Question about Gigabyte GA-EX58-UD5 Motherboard
Motherboard will not power back on after being turned off
  • Gigabyte Master
  • 27,725 Answers
Test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
might have been getting hot
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope this helps you
Posted on Feb 19, 2012
My motherboard is dead replaced power supply still nothing
you may got a power spike if so board bad look at the board the caps are they round or flat if rounded on top bad board
Jan 13, 2013 | HEWLETT-PACKARD Hewlett Packard GV34469001...
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    Emachine won't start .power is on, fan is on, doesn't boot up
    I love this one. I've actually done this many times before and have been successful.
    1. Turn the computer off and unplug the power cord from the back of the tower.
    2. Press and hold the power button for about 3 seconds while the computer2_bing.gif is unplugged (this drains the remaining power from the capacitors on the motherboard2_bing.gif).
    3. Plug the computer back in and turn it on.
    If that does not work, follow steps 1 and 2 again, but this time:
    3. Open the computer while it is unplugged and unplug the power supply from the motherboard then hold down the power button again for 3 seconds. (You may also want to take the RAM out and put in back in)
    4. Plug everything back in and turn the computer on.
    Mar 14, 2010 | Computers & Internet
    Usb not recongised
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
    The motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
    So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in. (VOILA)
    Nov 28, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
    My hp a6130n desktop computer won't turn on after a lightning storm. The power supply is good (the little green light in the back comes on) the switch is good - tested it, so I wonder what is wrong - is it...
    i got the same problem accept it didnt involve lighting storm thunder when i turned it off then i try turning back on it would start any help seems like the motherboard is fine the lil green light on back is on also can figure the problem help plz?
    Jul 06, 2009 | HP (D7580-60003) Motherboard
    No power to motherboard
    one way of testing your motherboard ( if you are sure the power supply is good ) , is unplug everything and leave it unplug for about 1 hour and 30 minutes, also remove the battery and bios chip, and unplug everything from the motherboard, come back after the 1 hour and 30 minutes, and plug it back in and it will turn on.....
    you might want to look into replacing the motherboard, look through http://www.geeks.com/, for the best and lowest prices, you also might want to take the hard drive and run some back ups, before that gives out too....
    i hope this helps, send me back some feed back
    Apr 03, 2009 | Intel Motherboard
    Tower won't turn on
    If it's the type of power supply that has a 4 prong cable that goes into your motherboard, and you remove that, and the fans turn on, I'm afraid it's the motherboard has a short in it. If they don't, double-check that your cable is tight in the back of the power supply, where it goes from the wall into the power supply. Sometimes they will be loose, and won't work completely, but will have only one or 2 power lines connectd, so there is your power light.
    Jan 12, 2009 | Intel Desktop Board D845EPI Motherboard
    Turned off computer for the night now will not turn back on
    Sounds like either a short, or misconfigured cable connection.
    Nov 23, 2008 | Intel D845GVSR Motherboard
    Asrock dual core 775 vsta motherboard
    Since the only thing connected is the power suppy and the CPU, this is often caused by a power supply unable to provide the power to the MB. You will need to swap out the power supply and that should take care of the problem.
    Jun 22, 2007 | Asrock 775Dual-915GL Motherboard
    Gigabyte GA-EX58-UD5 Motherboard Logo
    35 people viewed this question
    Top Gigabyte Computers & Internet Experts
    David
    David
    Tony
    Matthew Spark
    Matthew Spark
    Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
