Question about MSI KA790GXM Motherboard AMD Athlon II X4 635 Quad Core Processor Bundle (KA790GX WADX635WFGIBOX)
My P.C. got off interruptedly while scaning any drive of my WD sata hard disk.my p.c. configuration is AMD athlon||x4 635 quadcore processor,2+2 gb ddr3 Zion Ram,M4N68T-M V2 asus motherboard
It goes off also while i drag any vedio file into a player nd expand the playerbox.it goes off while playing any vedio file.After getting off if i wanna start up again then it starts up trying several times.then it shows that p,c,is not shut down properly.rapair recomended.if i select repair and then do ENTER ,it does not start up but if i choose start normally then it opens up afer trying twice or thrice...
  • MSI Master
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or you run the chkdsk utility
click start control panel administration tools computer management disc management right click on your drive select properties tools check now scan for and attempt to recovery bad sectors and
automatically fix any file system errors tick in both boxes or tick one box then wait until it has finished then return and tick in the other box
i have found the best results ticking the first box then returning after chkdsk has finished automatically fixing files
you should have no input while chkdsk is running any input might further damage your hard drive
hope this helps you
Posted on Feb 19, 2012
Install autodesk maya 2010 64bit
Okay the first thing even though your question is very general and we really don't know the specific probably having if you're installing an auto 64-bit you need these operating systems listed below make sure you have one of those operating systems it must be 64-bit you need to check if your operating system is 64-bit before you can stop go to the Run command on your operating system and type winver then enter an then enter and see if and seethe computer is if the computer64bit if it is not 64-bit you need a 64-bit computer first and foremost if you're having other problems you need to give us more details before we can help
If you're having a license key issue you may not actually own software or maybe counterfeit you need to contact Autodesk in that case good luck
The 64-bit version of Maya 2010 software is supported on any of the following operating systems:
  • Microsoft Windows Vista Business (SP1 or higher)
  • Microsoft Windows XP x64 Edition (SP2 or higher)
  • Red Hat® Enterprise Linux® 5.3 WS operating system
  • Fedora™ 8 operating system
The following web browsers are supported for Maya 2010:
  • Microsoft® Internet Explorer® 6.0 internet browser or higher
  • Netscape® 7 web browser or higher
  • Apple® Safari® web browser
  • Mozilla® Firefox® web browser
Hardware
At a minimum, the 32-bit version of Maya 2010 software requires a system with the following hardware:
  • Windows: Intel® Pentium® 4 or higher, AMD Athlon™ 64, or AMD Opteron™ processor
  • Macintosh® computer: Intel-based Macintosh computers
  • 2 GB RAM
  • 2 GB free hard drive space
  • Qualified hardware-accelerated OpenGL® graphics card
  • Three-button mouse with mouse driver software
  • DVD-ROM drive
  • Maya Composite media cache requirements for playback:
  • 10 GB minimum, 200 GB recommended
  • HDD: IDE, SATA, SATA 2, SAS, SCSI
At a minimum, the 64-bit version of Maya 2010 software requires a system with the following hardware:
  • Windows and Linux: Intel® EM64T processor, AMD Athlon 64, or AMD Opteron
  • 2 GB RAM
  • Qualified hardware-accelerated OpenGL graphics card
  • DVD-ROM drive
Mar 22, 2018 | Autodesk Computers & Internet
My HDD will going to corrupt, so i need to buy one, but i don't know that which HDD is compatible with my AMD Athlon XP 2000 PC. Could any one suiggest that how much maximum capacity HDD Support my PC....
Hard Disk upto 500GB capacity can be added to most of the PCs. As regards compatibility, first you have to check the motherboard for SATA Hard Disk interface as newer hard disks are SATA. Adding the hard disk has nothing to do with the processor. However, motherboard should have the connecting port/ option (such as SATA). Some motherboards support both IDE and SATA devices. Please check the motherboard for SATA Port. You may find the motherboard model/ system model and google a bit for its specification. (You have mentioned AMD Athlon XP 2000, which is the Processor not the motherboard)
If SATA is available on your motherboard, you may add Sata drives of 250-500-750GB drives according to you requirements. Otherwise you have to look for IDE hard Disk.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 24, 2011 | AMD Athlon XP 2000+, 1.67 GHz Retail...
I can't install AUTOCAD 2009 in my windows XP computer.It asks to install direct 3D
Most probably your hardware ie graphic card do not support software requirements.
Autocad 2009 system requirements for Win XP.
32-bit AutoCAD 2009
Running under Windows XP:
•Microsoft Windows XP SP2 operating system
•Intel® Pentium® 4 processor or AMD Athlon®, 2.2 GHz or greater
or
Intel or AMD Dual Core processor, 1.6 GHz or greater
•1 GB RAM
•750 MB free hard disk space for installation
•1024x768 VGA with true color
•Microsoft Internet Explorer 6.0 (SP1 or higher)
If you are using AutoCAD for 3D modeling, you should bump up your system as follows:
•Intel Pentium 4 processor or AMD Athlon, 3.0 GHz or greater
or
Intel or AMD Dual Core processor, 2.0 GHz or greater
•2 GB RAM or greater
•2 GB of additional free hard disk space
•1,280 x 1,024 32-bit color video display adapter (true color) 128 MB or greater, OpenGL or Direct3D capable workstation class graphics card.
Hope it helps.
Mar 22, 2011 | Computers & Internet
What is compatible hdd with amd athlon products?
Hard drives are standardized, and have been for years. Any hard drive that uses the controller type provided by your motherboard (IDE/PATA or SATA) will work. If the motherboard was manufactured before 2002, you should probably use a drive less than 127 GB, because the space above that area may be inaccessible.
Feb 25, 2010 | AMD Athlon XP 1700+, 1.47 GHz (AXP1700BOX)...
I am using a quadcore processor which runs on windows7. pen drives when used with the computer sometimes becomes unrecognizable. once it happens the pen drive becomes useless. do not know why? Can somebody...
solns:-
(probab=10%) 1.go to bios setting (by pressing DEL while starting comp.) there enable the USB options
(probab=10%) 2.Reinstall the operating systm
(probab=80%) 3.MANNUAL problem: the male pin of pen drive may not get properly fit into the female pin of ur comp.'s female USB pin- the same i have encountered 1ce.
May 14, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Upgrading my computer
Dear Fried its possible.. Go the Boot Menu at your BIOS ( For go the BIOS Press DEL at startup your system) there you may se Hard Disk Priority Option. There you can change Hard disk Priority... you may need setup your sata as first one..
Thanks...
Mar 26, 2009 | ASUS K8V SE DELUXE,...
Booup of a custom system.
disconnect all hard drives except the one with your operating sytem and try that. You may have something hooked up wrong but you need to rule out other problems..can you see all the hard drives in the bios?
Jan 19, 2009 | AMD Athlon 64 4000+, 2.4 GHz...
Change of hard disk from 160 gb ide to 250 gb sata
Hello there.
I checked the specifications on your motherboard from here .
As you can see it does indeed support SATA Hard Drives, as per the page:
SATA Four-Channel Serial ATA supports 4 SATA II devices
Each SATA hard drive uses up 1 of the channels, so you can use a total of 4 SATA drives at once.
Hope this helps.
Jun 16, 2008 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
MSI KA790GXM Motherboard  AMD Athlon II X4 635 Quad Core Processor Bundle (KA790GX WADX635WFGIBOX) Logo
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
