Question about Magic Chef CYE4000AWW Electric Dryer
Dryer problem MAGIC CHEF YE224LV 1999 MOTOR TURNS ON, HEATS UP, NO ELECTRICAL/UNUSUAL SMELL DRUM WILL NOT TURN. WNAT TO REPAIR MY SELF DOES THIS SOUND LIKE A BELT PROBLEM???? DOES THIS LATE MODEL EVEN HAVE A BELT?
  • sccllco2 Oct 27, 2008
    PERFECT.............................THANKSSSSSSSSSS
  • 5,911 Answers
I could be wrong, but I don't know of a dryer that DOESN'T use a belt to turn the drum. If the motor is turning on, and the drum is not spinning, more than likely your suspicions are correct and the belt is broken. You can find a replacement at searspartsdirect.com. Just type in the model number you have provided and look under the "Tumbler" heading for item number 5 (part #341241). The website also offers some helpful exploded view illustrations to assist in part location and installation.
Repairclinic.com carries the part at a cheaper price (item number 529597). Use the part number provided by the Sears website for your search criteria. Repairclinic also offers dryer belt installation diagrams. Just click on the "Repair Help" link at the top of the page and look under the "Special Features" section on the following page for "Dryer Belt Diagrams". Magic Chef uses diagram F. I hope you find this information helpful. Let me know if you have any questions.
Posted on Oct 26, 2008
Gas clothes dryer
If the motor is running then the belt is probably broken.
Dec 15, 2011 | Dryers
Replaced dryer belt. heating element works. dryer runs but tumbler still dont turn. diden't check to see if motor is working. if not dose that mean that the motor is bad. too many jeans were put in to...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 23, 2010 | Magic Chef CYE2000 Electric Commercial...
I own a Magic Chef model YG225LV and the drum stopped spinning. Looks like I need to disconnect the vent and gas lines and open it in back to get to the belt for replacement. Can you confirm that?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Yes, on most dryers that is correct...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 01, 2010 | Magic Chef Dryers
My dryer is heating but it is not turning
replace the drums drive belt
take off the top and front panels to do so
Jun 30, 2010 | Magic Chef CYE3005AYW Electric Dryer
Magic Chef electric Dryer won't start
Do you have power going to the receptacle. You can first go to your house panel and look for the circuit breaker for the dryer (usually a 30 amp 2-pole brkr.). It could be tripped. So first, put your dryer in the off position. Next, go back to your circuit breaker in your house panel. Turn off the breaker, and then turn it back on. This should reset the circuit breaker for the dryer. Then go back and try turning on your dryer. If this doesn't work, feel free to contact me again. However, this would seem to be it. Good Luck to you!
Mar 28, 2010 | Magic Chef Dryers
My magic chef dryer heats but will not blow air
A dryer fan is usually directly connected to the motor. If you hear the motor running, maybe the fan broke off, or the duct is really clogged.
Jan 11, 2009 | Magic Chef CYE4000AWW Electric Dryer
Dryer makes squeaking noise ,then dryer shuts off. mdl.#CYG4000AWW
Hello, sounds like the rear drum rollers are in need of replacement which is causing the motor to get hot and cut out on the thermal cut out. It can be tricky to service if you not handy. Good Luck
Oct 19, 2008 | Magic Chef CYG4000AWW Gas Dryer
Dryer quit working
I have a Magic Chef Clothes dryer. Model #YE224LV. Was drying clothes, went back to ckeck and dryer wasn't running. Push botton and nothing. Check circuit breaker everything ok. What do I need to check and how. Just won't start.
Thank you!!!
Nov 11, 2007 | Magic Chef CYE4000AWW Electric Dryer
Magic Chef CYE4000AWW Electric Dryer Logo
157 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
