Question about Ovens
I need to adjust the oven door on a leisure zenith 100 cooker
The fan assisted oven, the door doesnt close properly, it seems to close at the bottom and there is a fair gap at the top. it seems to need adjusting but dont know how to do it
SOURCE: leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Posted on Apr 07, 2008
  • 174 Answers
SOURCE: Hi. Just need to know
Hi there is no adjustment. to fix it you will need to change both hinges on the door. Some models have a roller which may need changing (on the oven frame where the hinges are located)if the door is creaking when opened or closed. wherever you go for parts you wil need the model and product no from the oven located around the door area.
Posted on Jan 20, 2011
SOURCE: my oven door does not close tight
These hinges are now obsolete and you cannot get them anywhere. The poblem with this type of hinge is not with weak springs or anything like that, it is with the pivot pin in the door hinge. Follow these instructions and it will not cost you anything for the repair.
It is best to remove the oven from the housing. Remove both sides of the oven panels, you have to remove the top first, then the sides (remove about 20 screws all together). Support the bottom oven door first by tying a bit of string between the bottom and top oven door hand rails. This will stop the door falling down when you remove the springs. unhook the springs and the door will just slide out. (Use a loop of string attached to the back end of the spring to pull it from its holes.)
Dismantle the door by removing the screws. You will probably find that the the hinge pivot pins have come away from the U shaped hinge bracket. The secret is to make sure that these are fixed firm back into the bracket. What I did was to nip the U hinge bracket in a vice, (or use pliers) so that the pin will now protude slightly each side of the bracket. This allows more surface bearing area so the pin will not pull itself out of the hinge. To further make sure, I glued the ends of the pin with epoxy resin.
Then reassemble.
My door now feels like a new one even though it is 15 years old.
Posted on Feb 04, 2011
barkencoa
  • 3463 Answers
SOURCE: Hotpoint ew81n cooker. Non working
Hi.
Unfortunately, the oven thermostat is non adjustable.
However, it is normal for oven temperatures to vary by + or - 10% of the setting.
This is acceptable, so to compensate, set the temp 10% less of the required temp setting.
Make sure you have the sensor fitted correctly inside the oven compartment
Make sure that the thermometer is accurate if you are checking the temperature with one.
Posted on Feb 23, 2011
  • 3 Answers
SOURCE: My leisure classic 110 gas
It could be the flame failure device our Cannon had the same problem
Posted on Sep 24, 2011
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 | Ovens
I have a belling double oven. The bottom is fan assisted. It all works okay but when it is turned off it is making a drumming noise after the fan has stopped. This lasts for at least 5 minutes. Any...
Sounds like the cooling fan bearings are worn, hence the noise after you turn the cooker off.This fan is in the top of the oven and helps to keep the inside cooker electrics cool and often keeps going for a while after you have turned the cooker off. Best to call an engineer to check this out for you!
Nov 30, 2014 | Ovens
Beko oven does not fully heat up
If you have a problem with your beko oven not heating then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Mar 29, 2014 | Ovens
Can't get the bottom oven working on my Zenith 50 cooker
Is it electric oven? Element gone most likely cause. Does the light and fan still come on?
Sep 05, 2012 | AEG Ovens
Hi. Just need to know if the oven door is adjustable on our AEG double oven cooker? The bottom oven seems to 'leak' hot air slightly from the top right hand corner and when you press on the same point the...
Jan 20, 2011 | Ovens
OVEN DOOR IS NOT CLOSE PROPERLY.
which subway are you , if the door doesnt close properly you may need new hinges
Jul 14, 2010 | TurboChef C3 Single Oven
Oven door lock pin broke
how did you fix it?? i have the same problem!! :(
May 12, 2010 | Ovens
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
Belling fan assisted ovens
no you can't connect a double oven to a 13a socket!!
needs a proper cooker outlet wired back to the consumer unit
Sep 29, 2008 | Belling XOU592 / XOU593 Electric Double...
Ovens Logo
74 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
