Question about Neff B1641 Single circotherm super Electric Oven
How do I sepate the inside from the outside of a neff oven Bl641 door
There does not appear to be any screws to unlock the front from the back
Remove the oven door by flipping the hinge catches into their alternative position and lift the door out of the hinge slots (note it is somewhat heavy). Lie the door, outside face down and press down on the glass with both hands until it slides off the mounting pins at the base of the door body. Replacement is an exact reversal.
Posted on May 14, 2012
  • 1462 Answers
SOURCE: neff u1721 fan door problem
yes it is a heat resistant adhesive and ive never had any success in regluing them
Posted on Jul 06, 2008
SOURCE: neff oven door (U1661)
The door is v heavy and the hinges being right at the bottom take a lot of strain, especially when the door is in 'half open' position. Once the springs start to wear the hinges are no longer strong enough to hold the top of the door firmly closed. Our U1661 is 8 years old and we've had the hinges replaced twice under extended warranty. The second time the hinges they supplied don't hold the door in this position and it will just drop straight down if you don't support it while you open it.
Posted on Oct 20, 2008
  • 1462 Answers
SOURCE: Neff Oven Door Removed Incorrectly
you need to lock the hinges to get the door back.
it needs some strength
lay door flat on floor
force hinge against the spring until right back and put the locking arm over. i use my feet for this!
Posted on Nov 29, 2008
barkencoa
  • 3463 Answers
SOURCE: unable to remove the fan blade on the neff u1721 oven (too tight)
The nut is a left hand thread, so unscrew it clockwise to release it, hold fan blade as you are doing this. Tighten anti- clockwise.
Plz rate my solution.
Thanks.
Posted on Jan 11, 2009
barkencoa
  • 3463 Answers
SOURCE: after some serious cleaning the inside glass has fallen out. NEFF
It will not be tape as this could catch fire, it is a very high melting point sealant that is used to secure the glass in place.
You can find it for sale on the internet, look under sealants
Please rate my solution.
Thanks.
Posted on Nov 24, 2009
NEFF OVEN B1593. I have an oven neff b1593 and it's been locked.i don't how to unlock it.
Unplug the Oven from power for 5 minutes and see if it resets and the door unlocks.
Oct 24, 2016 | Neff Ovens
Oven door handle one side not attached to door other side loose
look around the outer edge of the door a few screws hold the 2 halves together caution do it on a flat surface as the glass can fall out .
Sep 01, 2016 | Neff Ovens
Taking apart a NEFF oven door
The inner door glass is held on by two clips at the bottom (hinge side) and two slides near the handle side. Remove the door from the oven and lie it the worktop flat with the hinges uppermost. Near the hinges you will see the glass is angles leaving a triangle of metal frame either side near the hinges.Rest the outside of your hand on the metal for purchase and then pull on the glass along the bottom edge (reasonable tug required) this will disengage the bottom clips and then slide the glass down about an inch to remove completely.
Mar 21, 2013 | Neff U1661 Double circotherm super...
My neff b1421 does not heat up and has left a "chalky dust" substance in the oven?
The dust is from where the ring element has blown. remove the back panel 4-6 torx 20 screws and the blow on the element should be pretty obvious, part no is 499003. can be replace from inside the unit, one screw on the right of the ring and two on the holding bracket. Obviously, isolate from mains, be careful when you remove the element at the bracket side, so as not to let the connection wires drop into the back cavity or you will have to remove the whole oven and back of the oven to retrieve them. One tag on each prong of the element (doesn't matter which way round they go)
Best of luck
Mar 18, 2013 | Neff B1421 Electric Single Oven
Door does not close tightly ? problem with bottom hinges
Yep, sounds like the hinges/springs have been overloaded.
Dont know if it's a Neff problem in particular, but I had a Neff oven with exactly the same problem - it was already installed when I bought my house.
Spoke to Neff who advised this ocours if heavy things like a roasting tray with a heavy bird / joint in it is rested on the door whilst it's open.
Only cure is new spring/hinge units which are not cheap !
Sep 18, 2009 | Neff B1421 Electric Single Oven
Neff Oven handle loose
The door can be seperated by screw on the side of the door, Put lock washers to insure futer tightness.
Mar 12, 2009 | Ovens
How do i fit new door seals for an neff u1421 double oven i have the seals
If the seals have what appears to be hooks at the corners, then unhook the old seals and re hook the new seals into the holes in the front of oven .
If no hooks, then the front of the oven needs to be unfastened.to replace the seals.
Thanks.
Jan 14, 2009 | Neff U1421 Double circotherm Electric Oven
Neff oven u1420
Hinges not fitted properly,or possibly wrong hinges
Nov 03, 2008 | Neff U1661 Double circotherm super...
Neff u1271 oven not heating
Found the fault. It's the heat ring in the main oven. MAKE SURE THE MAINS POWER IS OFF PRIOR TO COMMENCING THIS WORK!!!!! 1.Simply remove the four screws that fix the fan surround in the main oven. 2.Remove the rear cover fixing screws and remove the rear cover. ( the cable passes through this so just rest it to one side ). 3.Remove the two push on spade connectors from the heater element ( positioned just down and to the right of the fan assembly ). 4.Remove the four heater element fixing screws from inside the main oven. 5. The tricky bit. . . There is one more fixing at the top of the fan in the main oven. I could not get the fan off its spindle, but the next step sorted this out. 6.Remove the three fan fixings from the rear of the oven. This allows the fan to wobble/move enough in the oven to remove the final heater fixing screw at the top of the fan. 7.Pull the heater element into the main oven. No doubt it has a very grey and flakey appearance to part of it! 8.Buy a new one and replace it in reverse order, remembering to replace all fixing screws as you go. 9. If you forget which way the cables on the heater element go, the one with the red marks on it goes to the left as you look at the back of the oven from the outside. ( nearest the fan assembly ) I know this all looks a bit long winded, but it really is quite simple if you follow the notes above! Hope this helps someone. Might just save a ridiculous call out charge from the professionals!!!! Best of luck, Keith.
Aug 15, 2007 | Neff U1721 Double circotherm Electric Oven
Change light-bulb
You need to remove the whole oven from its cabinet (after switching off the electricity supply). Removing the doors first; (see http://www.youtube.com/user/Apart4u for videos of this) then remove the facia, which allows you access to the two restraining hooks near the top of the sides of the oven. With these slackened off (screws at the front) and pushed back, the oven can be slid out of its housing - be careful, it's heavy - onto a similar height workbench in front of the oven housing. Removing the wiring hatch (2 screws) and the rear panel (6 screws) gives access to the screw in bulb. Hope this helps :)
May 17, 2007 | Neff B1421 Electric Single Oven
Neff B1641 Single circotherm super Electric Oven Logo
263 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
