Question about Wahl 8550
HOW TO RE-ASSEMBLE THE BLADE UNIT ON A WAHL 9590
TOOK IT TO BITS FOR CLEANING CANNOT RE-ASSEMBLE
3 Suggested Answers
SOURCE: How to reassemble blades on Wahl rechargeable unit
I had the same problem and I eventually figured it out. The blade assembly has to be reassembled first then snapped back into place.
1. the bottom part has a little "nub" that the screws attach to
2. the second part is the thin piece of metal with a ridge
3. the white plastic thing, make sure the ridges are sandwiched together
4. the small blade, the blades must face each other
5. the large blade
use the 2 screws to hold the assembly together, once assembled it snaps into place on the clipper. See attached picture for how it should look once assembled.
It's STUPID that this is missing from the instruction guide that comes with the clippers.
Posted on Oct 09, 2011
rick_stokes_
  • 61 Answers
SOURCE: How to attach beard regulator on Wahl Groomsman
The attachment should hook over the teeth of the blades and then snap onto the back end.
Posted on Sep 27, 2009
How to replace Wahl 9590-210 Pro-series blades
The entire blade sets simply pulls away and unsnaps from the body. The full new blade cartridge snaps back on the same way
Wahl Pro Series Size 10 Replacement Clipper Blade
Jan 22, 2017 | Wahl Health & Beauty
Resistor for wahl dog clipplers
The value of the resistor is 7.5 ohms, half watt or 1 watt will do the job. Not available from Wahl except as part of the PCB so an electronics store is the place to go. Whenever I find one of them burnt out I include a new set of batteries as part of the repair.
Oct 22, 2013 | Wahl 9590-301 ProSeries Pet Clipper Kit
Wahl 9590-210 Pro-series Complete pet clipper kit - corded and cordless operation, will not charge, only used once, bought new on US amazon using in Perth aus., it looks like the resistor has blown, the...
Is it the correct voltage? Check your transformer specifications, operating voltage will be written on it. If the blown resistor is on the PCB beside the battery it is not supplied as a separate part, it comes on that PCB. www.unityagencies.com.au will be able to direct you to an agent able to supply parts.
Oct 22, 2013 | Wahl 9590-210 Pro-series Complete Pet...
5. the large blade
Mar 15, 2010 | Wahl 8550
I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Jun 08, 2009 | Wahl 8550
Wahl 8550 Pet Clippers Won't Work
Tried the above solutions but it all keeps falling apart. It's a wahl pro series rechargeable. There are two screws, large blade, small blade, white plastic part and a silver bracket that seems to slide on the white plastic part. What goes in first? How do I assemble it? How do blades match? Do the grooves on large blade fit into small blade? Help, I can't reassemble it. Thanks in advance! Pam
May 06, 2009 | Wahl 8550
Took unit apart to clean and need reassembly diagram please
the thick racket sit on top of the lil gold bracket
Dec 02, 2008 | Wahl 8550
Wahl 8550 Logo
188 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
