Question about Neff H5642 Convection / Microwave Oven
MY H5642SOGB microwave keeps blowing the trip for the sockets.
    New Friend:
I have a neff microwave with no manual where can I get one, H5642SOGB, thanks
Posted on Jun 08, 2014
How do i fix it so it wont blow my fuse box:?:
Try another outlet. It maybe over loaded on the microwave outlet. if so you may need a outlet with not so many things on it. And if you lighten the load and it keeps tripping breakers, it may be in the microwave itself. Try another outlet first. Good-Day!
Dec 02, 2014 | Microwave Ovens
Hi, we have a Bosch HMT8656GB built-in microwave, and the other night (shortly after microwaving several potatoes), it shorted out and tripped the main fuse for the kitchen sockets. We've isolated it to...
Confirm that the receptacle where the microwave is plugged in is not faulty by plugging something else in the recepticle and seeing if it works or if the fuse blows. Check the power cord of the microwave for broken, frayed wires. Also check the bulb socket for broken wires. It may or may not be worth the cost of repair, depending on the repair cost verses a new microwave. There are repair parts available.
May 08, 2014 | Bosch HMT8656GB Microwave Oven
My microwave intermittently blows the downstairs sockets
If it is tripping the breaker when you just close the door, I think it might be one of the door switches that the latch activates. There are usually 3 switches behind the latch holes in the microwave. One is a safety monitor switch that is suppose to blow the internal fuse if the microwave is started and the door is not closed properly. It should blow the micro fuse before the house breaker unless you have a weak house breaker. It will do the same thing if start is pressed and it senses a problem with the door. You say the problem is intermittent so I assume you do get it to work at times so I'm guessing most of the microwave is OK. I'm pretty sure you have a door switch problem--- either out of adjustment ---or 1 of them going bad.
Apr 03, 2014 | Neff Microwave Ovens
Fuse keeps blowing
If the microwave oven is the newer type [7years or less], the problem is most likely the magnetron or the inverter board, but if model is older check for a shorted high voltage capacitor.
Aug 31, 2012 | Whirlpool MH1170XS Microwave Oven
My Magic Chef microwave tripped a breaker,I found a melted door switch and replaced it, the other three test ok.With the door closed everything works like new. When the door is opened the breaker blow
The only thing I can think of is check to make sure all switches are aligned correctly otherwise you will keep tripping the breaker, I'am certain that one of your switches are not properly in position.
Jul 07, 2012 | Magic Chef Microwave Ovens
The trip breaker in my home for the electrical outlet keep tripping off what do i do. the breaker in my electircal box for my electrical socket keep tripping off
go to the qualified electricians on your place... but there is some helpful tips that can help you.. (1) for continued protection before starting. turn off the main circuit breaker. (2) unplug all the appliances or equipment installed... (3) check all the wall socket outlet... look for any damages on the wall socket... if the wall socket outlet have no signs of burned or wet marked, try to turn on the circuit breaker. check if the problem is solved.. (4) if the wall socket outlet have a signs of burned or wet marked.. just replace that w/ the same type of socket... check also the appliances that may caused the problem... the easiest way to know is to look at the socket plug itself... ty
Jun 21, 2011 | Microwave Ovens
I don't know if it is the microwave that blowing the circuit, but that is what my brother said. It blows the circuit sometimes when they use it. Model# MS-104yc 1.5KW or maybe the combination of the air...
Are you referring to tripping the breaker? The microwave runs on 110 volts, and if you are referring to a central HVAC unit, it runs on 220. No way the one could blow the other, unless you are referring to a window unit. If it is tripping the breaker, you could start by replacing the breaker (can buy at Home Depot or Lowes), and if it still continues to trip the breaker, then it is more than likely the capacitor.
Jul 30, 2010 | LG LMV1630 Convection/Microwave Oven
Opening the door blows the fuse
more than likely you door safety switch has a short and every time you pull the door open the connections arc and trip the breaker or blows the fuse.
Aug 24, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
Blowing 25 amp fuses
In that case the outlet your using is pushing out too much electricity. Try calling your local electric company for help or a professional electric repair man.
May 21, 2009 | Emerson Black Microwave Oven
I have a Panasonic microwave model nn-sa616wx sn 58100747 it keeps triping the breaker after it operates for awhile we have taken a amp reading and it draws 17.2 amp.This is a new microwave.
Safety first, unplug your microwave from socket outlet.Needs to troubleshoots series of components using eliminating method to know which component(s) that causes breaker to trip off. It is obvious that a componet(s) "shorted out".Remove your fuse and replace it with resetable breaker tested.
Remove leads of the transformer output(secondary side). plug power cord run the microwave.If does not trip off the cct breaker change your transformer. do the same to capacitor lead, one after the other until you discover which component that shorted and cause your cct breaker to trip off.
Jul 24, 2008 | Panasonic Microwave Ovens
Neff H5642 Convection / Microwave Oven Logo
150 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
