Question about Compaq Computers & Internet
2135us will not recognize memory upgrade
Unit will not boot when PC2700 (333 MHz) memory modules are installed. When PC2100 (266 MHz) module is re-installed, unit boots normally.
  • 3,799 Answers
The reason it won't work with PC2700 ram is because it isn't supposed to. PC2100 is the fastest ram it can use.
Posted on Feb 18, 2012
3 Suggested Answers
  • 406 Answers
SOURCE: UPGRADATION OF RAM
Dear Sanjaykpaul.
This has to be checked with existing ram in your note book, The same type may be added to make it 512 MB or can be replaced with a new with Higher capacity. The speed should match with existing Ram Chip Module.
Best Regards
Rafique
Posted on Mar 03, 2008
emallari27
  • 86 Answers
SOURCE: I have a Fujitsu Lifebook E2010 with one 256 MB
Make sure that you got the right memory module with this specs:
Memory
  • DDR266 (266 MHz) so-DIMM 200 pin
  • 2 DIMM slots; upgradable to 1 GB total memory (512 MB x 2)
or better go to this link http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=GUIDES
there's a step by step troubleshooting for memory modules. Also make sure you purchase memory module from Fujitsu or Authorized Fujitsu Dealers .
You can also find us over the web, visit us at www.fujitsu.com or for Around-the-Clock Expert Technical Support you may contact us at :
Phone Support (Direct to Service Desk)
1-800-8FUJITS (1-800-838-5487)
Available 24 hours, 7 days a week.
Consumer Sales - 1-800-FUJITSU
Corporate Sales - 1-800-831-3183
Tech Support - 1-800-8FUJITS /1-800 8385487 or 1- 888 -3854212
-ERNZ
Posted on Feb 03, 2010
Hewlett Packard EliteBook 2530p Memory Upgrade
The 666 in the part number indicates a 666 MHz memory stick. In the spec of the HP 2530 P, it needs DDR2 800 Mhz memory. Possible that the memory is not compatible.
Dec 29, 2011 | HEWLETT-PACKARD ELITEBOOK 2530P BUSINESS...
Type of memores for asus P5S880-VM MOTHERBOARD Q=? FROM==miko hozer
Your motherboard can take DDR1 pc2100, pc2700, or pc3200 memory modules up to 2.0 gb maximum. If you upgrade your memory you must do the following. If you are only adding 1 module it must match the other module that is already installed. If you are installing both modules you can use whichever speed you want. The higher the number the high the Mhz or speed BUT it will only run as fast in Mhz as your front side bus speed which I think is 800Mhz (pc3200).
Apr 14, 2011 | Computers & Internet
Can i put ram from packard bell easynote into an acer aspire 5315.thanks
RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support)Max RAM: Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) This is the kind of memory you need, no matters the branch
Dec 21, 2010 | Acer Aspire 5315 Notebook
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Aug 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
I have a Fujitsu Lifebook E2010 with one 256 MB RAM module. When I try to upgrade to one (or two) 512 MB standard Kingston memory (266MHz Pc2100), the notebook won't boot, I only get 1-3-3-1 beeps which is...
Memory
-ERNZ
Feb 03, 2010 | Fujitsu LIFEBOOK E2010 PC Notebook
What is the maximum memory capacity of acer aspire 5600 model
According to the specs of this laptop model, it supports up to 4 GB of DDR2 533/667 MHz memory using two soDIMM modules. This means that you will have to replace the 512 MB memory module already installed in your laptop, & replace it with 2 soDIMM DDR2 533/667 MHz memory modules, each of 2 GB capacity.
Jul 14, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Memory upgrade, download upgrade to run 400
According to the specs of this motherboard, it only supports 333, 266 and 200 MHz DDR SDRAM. It does not support 400 MHz DDR SDRAM.
This motherboard has only 2 memory slots, each can accommodate a 1 GB memory module. Higher capacity memory modules are not supported by this motherboard.
No BIOS upgrade is available to provide support for 400 MHz DDR SDRAM memory modules.
Jun 04, 2009 | Intel D845GVSR Motherboard
Presario won't recognize second 256 RAM
Remove the original module, install just the new one and then start your computer. If it doesn't start, the memory you bought is bad. The system boards used in the Compaqs will auto-detect memory, and there are no jumpers or BIOS settings needed.
Apr 09, 2009 | Compaq Presario 5000 PC Desktop
I changed my1G ram in my asus 900ah to a 2g CrucialDDR2
As reported on the EeeUser forum, the EeePC 900 is somewhat picky with RAM upgrades. If the RAM chip is not exactly spec’d like the stock RAM module, then the computer would be prone to freezing, especially when switching between battery and mains power.
Also, note that the RAM module that came with the EeePC 900 is an AData PC2-3200 (running at 400 MHz) with part number DOGC1A08342. I find it strange that the chip is a 400 MHz one. Even the original 512MB chip that came with my EeePC 701 was a 667 MHz one!
This means if you plan to upgrade your 900’s RAM, better make sure the module is compatible!
P.S.: If this information was helpful, please rate this solution.
aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Mar 20, 2009 | ASUS Eee PC 900HA Notebook
Very slow boot
Bruce, the Dell OptiPlex GX260 normally will be equipped with a PC133 DDR1 128MB RAM module. It is recommended that you upgrade to higher memory bus DDR1 memory module, for example, 512MB/1GB DDR 1 running on 266 MHz to 533 MHz.
Hope this helps. Make sure u come back here if u still have further request.
Jan 08, 2009 | Dell OptiPlex GX260 PC Desktop
Computers & Internet Logo
64 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
