Question about Hotpoint 23 in. BF50 Built-in Dishwasher
Dishwasher tripping the circuit breaker
Hi, During a cycle while the machine was circulating the water the circuit breaker tripped. Each time I reset the circuit breaker it trips when I try and continue the program. There is a quantity of water in the basin of the machine so I manually turned the programmer to drain. I switched the program back on and it tripped the circuit breaker again. I have also tried changing the fuse but still no difference. Currently a 13Amp fuse in the plug. I am unsure what to try next. Many Thanks for all your help. Andy
  • 5 more comments
  • Andy Aguda Aug 21, 2006
    Thank you for the advice. I have just visually checked the wires from the junction box to the various points and it all seems ok. No signs of any burns. Any other thoughts at all?
    Many Thanks. Andy
    Thanks for getting back to me again. The circuit breaker seems fine as I've tried running from the upstairs ring and it trips that circuit breaker too. The heating element seems in good nick and I can't see anything that may be causing a problem.
    Sadly I haven't got any manuals or service sheets that would indicate any seriel numbers as when I moved into the house the dishwasher was part of the fitted kitchen. The only numbers I can find are the BF50 on the front pannel and a yellow sticker on the top. This has a large 'B' then 'CUVE LV4' then on the next line 'BIT 2.0' then lastly '3006002031. I am unsure if any of these would indicate a seriel number. The one piece of paperwork I do have was tucked in by the junction box. This has a picture of the program telling me what the stages are and a circuit diagram. This has a code printed '02021 B'.
    Thanks again for your help so far!!
  • Anonymous Mar 13, 2014
    My Kleenmaid DW5 dishwasher trips my House plugs circuit breaker every time it gets to the rinse cycle point in its cycle.
    My 10 yrs old C651 Plus trips the circuit breaker mid cycle. If I leave it a week unused, it will work for 2 3 cycles and then trip the breaker again. When back on power supply, the PC light flashes
  • Anonymous Mar 14, 2014
    I turn my dishwasher on & when it starts the intake of water it blows the main circuit breaker. All my electric circuits are ok & recently checked. Is water getting into the electrics on my dishwasher? If so is it time for a new one?
  • Anonymous Mar 18, 2014
    Is this a major problem?
  • Anonymous Mar 20, 2014
    dishwasher abruptly stopped working. thought I tripped circuit breaker, but did not. Wondered it there is a reset button on Kenmore Type 583-1
    President:
  • 878 Answers
Andy, leave the breaker off and remove the toe panel (bottom panel) from the dishwasher. Remove the cover of the junction box where the cord connection or wiring is made. Look at the wire caps and see if they are not burnt. Sometimes these connections become loose and arch, tripping the breaker. If so, cut the wires, strip a new end and reconnect. Catriver...post back.
Posted on Aug 21, 2006
  • Ron Marek
    Ron Marek Aug 21, 2006
    OK Andy, that would have been the main culprit. You want to check to make sure the heating element is intact and ohms out ok. The other issue would be the motor itself tripping the breaker. Can you run an extention to another circuit to make sure it's not the breaker itself giving you the problem? If you post a complete model number I should be able to look the diagram up on this..Catriver...post back.
SOURCE:
At end of washing machine fast spin the machine trips my electricity circuit and TV switches off along with other appliances. Can you tell me what's wrong with machine?
This tells me that you do not have an overload situation. There is a short, and/or one or more faulty breakers possibly including the main breaker.
Even an experienced DIY'er with electrical knowledge would probably contact an electrician at this point. If there is a potential problem with the main breaker then it is best to get professional help.
Why is my electric circuit breaker tripping
Common Causes for Tripped Circuit Breakers
Why Does My Circuit Breaker Keep Tripping
Jul 02, 2015 | Washing Machines
My spa flips breaker at the 6 pm circulation. Why?
Does it trip on other programmed cycles? Or, do you only have the one circulation time? This one is odd, if it only trips during one of multiple cycles. It could happen this way: if you have two or more cycles programmed, and only the one 6:00 cycle has the option for the heater to come on, then you could have a bad heater element? But the situation would have to have the spa in economy mode. Because heater will work only when timed filter cycles are activated, and if a demand for heat is registered, the heater will come on,and in your case, breaker will trip. If in standard mode, the breaker will trip any time the spa comes on, when a demand for heat is registered, this is called "heat call" or call for heat. Good luck
Feb 28, 2015 | Pool & Spa
Dishwasher trips out after running for a while
When you say "trips out" do you mean the circuit breaker trips? If so the breaker in the electrical box may be bad. Also do you have anything on that circuit pulling high amps when the dishwasher is running? Also when does it "trip out" during a pump cycle or when the heating element cycle starts?
If the pump does not work at all then the pump may have went out. If it happens when the heating element cycle starts then it may be the circuit is overloading or the breaker is bad.
Oct 14, 2014 | Smeg Dishwashers
Viking dishwasher VUD040 keeps tripping the circuit breaker during drying cycle
Are you sure the breaker is big enough to carry the Amps needed to start the drying cycle. You know that due to inductance it takes almost twice as many amps to start a motor as it does to run it.Find out how many Watts it uses and divide it by 120VAC and it will give the maximum amps it will draw. See if the breaker is high enough amp for it. A 25 Amp breaker should be efficient. I hope this helps you and if I can help you in anyway in the future let me know.
Mar 12, 2014 | Viking Dishwashers
Washer keeps blowing fuses
Do you mean the houses circuit breaker? If so, WHEN in the cycle does it blow the circuit breaker? WHEN it trips will tell you what to look at. I.E. If the circuit breaker trips during the fill cycle then it would be the walter inlet valve or the timer in the control panel; if it trips as soon as it is in the agitator cycle - then the motor or transmission; if it trips in the spin cycle - then the drain pump or transmission or control panel.
Jul 15, 2011 | Maytag LSG7806A Front Load Stacked Washer...
The dishwasher starts and initially rinses the dishes without heated water. In the next part of the cycle, the water is supposed to heat to a certain temperature.Beginning this morning, in this second part...
Hi
The issue is with the heating element of your dishwasher, it is withdrawing very large amount of power and thus, the circuit gets overloaded and circuit breaker trips. You'll need to check for any short circuits around the heater element. And, also the resistance of the heater element, it should be around 1.4K ohms to 1.8K ohms.
Please do rate the solution as FixYa and Revert for further assistance.
Thanks
Rylee
Jul 04, 2009 | Dishwashers
Dishwasher pops the circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Jul 01, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Washer trips circuit while filling tub
Sound like the inlet valve coil may be shorted. Remove console and check wires from water valve to control. If wires look ok, the inlet valve has a problem
Mar 18, 2009 | Maytag PAV2300 Top Load Washer
Tripping power
Don't know what the 2-cycle is... but here are a couple things to consider:
Dishwashers by code must be connected to a GFCI circuit since they handle water. If there is a faulty ground anywhere on the device the GFCI will trip, hence saving you from being electrocuted. If the circuit breaker is under rated and the 2-cycle is drawing more current than the rating, it will blow. The dishwasher should be on its own circuit also. If more than one appliance is on the same circuit, it may be too much for that circuit. My guess is that the 2-cycle is trying to heat the water inside the washer and drawing alot of power. Make sure the rating of the circuit breaker matches the manufacturers recommendation.
Mar 09, 2008 | Indesit 24 in. D61 Free-standing...
Hotpoint 23 in. BF50 Built-in Dishwasher Logo
12,161 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
