Question about LG Washing Machines
Lg wm-1437wfd on power up flashing programe selector and screen but no error codes rotating selector has no effect
  • 210 Answers
SOURCE: "CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Posted on Jun 03, 2008
SOURCE: LG WM 14316FD washing machine
An UE Error Code is indicative of a “Unbalanced Error”. This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum. I found this answer on the lg web site.
Posted on Dec 14, 2008
  • 12 Answers
SOURCE: LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Posted on Oct 24, 2009
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Posted on Feb 21, 2010
DirtyOldGit
  • 5 Answers
SOURCE: what is the AE error code on LG steam direct drive washing machin
the AE code means that there is water in the base I found that the steam heater element in mine was leaking so after a quick repair using silicon and a good clean after drying the water out of the base it now works again
PS I used to be a washing machine repair engineer! I wouldn't suggest that you start opening up your washing machine!!!!
Posted on Mar 31, 2010
I have a Kenmore washer #11026002010. I am having problems with the water overfilling and not progressing to the next cycle. Would you have info on the fault codes and also the recalibration procedure
Does it sound like it wants to spin? If so more than likely the motor coupler broke causing your washer to not spin. It is one of the most common parts that fail.
Anyhow Sears is the best bet for your answers they even list all the steps needed to trouble shoot.
Model 11026002010 Kenmore Automatic washer Repair
This one is from the link above and credit to:
Natasha12,November 17, 2014
Thank you for choosing Searspartsdirect.com and being a valued member. I can certainly assist you in locating the diagnostics for your washer.
ACTIVATING THE SERVICE
DIAGNOSTIC TEST MODES
1. Be sure the washer is in standby mode
(plugged in with all indicators off).
2. Perform the following sequence of
movement using the cycle selector knob.
NOTE: AFTER RESET, sequence "a" through
"e" must be completed within 6 seconds.
RESET - Rotate cycle selector knob
counterclockwise one or more clicks
to clear sequence.
a. Rotate cycle selector knob clockwise
one click and wait ½ second.
b. Rotate cycle selector knob clockwise
c. Rotate cycle selector knob clockwise
d. Rotate cycle selector knob
counterclockwise one click and
wait ½ second.
e. Rotate cycle selector knob
clockwise one click.
?Successful activation of Diagnostic Test
Modes will be indicated by all status
LEDs (except for Lid Locked) flashing
ON and OFF in half-second intervals.
NOTE: LED names may vary between
makes and models.
FAULT CODE DISPLAY MODE (Pgs 6-7)
To access fault/error codes, perform steps 1
and 2 of Activating the Service Diagnostic Test
Modes. Turn the cycle selector knob until the
status LEDs or display correspond as follows:
?"Done" LED On, "01" Displayed on 7-segment
01
Sensing Soak Wash Rinse Spin Done
Press the START button to enter Fault Code
Display Mode. The status LEDs will flash
ON and OFF and "cl" is displayed on the
7-segment (if display exists).
1. To view last 4 fault codes:
? Turn cycle selector knob clockwise to view
fault codes in the order of most recent to
oldest. (Refer to Fault/Error Code charts
on pages 6 & 7.)
NOTE: A fault/error code will be removed
from memory if it does not reoccur after
10 consecutive wash cycles.
2. To clear fault codes:
? Turn cycle selector knob until the status
LEDs flash ON and OFF or "cl" is displayed
on 7-segment. (See figure 2, page 2).
?Press and hold START button for 3
seconds to clear all fault codes. Press
POWER to exit Service Diagnostic Mode.
You can also visit searpartsdirect.com for parts, diagrams, and repair information.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website: Sears Home Services .
Thank you for your question. Have a great day.
Jan 10, 2015 | Kenmore Washing Machines
LG WM 1485FHD with LE error code. Stope washing after 5 or 10 mins and can't get it to complete cycle
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall Effect sensor is used in these washers which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when there is an issue with the motor or when the Hall Effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sensor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Jun 14, 2011 | LG WM-1485FHD Front Load Washer
Im getting an LE error code. What is that and how do I fix it? The only repair guy is either out of biz or just wont return calls. Thank you
LE error codes on LG front loads are usually caused by the filter being clogged. Remove the small door on front left of machine and remove the filter Some water will come out . Clean the filter and reinsert it and see if that solves the problem
Mar 08, 2011 | LG WM-2277HW Front Load Washer
No power and breakers are all fine
replace the main board under the top cover and the "Hall-Effect" motor speed sensor inside the rear access panel behind th brake cover and in the stator assembly,when the sensor detects no motor rotation from going bad(not the motor) it ruins the mainboard
Jan 28, 2011 | LG WM-2277HW Front Load Washer
Drum wont rotate
Code LE is a locked motor Error and it is caused by:
• The connector (3-pin, male, white) in the MOTOR
HARNESS is not connected to the connector
(3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors
(3-pin, male, white) in the MOTOR HARNESS
and 4-pin, female, white connector in the MAIN PWB
ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR
ASSEMBLY and MAIN PWB ASSEMBLY is cut (open
circuited).
• The hall sensor is out of order/defective.
If you need a service manual for that you can find on Here.
Lg WM-2277HW
I hope this helps.
Randy
FixYa Support Team
Jun 08, 2010 | LG WM-2277HW Front Load Washer
580ex off camera shuts down after a minute or so of standby
No and no, the flash is by default programed to shut off after 1 minute .If you were using the flash on-camera, the flash would automatically power itself on when camera activity is detected but when the flash is detached, it doesn't wake back up.
To change this you have to turn off the auto shut off in the flash menu:
1. Power the flash on
2. Hold down the back light /C.Fn button until "Fn 00 0" appears on the screen
3. Rotate the selector wheel until you see "Fn 01 0"
4. Press your selector button down so that the 0 begins flashing
5. Rotate your selector wheel to change the 0 to a 1
6. Rotate the selector to the "Fn 14 0" position and set it to 1
7. Press your selector button to save this parameter
8. Press your Mode button to return to the main screen
Now your flash stays on as long as the flash switch is turned on ON, and as long as you have juice in the batteries.
Do not forget to turn off the flash after you are done.You can reverse it anytime, but you have to read the manual for that..
Same setup can be found in the manual
May 07, 2010 | Canon SPEEDLITE 580EX TTL Flash
Oct 24, 2009 | LG WM-2277HW Front Load Washer
Lg washer oe error
On LG washing machines, the OE flashing code means there is a drainage problem. hope that helped.
Please Rate Me
George
Apr 28, 2009 | LG WM-2277HW Front Load Washer
LE error code on LG WM0642 FL washer
LE is a locked motor error code.
It is usually associated with a loose motor connector wire or a defective Hall Sensor.
Mar 08, 2009 | LG WM-2277HW Front Load Washer
Dec 01, 2007 | LG Washing Machines
Washing Machines Logo
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
