Question about Philips Senseo HD-7810 Coffee Maker
Senseo blinks slowly but doesn't heat water
2 Suggested Answers
  • 6 Answers
SOURCE: I turn on the machine, and the light just blinks
at the side of the machine by the water level you will see a float, sometimes this float gets stuck, use a magnet on the outside of the machine to connect with the magnet in the float and then slowly slide the magnet upwards, the float will follow the magnet and the light will flash slowly and the water will heat, if the light continues to flash rapidly you have not connected with the magnet - try again
Posted on Oct 16, 2009
On light will not stop blinking on my Senseo coffee machine
my senseo did the same. i read on hear to clean magnet/float mechanism inside the water resevoir. i did this with a tooth-brush and soapy water. as you invert the empty water container you will see/hear the float slide up and down when clean. work a treat for me.
Nov 20, 2012 | Philips Senseo HD-7810 Coffee Maker
The "clean" light blinks 7
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 28, 2011 | KitchenAid Dishwashers
I turn the machine on and the light blinks and it will not heat the water. I have tried using a magnet to move the float, but the float is at the top.
Do you see a fast or a slow blink? If you see:
  • A fast blink: the machine has encountered some condition that prohibits it from engaging the heater element. This could be a low water level detection (the float being in the high position doesn't mean the Reed relais is also triggered!), some other malfunction or a power problem. To rule out the latter, plug the Senseo into another wall socket, preferrably another electric group.
  • A slow blink: your Senseo is feeling happy and is unaware of a problem. This may point to a defective heater element. If you do hear the rumbling noise of water being heated, it's most likely the temperature sensor - both are cases for the repair shop.
Sep 05, 2010 | Philips Senseo HD-7810 Coffee Maker
Hello, Hope you guys can help me on this one: My philips senseo coffee machine blinks constantly when I turn it on as if there is no water. However, there is enough water in the tank. If I hold the tank...
Either the little magnet in the reservoir is stuck (does it float when you slowly fill up the reservoir?), or the corresponding Reed relais doesn't properly respond to the magnets presence. The latter most likely requires technical attention.
Aug 22, 2010 | Philips Senseo HD-7810 Coffee Maker
Senseo thermocouple junction -
once you locate and remove existing thermocouple reverse procedure best of luck
Oct 15, 2009 | Rheem 24" Water Heater Thermocouple Kit
I turn on the machine, and the light just blinks on and off...no sound of water heating as with my other senseo. I took off the back, and all of the wires seem to be connected.
Sep 23, 2009 | Philips Senseo HD-7810 Coffee Maker
The indicator light continues to blink rapidly
you are correct in thinking the problem is caused by the valve. Use a magnet to connect to the valve from the outside of the machine, slide the magnet very slowly upwards along the water level, the rapid flashing should stop and the water should begin to heat, if not try again as you have not connected the valve to the magnet
Sep 08, 2009 | Philips Senseo HD-7810 Coffee Maker
Senseo 7814 does not heat water and red light keeps flashing
is the red light flashing as though not enough water, if so use a magnet to connect to the valve inside the machine, the valve can be found along the water level where the float is. what is happening is that the float is stuck. by connecting the magnet to the valve and very slowly moving the magnet along the water level, upwards the valve will follow and the water will begin to heat as the light changes to a slow flash, if it doesn't work try again as you have not connected to the magnet
Aug 26, 2009 | Philips Senseo HD7832 Coffee Maker
Blinking power button
The power button blinks when it is heating the water up prior to use. It should switch off automatically when the water has boiled.
Aug 26, 2009 | Philips Senseo HD7820 Deluxe Single-Serve...
The water is not heating up!
Makesure the water holder is seated right. also follow the directions toclean it out once.
If no good,
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Feb 01, 2009 | Philips Senseo HD-7810 Coffee Maker
Philips Senseo HD-7810 Coffee Maker Logo
259 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
just-ice
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
