Question about Electrical Supplies
Dynacord powermate 600 service manual - Electrical Supplies
2 Suggested Answers
  • 5473 Answers
SOURCE: Dynacord Powermate 1000 Mixer MK1 manual, where
Do you mean teh Powermate 1000 powered mixing board? Dynacord has the manuals for some of their products on their site: http://www.dynacord.de/en/products/7/5/29_powermate.html . The direct link to the manual for the PowerMate 1000 is http://www.dynacord.com/downloads/PowerMate2_Manual_Vs02.pdf . Note the English documentation starts on page 31.
I hope this helps.
Posted on Oct 01, 2011
Dynacord pm 600
That is not a computer, friend. This is a computer forum.
Jul 30, 2014 | Computers & Internet
Dynacord Powermate 1000 Mixer MK1 manual, where can i get one?
I hope this helps.
Oct 01, 2011 | Electrical Supplies
How old is a Coleman Powermate generator pm0545305.01? Where can I find a manual for it?
What kind of problem are you having?? Powermate customer support number below. They should be able to e-mail you one if it is an older unit. General operator's manual here http://www.powermate.com/generators/0062929_0706.pdf. Parts catalog here http://www.powermate.com/pdfs/2007/11/30/parts_pm054__er+_diagram.pdf. The parts catalog has a start date of 11/1/97.
CUSTOMER HOTLINE
1-800-445-1805
or 1-308-237-2181
FOR QUESTIONS OR
SERVICE INFORMATION
Jul 16, 2011 | Coleman Powermate Powermate 5000W...
Coleman Powermate Maxa5000 ER Plus generator...model# PMO525312.17...i need a complete service/repair manual!!
Unfortunately, a service manual is not going to be easy to find. You may be able to order from Powermate, but you may want to save your money and spend it on consumables.
I am guessing that you are looking for a service manual for the engine itself? Good Luck on that one as well, as Tecumseh has folded. Post the engine model# and other information found on the tag, somebody (perhaps myself) may have the manual you need and send it to you via email.
Parts for the engine itself are likely to be hard to find, consider an engine replacement. It likely will be cheaper.
Jun 11, 2010 | Coleman Electrical Supplies
Drawing of Cobra 2 Sub box
Alright, I looked up that sub and I think I know what you need. First and most importantly every sub woofer enclosure is different-made for the sub woofer you will be using. Unless you have the same exact model DYNACORD is using, your box will be slightly different. In fact depending on the sub, your box may be dramatically different. There are some people, like myself, that could help design an enclosure for you but they will probably charge for their services. Either way you can go on the internet and look at some designs to give you an idea of what you need to build. The particular design DYNACORD chose to use is called a "Vented direct radiating cabinet" (it also uses a couple other electronic goodies) a little complex to understand and build. Sure you could try to copy it but it won't work right unless you have the same sub. In fact I use a computer program to assist me in this regard, so don't feel bad if you don't get it right the first time. Good luck and I'll leave you with something from Dynacord.
-Dynami
DYNACORD´s COBRA-SUB is a vented direct radiating
cabinet, equipped with the high-power Electro-Voice EVX
180B 18" transducer.
Frequency response is 38Hz - 170Hz (-10dB), so the crossover
frequency to Mid-Hi cabinets, e.g. DYNACORD´s
COBRA-TOP can be chosen strictly application-oriented
between 80Hz and 160Hz.
The cabinet is equipped with an electronic circuit called
VOICE COIL TRACKING PROTECTION. This circuit senses
the terminal voltage of the transducer and simulates the
thermal behaviour of the woofer´s voice coil. In case of
potential thermal overload the power applied to the speaker
is reduced to a safe level.
Power amps up to 1200W/8Ohms can be used in order to
have maximum dynamic range without the danger of thermal
overload in non-controlled situations. The VOICE COIL
TRACKING PROTECTION exhibits “soft” switching characteristics,
so no annoying clicks or pops are audible. The
circuitry automatically resets after the voice coil temperature
has reached a safe value.
The COBRA-SUB cabinet is made of 18mm birch plywood.
All corner joints and braces are grooved and glued. The
cabinet´s surface is coated with an extremely durable Polyurethane
which exceeds the quality of a standard lacquer
finish by an order of magnitude. A powder coated steel grille
and a lockable cover protects the COBRA-SUB against
damage during transport and bad environmental conditions.
The connector panel uses two 4-pole Speakon connectors
(IN/OUT) for a safe connection and easy daisy-chaining to
other cabinets. The pin assignment is 1+/1-. Pins 2+ and 2-
are also connected between the two Speakon connectors.
When using DYNACORD power amp racks, the whole system
can be wired with 4-pole Speakon cables without any
danger of accidental wiring mistakes. Four recessed rigging
tracks and two webbing-strap points can be used for easy
“flying” of the COBRA-SUBs. The cabinet is equipped with
four large ABS feet that allow easy stacking and a “snap-on
flying” even in angled positions.
Two handles and four heavy-duty castors on the rear side
guarantee easy and safe transport.
Mar 15, 2009 | ElectroVoice EVX-180B Car Subwoofer
Oil to gas ratio for Coleman Powermate 5000?
my powermate is straight gas.......be careful. go to colman web site and download service manual. mike
Nov 18, 2008 | Coleman Powermate Premium Plus 6250W...
Generator fuel-oil mixture
My manual for my Powermate 1000 says 18:1 fuel mixture.
Sep 05, 2008 | Coleman Electrical Supplies
Checking oil in generator
I found some website help. I have this same problem.
http://www.powermate.com/faq.php?cat_id=3
http://www.powermate.com/faq.php?cat_id=3&faq_id=32
I also found out a lot about the Powermate company via a customer service email reply: This has an elusive customer service number that i have not tried yet.
Powermate Corporation is not a part of The Coleman Company, Inc. They have been an independent company for over 10 years and we have no information on their products.
Powermate manufactured generators, pressure washers, air compressors and air powered tools. Information about those products was available from
Powermate Corp.
125 Airport Road
Kearney, NE 68848
Toll Free: 1-800-445-1805 (disconnected)
or 402-758-6303 (disconnected)
Web Page: www.powermate.com
Earlier this year, Powermate transferred the right to sell air compressors and air powered tools to a company by the name of MAT Industries, LLC, 625 Barclay Boulevard, Lincolnshire, IL 60069, 1(800) 628-8815. This company may be able to help you with questions related to air compressors and air powered tools.
In March 2008, Powermate filed for bankruptcy protection. We understand that customer service inquiries to Powermate via emails, mail and telephone calls will not be answered. However, some information about Powermate and its products continues to be available at their website.
If the problem with your unit is with the engine, check the engine manual that came with the unit to determine whether the engine has a separate warranty from the manufacturer. When Coleman was affiliated with Powermate, they did. If so, you can contact the engine manufacturer for a listing of warranty centers in your area. The contact number should be in the engine manual.
If you are needing parts for a powerwasher, please visit the site
http://www.ppe-pressure-washer-parts.com/coleman-powermate-pressure-washer-parts for assistance.
Thank you,
Harold
Coleman Consumer Service
Aug 30, 2008 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
325 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
