Sir my laptop screen is suddenly gone black.in this black screen i get the message NTLDR is missing Press any Key to restart.i did that but not open my laptop. how can i solve this problem?
SOURCE: im using dell inspiron 1525
Hi Friends,
Problem with Dell Laptops?
For solutions for your problem you need to visit a site by just Click Here .
For any hardware problem with Dell Laptop you can Click Here
SOURCE: NTLDR is missing. Say's to restart, just goes back
folow this link
http://support.microsoft.com/kb/320397
SOURCE: missing NTLDR file
The first thing to do is try to change back whatever hardware or software change you just made (this could be as simple as leaving a floppy disk in the drive or you need to reseat the IDE cables). If the contents of the drive are especially important and you have no backups, I would recommend removing the hard drive, placing in an enclosure, and backing up the data first, in fact, backup all of your computers. (What if I made new changes that I want to keep?).
Make a NTLDR boot disk to get back into Windows.
The quick test to make sure your OS installation is still good is to create an MBR and NTLDR on a floppy disk and check if you can just boot back up into your system, this disk will check many of the partitions for a working windows installation. Here are the instructions to do this:
1. Get a blank floppy/cd-r/usb (whatever is on it will be erased), and put it into a working computer.
2. If you have a working Windows machine download my fix: Floppy fixntldr.exe | CD-R fixntldriso.zip | USB ntldrusb.zip onto a working computer (Backup copies of these files available at http://ntldrismissing.com )
(What if I don't want to download a file from a website I don't trust?). (64 bit WinXP Floppy 64ntflop.exe | CD-R 64ntiso.zip | Files 64ntfile.zip)
Do you remember if the broken computers had the Windows installation in "Windows"? If you can't remember just keep going (What if it was not named Windows but WINNT like in NT4 or 2000?) .
(If your backup system is NT4 or Windows 2000: What if my backup system is Mac / Linux or another alt OS?).
3. Make the new boot disk:
*Floppy: Run the fixntldr.exe file by double clicking it. Click OK to overwrite the blank floppy disc in the working computer, you should see some screens about writing a new floppy disk. (If you don't like running an exe from me, you can run fixntldr_RawRite.zip and just replace the RawRite.exe file inside with one you trust) (now go to step 4)
*CD-R: This is not a normal file you burn to a CD, it is an "ISO" file, you must first extract the fixntldriso.zip file by right clicking it and choosing "Extract All" then Next>Next>Finish then download a program called "ISO Recorder" from here http://isorecorder.alexfeinman.com/isorecorder.htm (Windows 2000 users use Active ISO Burner IsoBurner-Setup.exe) and install it. Once it's installed, right click the fixntldr.iso file and choose to "Copy image to CD" or "Burn ISO file" and let it burn the cd (now go to step 4)
*USB: Right click the ntldrusb.zip file and choose "Extract All" Next>Next>Finish
Then Insert your USB Stick into the working computer (remove any other USB sticks, and be sure there isn't anything on the USB stick that you want since we are about to erase it);
Double-click HPUSBFW.EXE in the ntldrusb folder;
Check "Create a DOS startup disk" and "using DOS system files located at" then press the grey button with the "...";
A box will come up asking you which folder to select, point it to the "dos system files" folder;
Press OK; Press Start; Press Yes; Let it run for just a few minutes till a new box comes up; Press OK; Press Close;
Open the "putonusb" folder, copy all the files, paste them onto the usb stick (just in the root of the drive, like E:\);
Eject the USB Stick; Remove it from your computer;
Place it into the computer with the "NTLDR is missing" issue, reboot it.
You will see the Windows 98 screen pop up for a second, then you will see a black screen with white letters prompting you to "replace boot sector of the drive C: (y/n)", press the y key;
It will go to a C:\ prompt, reboot the computer by pressing Ctrl+Alt+Del; (now go to step 4)
4. Put the new floppy/cd-r/usb you have just created into the computer that gets the NTLDR is missing error message, turn the broken computer off.
Using the boot disk in the computer with the "NTLDR is missing" error.
Start back up the broken computer with the floppy/cd-r/usb inside it/plugged into it. Once your computer gets past the BIOS screen your computer should try to access the boot disk and you should see a black screen with white letters (What if I don't see this screen?). that says:
Try it first, if it was the wrong selection, you will likely get one of these four errors:
1. Windows could not start because file "<Windows Root>\system32\hal.dll was missing or corrupt
2. Windows could not start because of a computer disk hardware configuration problem. Could not read from the selected boot disk. Check boot path and disk hardware. Please check the Windows documentation about hardware disk configuration and your hardware reference manuals for additional information.
3. I/O Error accessing boot sector file multi(0)disk(0)fdisk(0)\BOOTSECT.DOS
4. Immediate reboot
If you get the immediate reboot or some other weird error, try pressing F8 at the "1st Try This" selection screen, it will give you a prompt where you can select Safe Mode, and then try the "1st Try This" option again. Safe Mode is a special "minimal" version of Windows that doesn't load certain parts of the operating system that might have caused the problem.
One of the choices should eventually boot you back into Windows. (What if none of the options worked?) .
Use windows to fix the boot files on the hard drive.
If you got back into Windows, stop whatever you are doing and backup your most important information from this computer.
Now that you are done backing up the most important info, try to change back whatever you were last doing and boot normally, it that doesn't work, put the floppy back into the broken computer and double click the fixntldr.bat file on the floppy drive, if it asks you to overwrite a file, just type in y for yes (the file copies boot.ini, ntldr, ntdetect.com from the floppy to the C:\ drive and removes the read only attributes). That process take a few minutes, then remove the floppy and reboot.
If you are using the cd or usb solution, copy the boot.ini, ntldr, and ntdetect.com files to My Computer > Local Disk C:\ > and overwite whatever files might be there, then right click each file, choose properties, uncheck the Read Only attribute, and click OK.
If you get back into Windows again, you can change that "1st Try This" menu by going into Start > Control Panel > PerformanceAndMaintenance/System > Advanced tab > Startup and Recovery section, Settings button > System Startup; then change the "Default Operating System:" to the selection that worked for you, and change the box that says "Time to display list of operating systems" to however many seconds you want (usually 1 second). Click OK twice.
If you copy the file over and boot up and get a "NTLDR is compressed" error message, be sure to uncheck "compress contents to save space" on the hard drive.
SOURCE: NTLDR missing issue
copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
SOURCE: i get ntldr is missing on my netbook, help in simpliest of terms
Pressing Ctrl, Alt and Del just restarts the computer.
"ntldr" is a windows boot file which has become corrupt and unreadable causing the computer to loop on boot up.
As far as i know that laptop does not have a CD/DVD drive so you can't fix the problem unless you have a external CD/DVD drive and a recovery CD.
Is the netbook still under warranty? If so take advantage of that and send it in for Acer to deal with.
If not you will need a recovery CD or Windows install disk, an external hard drive and some patience.
If you need anymore help or advice please post back.
Good luck.
