Question about Cameras
Nikon SB600 flash won't fire
I changed a broken Xenon tube inside my flash unit. Because the new tube was not original - it was 4 mm longer, so even though the unit worked fine after my repair, I couldn't close it. So I ordered another tube, a little shorter than the 1st one. Soldered it to its place, and now the flash won't fire for some reason. I checked, and there's high voltage between the trigger to each sides of the tube's contacts. I also hear tick sound every time I press the TEST button, but no Flash light! What do you think seems to be the problem now?
  • Jake Okun Feb 21, 2012
    I really don't know the part number of the thyristor. I do have the electronics schematics, but it's not there as a part number.
    I don't have a spare board either, that's the problem.. I'm not sure it's worth the cash - if it's not the faulty unit.
    That's why i'm so eager to pinpoint the problem.
    Genius:
  • 1,212 Answers
There may be a short, or it is arcing over,
Test fire it in the dark to see if you can locate the arc. If no arc, it is likely arcing in the charge capacitor or what might be left of the thyristor.. Which could mean a broken contact, solder connection or wire..
Posted on Feb 19, 2012
Testimonial: "Very detailed answer. I will test this. Thank you very much!"
  • 1 more comment
  • Jake Okun Feb 20, 2012
    I already tested the contacts on both PCB's and it looks ok.. though, I don't know the exact voltage values.
    Can I test for proper voltage values with a simple digital multimeter?
    If so, which values should I expect between the trigger and the flash tube contacts?
    And another thing.. If the the SCR/thyristor or even the trigger coil itself fails, replacing the entire left PCB-K would fix the problem? (it's the PCB with the green trigger coil).
  • John McPherson Feb 20, 2012
    Voltage values will vary, if you can locate a device number of the thyrister you can do a part look up at Digikeyhttp://www.digikey.com and usually it will come up with the right part, if the specs for the old one are in their system. Xenon tubes should fire at 750 volts so most digital volt meters should be in their safe range and most are a10 Megohm impedance so they should not load the circuit excessively.
    If you have a spare board handy- try it. It beats trying to seek out the one failed component, it is what many service centers do.
  • John McPherson Feb 21, 2012
    It is possible too the xenon tube is defective. Since it worked before with the longer tube, I would try that one again just to test the integrity of the circuit. If it fires, the shorter strobe tube is defective. If the old tube that did work does not fire, then you need to look at the circuit board components
    I would check the thyristor for excess leakage or failed conditon. If a part number on the device itself itself is not available, You can try a 1000 volt 4 Amp SCR or Triac. If the original were an SCR, the Triac should work fine.
    In most cases pin 3 is the gate. this controls the device. With an SCR, pin 1 is the Cathode and pin 2 is the anode. the resistance between 1 and 2 should be very high, both polarities of test applied alternaternatly. When pin 3 is shorted to pin 2, it should behave like a diode- current flows when leads are one polarity across the device - fairly low resistance, and then high resistance when leads reversed. A triac will conduct AC current so resistance should be lower in on state (pin 3 connected/ shorted) than in the off state. No need to reverse leads.
    Checking the coil will be a little difficullt as one winding is not connected at both ends. This one usually is terminated at the middle of the xenon tube. The other windings should show some resistance.
Did not flash fire
Have you tried the SB600 flashgun on another Nikon Camera, if not do so, and if it doesn't fire for you, then you should send it to a Nikon Service Centre.
Apr 25, 2014 | Nikon Speedlight SB-600 TTL Flash
Coolpix L110 Flash Issue: At the end of June my L110 flash wouldn't work. This was after a 4 inch slip from my hand to the table, but shouldn't have caused such a big issue. The flash wouldn't...
You will need to know how a flash works. Basically there is a circuit that increases the voltage to insane levels - 2000-5000 volts, store it in a huge capacitor storage, and discharges it over an inert xenon gas tube.
a knock may damage delicate parts, especially the storage and the gas tube.
Have you tried other shops? How about sending directly to Nikon USA? or their fleet of authorised repair shops?
http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
Sep 26, 2011 | Nikon Coolpix L110 Digital Camera
My SB600 is on, shows "ready" but won't fire... the STBY shows on even when not connected to the camera. Will not fire. Any ideas?
Aug 17, 2010 | Nikon Speedlight SB-600 TTL Flash
Nikon Sb600 does not fire every time
More than likely it is the flasg tube . Be sure to clean the hot shoe assembly foot well .
Berrie Smith Camera Repair bbmw@bellsouth.net
Nov 17, 2008 | Nikon Speedlight SB-600 TTL Flash
Sb600 display fine, but no longer flashes
Your flash has a bad flash tube . make sure the batteries are in corectly and youhave a ready red light .
Nov 08, 2008 | Nikon Speedlight SB-600 TTL Flash
Water got into my sb600
I doubt it. Water damage usually is fatal, or very expensive.
Aug 07, 2008 | Nikon Speedlight SB-600 TTL Flash
Nikon SB600.
The flash unit is very compact and the high voltage is at 330volts .
NIKON uses strink warap onn the ends of the tube also and the trigger lead will
pull out of the trigger coil if not careful .
If you need repair contact.
BERRIE SMITH CAMERA REPAIR
bbmw@bellsouth.net
770-312-0719
Jul 15, 2008 | Nikon Speedlight SB-600 TTL Flash
Dropped my SB600
It is possible, but highly unlikely considering that there is no real way to purchase the correct Xenon tube outside of Nikon's supply chain. Also, it would depend on your skill level in dealing with high voltage flash tubes - the electronic flash has a little high voltage power supply that charges up some capacitors (the high pitched sound you hear while it is recycling). When you fire the flash you discharge the capacitors across the Xenon tube which generates a plasma and gives of a pulse light. So, the truth is, if you are asking the question, it is probably not within your capabilities - though if you want to give it a shot, please make sure you discharge everything before attempting to do so. Even after several days, there will still be an appreciable voltage present unless Nikon has done something to protect you (doubtful). Also, you would need to pay extreme attention to contamination from skin oils, etc., so that you don't wind up ruining the high voltage part or blackening the bulb that you put in.
If you have a homeowners or renters insurance policy and the deductible is low enough, I believe that this would fall under one of those.
Good luck.
Nov 16, 2007 | Nikon Speedlight SB-600 TTL Flash
Metz 58 - broken
Take out batteries
Put in 4 new Energizer Lit. Bat in.
Turn on flash
Wait for the ready ready, fully charged
Press the test button out.
Flash should be able to be fired.
atdlee@netzero.com
Aug 13, 2007 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
Cameras Logo
661 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
