Question about Gateway Computers & Internet
My computer is responding slower than usual
Alot of web sites seem to get 'stuck' it will say--'not responding'
    New Friend:
  • 84 Answers
HI
UE THE MODERN NAVIGATOR
AND TRY
Posted on Feb 18, 2012
Lenovo laptop:check cable connection!
Deat
Replace the harddisk cable it will solve the issue
Apr 24, 2013 | Lenovo IdeaPad Computers & Internet
I had to reinstall xp home edition and the product key won't work help
Do you have the proper key ? it should be printed usually on a sticker somewhere on your computer
Make sure all keys are typed in correctly with the space between
IE: Q8VBM-34FWW-7DFFY- .... this is just an example
Hope this helps.
Dec 19, 2012 | Microsoft Windows Xp Home Edition Sp2...
Dw999 sds drill seems to run slow then if you keep pulling trigger runs faster then back slower thanks
A common failure item the switch is going bad. You need Dewalt part number 152274-19SV. They're not hard to replace but shop around the web for one, these switch usually run between $45 and $60 plus shipping.
Dec 27, 2011 | Drills
My computer frequently stops responding, specially when i minimize windows. My screen usually leaves annoying images. I think it freezes that way. I've checked the device manager, my windows...
How much memory does your computer have? Alot of times when the temporary memory gets full everything will slow down and will cause applications to stop responding.
It can also be your hardrive is too full. The more space you use on your hardrive the slower it will go and if you fill it too full it will also make programs stop responding.
Sep 15, 2011 | Microsoft Windows XP Home Edition
I can't connect to youtube. I get this page that just say 404 not found
404 - page not found
1. st check that you didnt mispell the URL: http://www.youtube.com (this happens alot)
2. check your internett conection
3. if your internett is down check if some one else has internett problems (an other computer)
4. If everyting else fails, restart computer, stil problem: restart router.
5. call the phone /internet company
On the company web this page might be blocked if so you can go around on pages like:
http://youtubeproxy.org/ then type the address it will be (alot slower)
Aug 24, 2011 | Computers & Internet
My pc is too slow what can i do?frequently it becomes hang.
the easiest solution could be to totally shut down your computer. let it reset itself, and power it back up again. If that does not seem to help, then I would clear the cache on your PC. I would also run a scan - see if there are errors.
Do you have alot of games on your PC? Do you download anything free that is offered? Many times that slows a PC way down.
Aug 21, 2011 | Computers & Internet
Most of my programs keep saying not responding. what seems to be the problem?
Your computer is running low on memory, due to too many running programs (unwanted programs starting in the background when windows boots). This causes the computer to use your hard drive when ram is used up (this is alot slower than ram).
Use some software to clean your computer up. Try this little guide.
Also Think about adding more ram
http://www.fixya.com/support/r5272277-secure_clean_computers
Jul 19, 2010 | E-Machines Computers & Internet
Many Computer Programs "Not Responding".
How much memory do you have? If less than 1GB, that could create a serious bottle neck.
Otherwise, my guess is that there is a process running in the background that is using a lot of CPU cycles....maybe a virus. I would try these things:
A. Update your anti-virus software and do a full scan.
B. Run a free utility like Spybot Search & Destroy to check for malware.
C. Download free programs called "ProcessExplorer" and "AutoRuns" (should be available from Microsoft). ProcessExplorer will show you ALL of the processes running on your computer, and how much resources they are using. Disable the ones you don't need.
AutoRuns shows you all of the software that starts up when you boot your computer. Again, disabling the ones you don't need helps a lot.
D. Defragment your hard drive. I recommend the free Smart Defrag utility from IObit.
You can always get a quick look at what your computer is doing by using CTRL-ALT-DEL; selecting Task Manager; then going to the Processes tab. If you see a process using a bunch of CPU resources, and have nothing running, you might want to research that one.
Jul 15, 2010 | Microsoft Windows XP Professional
Minolta Pagepro 9100. The control panel seems to be stuck in a loop at initialization. It shows the following; 1. Disk & flash system loader v.1.0.1 2. Verifying image 3.Jumping to SYS entry point. It...
sound like the printer operating system failed nothing to do with drivers get a Konica Minolta tech out to look at it, mite be able to get a firmware from secured web site to re flash the machine.
Feb 28, 2010 | Minolta magicolor 3300 Laser Printer
PLEASE SOMEBODY HELP ME BEFORE I MURDER MY LAP TOP WITH A BIG HAMMER!!!! When using internet (o2broadband - firefox ) on my E-SYSTEM 3085 lap top,after about hlf hr to hr it starts freaking out & loads...
Download this program: http://www.malwarebytes.org/mbam.php
Click on the left of the page for the free version and run a quick scan, delete everything it finds and do a system reboot as soon as the program finishes so it can delete and locked files.
Mc Afee is ok but recently I've came across lots af malware infections that norton and Mcafee dont seem to pick up.
I hope it helps.
May 11, 2009 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
