Question about HP LaserJet 3050 All-In-One Printer
I bought an HP 3050 J610 printer less than a year ago, and need to replace the ink cartridges. Elsewhere on this site Upvarish advised someone else to use 61 cartridges, when the person asking for he
Which cartridge to use for replacement
  • HP Master
  • 5,059 Answers
The HP 3050 Deskjet All-in-One takes the HP 61 cartridges: http://www.shopping.hp.com/product/CH376A%2523B1H . There are 2 cartridge boxes (black and tricolor: cyan, magenta and yellow). Both regular or extended use cartridges are available.
I hope this helps. If you actually have a Laserjet printer, please give the model of the printer to get the toner cartridge you need.
Posted on Feb 19, 2012
upvansh
  • 119 Answers
SOURCE: What cartridge should i use for the HP Deskjet
Hi
I am sorry but 301 is not the right cartridge.
The cartridge that this printer uses is Hp 61 Black and Hp 61 Tricolor
Regards
Upvansh
Posted on Dec 26, 2010
seeker5211
  • 1089 Answers
SOURCE: how do you get a
Press MENU and then 2.
Press < or > to set location then press 'check mark'.
Press 1 to confirm.
If this doesn't set the language, then you will have to do a NVRAM Init. Beware that all settings will be reset to factory default. So, make sure that you know how to enter the correct ones.
Turn off printer. Press and hold the * and 'check mark' while you turn on printer. Keep holding the buttons down until you see displayed "Permanent Storage Init" Release the buttons. Wait for it to ready.
Now when it is ready you can press < or > until the correct language appears. Then press "check mark" and press 1 to confirm.
Good Luck
Posted on Dec 29, 2010
soundman4305
  • 40 Answers
SOURCE: my HP Deskjet 3050 J610 series didnt come with a
Most HP printers will have a free software download from the hp website at www.hp.com. Just look for the downloads or support tabs, it will allow you to search by your printer model. Once downloaded, install the software then plug in the printer so the computer can find it.
Posted on Mar 07, 2011
  • 85 Answers
SOURCE: I am trying to replace
Below is the link provided by HP Support for your issue...
Incompatible Ink Error
Posted on May 02, 2011
  • 111 Answers
SOURCE: my Hp deskjet 3050 j610
Run this utility to see what's going on with the printer. http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&jumpid=ex_r4155/hho/ipg/ccdoc/printer_diag/&lang=en&softwareitem=mp-91788-1
after running the utility above,restart your printer and try printing again.
Posted on Jul 17, 2011
Need instructions on opening up printer and installing cartridges
Here is a link to a video from HP that will show and explain the procedure. Please note that although the model is slightly different the process is the same.
HP Deskjet 3050A J611 and 3050 J610 All in One Printer Series Replacing...
Oct 16, 2015 | HP Deskjet 3052A
I had bought hp deskjet 3050 from usa and want compatible ink cartridge in india , i purchase catridge 802 but it shows incompatible cartridge
You need to purchase a cartridge designed to be used in the USA. The local cartridges are probably for Europe and are not the same.
Sep 12, 2013 | HP PSC 1610 All-In-One InkJet Printer
Tricolor cartridge problem error message on HP 3050 J610
These types of severe cartridge errors (i.e. Incompatible cartridges, Black/Color cartridge(s) problem / Cartridge not intended for this printer, etc.) typically indicate the internal micro-electronics of the HP 61 cartridge are electrically damaged. The cartridges electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you run a Tap 41 diagnostic test to check cartridges electrical health (this is a forced service test so the printer will attempt to send whether cartridges are good or not); Refer to Inkjet411 youtube videos below:
HP 60, 60XL, 61, 61XL Ink Cartridge Refills - Solving Errors & Warnings:http://www.youtube.com/watch?v=BskAfa6NJSg
HP Deskjet 1000-3056 Printer Models -- HP 61 Ink Cartridges Tap 41 Diagnostics Testhttp://www.youtube.com/watch?v=tMZkqE36ifk
Jan 25, 2012 | HP LaserJet 3050 All-In-One Printer
Como resolver error oxc4eb841a en impresora HP deskjet 3050 serie J610
I have a problem, when I turn my Hp deskjet 3050 multifunction gives me an error code and not OXC4EB841A concerned
thanks
Sep 22, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Can't change ink cartriges
Hi
First of all be advised that this is a laser printer and the toner cartridge needs to be replaced.
Follow the steps below
1. Press the blue button on right side of the printer
2. Lift the toner cartridge a little up (This will unlock the cartidge from the holders)
3. remove it slowly and do not force remove the cartridge.
4. The new toner cartridge needs a little care to install
Check this link for step by step instructions of HP.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=es&cc=uy&taskId=125&prodSeriesId=1140783&prodTypeId=18972&objectID=c02709218
Jul 11, 2011 | HP LaserJet 3050 All-In-One Printer
Can ink be use to refill the hp deskjet 3050 j610
no you cant use the normal ink now a days we can buy the printer ink +by saying the model no of the printer or the cartridge no the ink is different used in printer
Mar 15, 2011 | Computers & Internet
What cartridge should i use for the HP Deskjet 3050 J610 I was told to get the 301 cartridge, but printer keeps rejecting it as the wrong one.
Hi
Regards
Upvansh
Dec 26, 2010 | HP LaserJet 3050 All-In-One Printer
HP 1350V all-in-one
Hi, You need to get a new ink cartridge. It is really not recommended to refill ink cartridges but if you do then it is advisable not to exceed 3 times because it could damage the printer head. If the new inks still gives error, then your printer head may need to be checked to see if it needs replacing. Good luck!
May 25, 2007 | HP PSC 1350v All-In-One InkJet Printer
HP LaserJet 3050 All-In-One Printer Logo
291 people viewed this question
Seeker5211
Seeker5211
