Question about York Exercise & Fitness
My York Fitness Inspiration Treadmill won't work :(
Nothing on the display so no error code - but when I switch it on I can hear a low 'hum' from underneath so there is power to it. I've checked the fuse in the plug, and removed the housing from the motor to have a look - no corrosion, rust, loose wires that I can see. I've tried re-starting it with the safety button, but nothing. The button doesn't seem to have a 'click', or very much resistance - it does return but it doesn't see to actually do anything. Is this button broken? If so, would that prevent the machine from re-starting? How would I bypass the circuit breaker?
    Top Expert:
  • York Master
  • 12,223 Answers
Dear Sir:
You have a lack of power in power supply.
Attached is the block diagram for easy diagnose and troubleshooting ,see my tips for more details for to make some measure with your VOM.
Please do not by pass any c.breaker only you will complicate the electronic system.
After you see the block diagram, you can conclude if the power supply +transformer+or main mother board is faulty.
Of course ty your circuit breaker from your house, and see the ground or your outlet wall, see if there some problem to ground.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua.
Posted on Feb 19, 2012
vpaaf
  • 115 Answers
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
Posted on May 01, 2009
erpaalai
  • 999 Answers
SOURCE: The safety key has been lost can you bypass this
Anything the same size as the key inserted in the slot will work. It just activates a switch.
Eric
Posted on Jun 24, 2009
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
  • 3 Answers
SOURCE: i have a error reading of l5 or ls not too sure york fitness z16
The L5 message means that there is a problem with the speed setting switches. Some models have one set of speed adjusting stitches on the handlebar and another set on the console. One of them is defective and is causing the problem.
Posted on Feb 03, 2010
  • 16 Answers
SOURCE: Life Fitness Treadmill "FET" error
Can you please provide model of unit.
Posted on Feb 20, 2010
My treadmill york show me in the sreen error 7 and I can to start machine it doesn't work .thanks gabriel
If you wish to get some details about treadmill repair ; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Feb 08, 2017 | York Exercise & Fitness
Treadmill error code 68
f91790db-4de9-486c-b68a-34e9745503d7.gifplease download the owner manual for identify the REED switch. go www.fitness.manualsonline.com
God bless you
Jun 16, 2013 | Avanti Fitness AT380 Treadmill
York furnace won't ignite
Is the igniter receiving 120 volts after the pressure switch closes? If not, either the board is bad or the pressure switch is open
Nov 27, 2012 | Heating & Cooling
I have A Life fitness 9100 treadmill The display shows the message "maintenance notes wax over" how can I remove this error?the treadmill will not turn on HELPPP
see this steps and fix it. .Of course you must read your instr. manual or download from www. iconservice.com
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
  • 2 Press the "ENTER" button three times to access the treadmill's error log.
  • 3 Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
  • 4 To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
  • 5 To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
  • Oct 17, 2012 | Life Fitness Lifestride 9100 HRT...
    I have a York Fitness Inspiration treadmill that won't work - nothing on the control panel, no signs of life except a very quiet hum that proves power is going into it - have tried changing the fu
    Dear Sir:
    Please adjust the reed swtich , attached below see the diagram and adjust according. 1/8-/14" 2) Tight the ribbon cable from keypanel 3) Tight the connecto from display board vs main motor board.
    Run the software calibration for easy diagnose and troubleshooting.
    see my block diagram for better understanting.I fyou want to measure the motor see my personal TIPS. sincerely. God bless you.
    ernesto cuadra
    managua, nicaragua. c.a.
    Feb 17, 2012 | York Exercise & Fitness
    Error 7 on my york inspiration treadmill tried reset button but still not working any ideas.
    hi,
    By error 7 it means that the safety is not positioned correctly. or the saftey switch inside the unit is faulty. Its a magnetic switch. When you place the safety key (its made of magnet) this switch will activate. Then only teradmill start. Check the safety key is positined correctly or not. If it is in position then you have to replace the safety switch inside the control console.
    OK
    Sep 01, 2011 | York Barbell Home Use Fold-Up Treadmill
    E1 not ERR1 error appears on the display of diamond t300 york fitness treadmill??
    Your problem might be that a magnet has fallen off. Here's an illustrated guide that will make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
    Good luck.
    Jul 04, 2010 | York Yankees Bedding MLB Comforter
    I have a error reading of l5 or ls not too sure york fitness z16
    Dec 29, 2009 | York Exercise & Fitness
    York t500 treadmill model no:LQ6010 showing err07 when turned on
    Error 7 is a Safety Key Error..
    that's the red magnetic circular thingy on the console.
    Simply secure the safety key in place and try it again
    Jan 19, 2009 | York Barbell Home Use Fold-Up Treadmill
    Exercise & Fitness Logo
    390 people viewed this question
    Top York Exercise & Fitness Experts
    Electro Med Services...
    Tom Chichester
    ray gallant
    Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
