524 people viewed this question
Top Cadence Car Audio & Video Experts
xxxxxx xxx
Are you a Cadence Car Audio and Video Expert? Answer questions, earn points and help others
