Question about Air Tools & Compressors
Manual for arlec enforcer air compressor 2.5 hp 40 litre
2.5 horse power 40 litres
SOURCE: only gets up to 40 psi but keeps running
Did you try tightening the best up?
Posted on Apr 04, 2009
  • 89 Answers
SOURCE: belt drive wont build up pressure
SOUNDS LIKE THE VALVES IN YOUR HEAD ARE NOT CLOSING ALL THE WAY. THEY ARE MOST LIKELY REED VALVES, THIN STRIPS OF METAL THAT OPEN AND CLOSE WHEN THE PISTON MOVES. MAKE SURE THEY ARE CLOSING ALL THE WAY (NOT CARBONED UP). IF YOU REMOVE THE HEAD THEN MARK IT SO YOU CAN PUT IT BACK LIKE YOU FOUND IT. NOT TURNED OR FLIPPED OVER. ALSO IF YOU HAVE TWO PISTONS THE LOW PRESSURE PISTON COULD BE WORKING AND THE HIGH PRESSURE ONE ISNT. BROKE ROD OR VALVES. CHECK AIR FILTER. HOPE THIS HELPS. JODY
Posted on Apr 12, 2009
  • 142 Answers
SOURCE: How do I Reset the pressure switch to kick in
the pressure switch is generally set from the factory, but if you are brave and have some free time it can be done
Take the cover off of the pressure switch, and you will see the contacts. What you will have to do is loosen the nuts on the threaded shafts equally a little at a time until you reach the pressure that you want.
Not something i recommend, but it can be done and done safely. REMEBER TO UNPLUG IT SO YOU DON'T ZAPP YOURSELF!!!!!
Posted on Jul 08, 2009
  • 50 Answers
SOURCE: Craftsman 3 gal., 1.5 hp air compressor: won't
The compressor will not auto shut off until it reaches the preset pressure which is usually around 100-130 psi - your problem is leakage of air from the oil filler cap suggesting that you have a failed internal valve.
Posted on Sep 24, 2009
  • 36 Answers
SOURCE: vertical 33 gal compressor wont build pressure
could be a gaskit or the inlet reed
Posted on Jul 30, 2010
What is the conversion from cubic inch to liters in automobile engines
10 cubic " = .1638706 litres
in your case
300 CI = 4.9161119 litres
horse power has no value in engine performance as horses are no longer in use but torque does so you have to refer to the engine power as ft/lbs of torque or newton meters of torque
Feb 16, 2018 | The Office Equipment & Supplies
Which car is the most fuel-efficient?
1. Maruti Suzuki Ciaz SHVS Mileage - 28.09 kmpl
Tank capacity - 43 L
Range - 1208 km
Engine - Diesel SHVS, 1.3-litre, 90PS, 200 Nm, 5-speed Manual
2. Maruti Suzuki Celerio Mileage - 27.62 kmpl
Tank Capacity - 35 L
Range - 967 km
Engine - DDiS 125 Diesel, 0.8-litre, 47.60PS, 125 Nm, 5-speed Manual
3. Maruti Suzuki Baleno Mileage - 27.39 kmpl
Tank Capacity - 37 L
Range - 1013 km
Engine - 190 DDiS Diesel, 1.3-litre, 75PS, 190 Nm, 5-speed Manual
4. Honda Jazz Mileage - 27.30 kmpl
Tank Capacity - 40 L
Range - 1092 km
Engine - I-DTEC Diesel, 1.5-litre, 100PS, 200 Nm, 6-speed Manual
5. Tata Tiago Mileage - 27.28 kmpl
Range - 955 km
Engine - RevoTorq 3-cylinder Diesel, 1.05-litre, 70PS, 140 Nm, 5-speed Manual
Dec 27, 2017 | Cars & Trucks
What is the engine capacity horse power for a 351 ford cleaverland .
351 "C" 4V 1970-1973 Cleveland
http://www.carmemories.com/ford-engine-specifications/351-engine-specs/351c.html
would have thought engine capacity would be what they wanted
351 cubic inches which converts to 5.75186 litre capacity
horse power in the link above is 300 BHP (brake horse power)
I have no idea myself but found the car memories web site that states the engine specifications and I hope it is correct and matches your engine ?
most likely it would be rounded up to a 5.8 litre capacity
Jul 07, 2017 | Ford Cars & Trucks
Need gas misture ratio for trimmer SRM2501
pauly46 here
the ratio you should use is 50:1
that is 20 mils of 2 stroke oil for every 1.0 litre of petrol that you mix
so if you want to make 2 litre mix use 40 mils of 2 stroke oil , then add 2 litres of petrol only and give good shake
note use good quality 2 stroke oil , such as sthil or husqvarna oil from your outdoor power shop
but if using general 2 stroke oil from a garage use 40 mils of oil for every 1 litre that you mix
this ratio is 25:1 this mix is on the richer side
cheers hope this helps
May 01, 2011 | Echo Garden
What is the fuel mix for 359
hi there troyandbec
pauly46 here
May 01, 2011 | Husqvarna Chain Saw Maintenance Kit 357xp ...
I have bought an ex-display Rockworth 24 litre 2.0 Horse Power Compressor and need to source a users manual
Hi, my name is John. Welcome to FixYa. You can get it here. www.mastertoolrepair.com . Thanks for choosing FixYa...John
Nov 24, 2010 | Air Tools & Compressors
What air compressor you can recommend me for inflating 10x20 truck tires? please give me the right specs. thank you
Noramally a 250 litres capacity with 5 hp motor /three phase would be enough for the job.
You can increase the tank capacity to higher level if the requirement is commercial.
Sep 18, 2010 | Makita MAC5200 Electric Powered Air...
How much 2 stroke oil do I need to add to 1 litre of petrol to achieve a rotio of 40:1
40:1, means 40 parts petrol to 1 part oil. So it's (1 litre-1000ml) divided by 40= 25 ml of oil. Even if you had an odd amount of fuel, Say 7.5 litre's-7500ml 7500 divided by 40 = 187.5ml of oil.
Sep 01, 2010 | Light Outboard Motor Boat Bass Fishing...
Air Tools & Compressors Logo
1,411 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
