Question about Miele Novotronic Premier 500 Front Load Washer
After using my Miele novotronic w555 it leaves soap deposit on many of the clothes.
This alway occurs on DARK WASH
  • 70 Answers
SOURCE: Miele novotronic w820
i havent changed one on this model but there useally much the same and qiute easy to do first take the back off the machine
at the lower half of the rear of the drum there is two prongs sticking out with wires on spade connectors a third earth wire in the centre remove these 3 wires they should just pull off but sometimes held on by nuts you will have to check yours then with the machine emty of water unbolt this is the element assembly is the reverse
Posted on Jul 26, 2008
Gallois
SOURCE: Hi, i have a miele novotronic w 916 and it's not spinning
I mean this is not a filter error and i think the power main board inside on front bottom EL110 has an defekt and must change.
Or you can post the problem on my board www.avpc.de with photos for solving together and find another cheap used power board for it ...
Posted on Sep 09, 2009
reverendrave
  • 24 Answers
SOURCE: replace door seal miele novotonic w 502
Hello mc2739,
It's been awhile for me since I have done this so I searched on the internet and found the following. The instructions are pretty detailed. You may want to contact Miele if any problems
1. Open the machine door.
2. Turn the main power off and unplug the machine from the wall.
3. Completely remove the powder dispenser drawer (it will come out so far (and stop), then there is a small button at the rear of the dispenser which you need to depress to remove it fully, you'll see this button once you've withdrawn the drawer to its stop position.
5. Undo and remove the 3 x hexagonal head bolts surrounding the door seal (they are at approximately the 2, 6 and 10 o'clock positions). Note these bolts actually secure the front panel to the machine chassis, they do not retain the door seal. Don't worry the front will not drop off.
6. Now look at the aperture of the powder dispenser drawer (you have of course removed the actual drawer earlier). Locate the lower left hand corner of the aperture, and you'll see a recessed philips head screw in a hole. Undo and remove that screw.
7. Now, you'll need to get on your hands and knees. You DO NOT need to tilt, or lift up the washing machine to do the next bit. Locate the underside of the front panel right at the bottom. You'll notice that it sticks out about half an inch or so and is proud of what I would call the kick plate which extends right down to the floor. You need to look on the underside of the front panel, about an inch or so in from the left hand edge. There you will see a spring loaded clip which when closed is located within a slot on the underside of the front panel. Using a flat bladed screwdriver, you need to carefully lever the spring clip open whilst gently pulling the whole front panel (from the left side) ajar. It will just suddenly pop out once you've done it.
8. Open the pump access door lower left hand side of the front panel) and unclip the drain tube from its plastic retaining clip.
9. Now carefully swing open the whole front panel, it opens like a door (hinged on the right hand side). It might be a little stiff as there are a whost of leads attached to it, but it is designed to open fully (with the leads attached) to about 90 degrees.
10. Next, unseat the rubber door seal from around the door opening area (on the chassis, not the front panel, obvioulsy), so that the seal the flops away from the chassis and lies just inside the machine.
11. You will notice that there is a thin steel band holding the door seal in place around the drum. On the right hand side (at about the 3 o'clock position), you'ss see a tensioning screw for the band. With a flat bladed screwdriver undo this completely and remove the screw (it is accessible from above with a long screwdriver). Be aware that there is 1 x washer and 1 x 'nut' type fitting that will fall out when you remove the screw. Locate these and retain them for later.
12. Now extend the steel band to its maximum opening (by moving the 2 x lugs apart where the now removed screw was).
13. You can now remove the steel band. Then pull it out through the hole/door aperture in the chassis.
14. Locate the small rubber tag at about the 12 o'clock position where the seal is attached to the drum and tug it. The seal will then come away from the drum. Remove the old seal completely.
15. Using your new seal, place this correctly around the drum (there is a lip on the seal and this has to go over the lip on the drum. Remember, the seal goes on the OUTSIDE of the drum. Ensure the 'tag' is at the 12 o'clock position.
16. Reassembly is then the reverse of removal.
17. Make sure that you do up the retaining steel band sufficiently and that you correctly locate the sela on the chassis front panel (there is a groove in the seal which will locate the seal in the aperture).
18. Finally, once you're done, put the machine through a few rinse cycles (where the water level is high) and look for leaks. If you have a leak, it is likely that your door seal has a rip/tear, or that it has not been correctly located around the drum - in which case you'll need to investigate.
Posted on Sep 17, 2009
  • 177 Answers
SOURCE: How do I use the washing machine, a miele novotronic w 969
The I is the pre-wash and the III is the main wash where you put the soap powder. the # star looking symbol is the fabric conditioner.
If you don't have a manual you can download this from the miele website.
Posted on Jan 18, 2010
Testimonial: "Thanx for the help. I managed to get my first wash very successfully. "
  • 70 Answers
SOURCE: My Miele Novotronic W 844 Washing Machine will not
Hi there are 3 possible causes.
1. Out of balance load (drum is divide into 3 sections if weight i one section is greater then 1.25kg than another section will not spin)
2.Carbon brushes ( Normally good for at least 10 years)
3. Vent from drain pump blocked.(Vent left front side of soap drawer. Visible when drawer removed)
Posted on Mar 30, 2010
All my dark clothes have soap deposits on them and clothes seem exceptionally wrinkled when I take them out of the washer.
If load is wrinkled the load may have set in the washer to long it is recommended to remove wash as soon as it stops or the load was too large for the washer capacity. Loads must be balanced and move freely during washing. Also using too much detergent could cause the deposits on clothing. Using an he ( high Efficiency) detergent might help. Using delicate or another cycle with low spin speed will reduce wrinkling.hope this helps
Jul 01, 2015 | Maytag Bravos MTW6600T Top Load Washer
Why does my machine shrink clothes on 40 degree wash
Some tissues are more sensitive to shrinking than others.
Some clothing cannot be machine washed or only at very low temperatures (hand warm).
Especially woolen fabric will shrink even at 40 degrees.
Be carefull with spinning at high RPM's.
Always consult the label in the clothing:
Jun 03, 2014 | Miele Novotronic Premier 500 Front Load...
Novotronic w844 when washing large load sticks at rinse program and has to be restarted often several times
It sounds like your heater element is not working. If the washer doesn't reach the desired temperature it will not advance to the next level. Try to do a cold wash and see if it completes the cycle if it does you need to replace the heater element.
Feb 01, 2012 | Miele Washing Machines
Miele Novotronic T562C: Do I put the washing powder into the small opening/hole top left in the removable part? It looks almost too small! And I can't see how it gets out of there into the machine during a...
Right side of compartment for powder when Pre wash is selected.
Middle compartment for powder when Pre wash not selected
Left side with flap for fabric conditioner.
Apr 03, 2010 | Miele Novotronic Premier 500 Front Load...
My Miele Novotronic W 844 Washing Machine will not completely spin dry my clothes. They are soggy at the end of the wash cycle. Help please! (My machine's settings are in German.)
Mar 19, 2010 | Miele Novotronic W1918A Front Load Washer
Jan 10, 2010 | Miele Novotronic W1918A Front Load Washer
Soap suds on the door at the end of a wash cycle. Miele E526
With all modern front loading washers, you might find that the amount of detergent you need is much less than what is recommended by the detergent makers!
First, be sure you're using the He (High Efficiency) detergent and try using only 2 or 3 tablespoons of detergent. If you've heavily stained clothes, be sure to pre-treat them rather than adding more detergent. That should also help with the extra soap left in the clothes after a complete wash cycle.
Give this a try and adjust the detergent as needed to get the best results for your situation.
Hope you find this Very Helpful and best regard!
Sep 22, 2009 | Miele Novotronic Premier 500 Front Load...
Hello, our miele w5040 is about 6 years old and we
if you mostly use lower temperature washes a bacterial mould builds up inside the machine. it can be seen as a black residue in the soap dispenser drawer and in the folds of the rubber door seal. a grey sludge also builds up on the inside of the wash drum and the drain filter. doing at least one hot wash ( above 60 C ) a week can stop this happening.
Aug 26, 2009 | Washing Machines
Dyed washing
TRY TO USE HIGH TEMPERATURE PROGRAME LIKE COTTON PROGRAM WITH 95 DEGREE WITHOUT ANY CLOTHES AND WAIT UNTILL IT FINISH PROGRAMM , DONOT BUT ANY TYPE OF SOAP
THIS LIKE PROGRAMM FOR SELF CLEANING.
I THINK IT WILL BE GOOD !
THANKS
Jun 21, 2009 | Miele Novotronic Premier 500 Front Load...
Spin Cycle Drum deceased.
Dear sir,
I am sorry our chat got cut off. i had a power outage here where i am...
it is up to you weather you want to spend that much on replacing the transmission on your washer....
also the white spots on your clothes. that will be because of the detergant used. the washer is not getting all the soap out of the clothes there for it is getting stcuk on them... if you would like we can try another chat.... please let me know so i can be ready for you.
Aug 23, 2008 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic Premier 500 Front Load Washer Logo
97 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
