Question about Panasonic 24V Cordless Sds Rotary Hammer Drill Kit, EY6813NQKW
I have panasonic 24v rotary drill model EY6813 my batteries ran done and when i charged they no longer worked on drill there is 24v at battery but drill just not working
Happened with both batteries one comes up on charger as fully charged and one battery says faulty
2 Suggested Answers
SOURCE: I have a Panasonic 24V rotary hammer drill (model
This kind of problem often start in the machines battery contact springs. In the sprigs should be bent or be slack for any reason, poor contact will occur causing heating (as you noticed). This in turn weakens the tension of the spring/contact in the drill itself further. Inspect the contact springs and look for discoloration and moulted plastic around it. You must replace the drills battery contacts to avoid this problem from escalating. The battery may be saved if you gently rub the contact surfaces with an abrasive. Check the charger's contacts although they may not be replaceable so you will have to improvise. Do not use a damaged battery with damaged, misformed, or uneven terminals due to the danger of poor contact and overheating.
Posted on Nov 29, 2010
Dremel charger model 856 won't charge. Charging light will not come on.
I had a similar problem. I was going to take the charger apart but I ran into triangular socket head screws so in desperation I gently bent the 5 contact wires out from the battery socket. After slipping in the battery and plugging the charger into the wall socket, the charging light returned. The charger contacts that come into contact with the battery are easily pushed back and after a few battery insertions fail to make contact with the battery.
Feb 10, 2013 | Dremel 10.8V Lithium-Ion Cordless Rotary...
Red light comes on after a couple of seconds and the drill stops working
Hi did u get this fixed my one does the same battery say it's full but red light comes on drill stops cheers
Apr 03, 2012 | Metabo 600190520 KHA24 24V Cordless...
Coleman 18v drill CTP 8129 number 9408 label underside drill. Probably 30 hours total usage over 2 years. Appeared not to hold charge after 18 months - had to recharge before every use on a 1 week...
These batteries never last very long. That model of drill is no longer made but I did find some refurbished batteries on EBAY. However, with EBAY you get what you get. Personally, I would never buy a refurbished battery and besides, they are way overpriced for a refurb. Sorry my friend but you would be better off just buying a name brand drill with Ni-cAD batteries (18V or 24V are the most common). I have a 24V DeWalt that I love and replacement batteries are cheap.
Aug 01, 2017 | Coleman Drills
I have a Black Max 24V, model JD610424 and when I put the battery in the charger, nothing happens. I just cannot charge the battery. ****
Black Max 24v power drill
Allied International sells them at 1-800-248-6657, drill part # JDB240R. Have the part number from your drill available (on the label on side or top of drill...a number like 33643)
Mar 07, 2010 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
My new Black Max 24v drill charger will not charge the battery
You indicate that the drill is new. I'd suggest you return it for a replacement. Seems to be a defective or wrong charger. If you have problems and If you paid by credit card call the card company and have them stop payment on that charge.
Feb 21, 2010 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
How long do I charge my 24v ryobi batteries for .thank you
Ryobis have an automatic charger with lights to tell you when it is done. It needs to be fully charged each time to make battery last as long as possible.
Aug 09, 2009 | Drills
I have a Panasonic 24V rotary hammer drill (model EY6813). Recently, one of the stock NiMH batteries began sticking in the charger and the drill. Appears as if one of the battery contacts in "welding"...
Jul 19, 2009 | Panasonic 24V Cordless Sds Rotary Hammer...
I have a dewalt DW005 24V hammer/plus drill i am having problems charging batteries. the L.E.D lights flashes as though its charging but it has stopped showing continuous light as it should do when fully...
The battery has probably lost it's ability to receive a charge. Is it old? Check the output of charger, should be around 26 volts DC at the output jack.
Jun 25, 2009 | Dewalt DW005K Rotary Hammer
Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Sep 29, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Panasonic 24V Cordless Sds Rotary Hammer Drill Kit, EY6813NQKW Logo
104 people viewed this question
Top Panasonic Drills Experts
Craig Butler
Craig Butler
Joseph A Howard
Level 1 Expert
Are you a Panasonic Drill Expert? Answer questions, earn points and help others
