Question about Panasonic HDC-SD1 Camcorder
Camera Doesn't get on . it get hang
Please help me to get my camcorder o>k
Some times it get hanged and show no response to any command
At last i need to remove Battery to off... But when it try to on it again it doesn't get onn
After many try it agan get on but after some time it get hang again
5 Suggested Answers
SOURCE: Panasonic PV-GS19 I canĀ“t download video to pC
MOTION DV STUDIO should work. I can't find the "free" smaller version and have lost the disc that came with cam that had it. Panasonic does not support this cams donwloads on their site. I can only find the for sale versions of MOTION DV STUDIO. I am having the same d*mn problem. I have a PC with Xp with a number of built in editing programs that should be able to capture from firewire and recognize this connection. This cams USB connection captures bad video artifacts during transfer. The only other solution which I can think of is to use a SVHS serial to mini cord (?). I can't find one of these for sale anywhere...if they exist. Any other people having this problem and have solved it without buying a full version of MOTION DV STUDIO? If anyone can upload the free version of basic MOTION DV STUDIO for us to download, that would be awesome. Btw- my laptop will not recognize the firewire connection from the DV camcorder no matter what I try within the hardware connection UI, etc.
Posted on Sep 09, 2007
johnychel
  • 796 Answers
SOURCE: Won't turn on
hello sir
Posted on Feb 24, 2008
Rider On Way
  • 1679 Answers
SOURCE: Hi, need help with the camera not powering down
Once you turn off the camera and remove the batter, does it power on and if you press the off button does it go off ?
Try this
You need to know in which position was camera turned of.
So try turning it on in RECORD OR PLAY position.
It will work then...
Posted on Nov 27, 2010
  • 269 Answers
SOURCE: I just got a usb
USB will only transfer the still pictures to a computer. If you wish to capture video from the tape, you must use a firewire cable.
Posted on May 11, 2011
Rick Riggins
  • 1812 Answers
SOURCE: Panasonic AG-DVC7 Mini DV Camcorder comes on with
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair cost low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 15, 2011
How do I hang a picture on a Durock cement board wall?
Please provide more information.
Cement board is usually used to as a waterproof wall.
many different 3M Brand Command hangers might work.
if you need to hang a picture in your shower, you may be spending too much time in the shower to require the need for entertainment, possibly need to "phone a friend"?
Command Products
Sep 19, 2014 | Masonry Tools
I have a LG xnote rd405... I'm unable to start the
This can be fixed by Re-installing the Os into your laptop again this is due to some error files hanged in the Os program files.if your laptop if having Win 7,this can be correctly by Recovery Cd. if you like my comment please give me some points For my Better Growth,wishing your betterment
Apr 21, 2012 | LG Computers & Internet
Sony vx2000 lcd broken The lcd screen is hanging by the wires. How would i fix that?
A broken hinge assembly is the most probable cause. This will require disassembling the camera to repair and can be done fairly inexpensively. However, it's not really a user serviceable problem and should be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Oct 01, 2011 | Sony DCR-VX2000 Mini DV Digital Camcorder
I HAVE 20 COMPUTERS CONNECTED THROUGH LAN SYSTEM HAVING XP SERVICE PACK 2 & 3 OS. I HAVE INSTALLED NORTON 2010 ANTIVIRUS SOFTWARE ON EACH SYSTEM 10-11 MONTHS BACK. I HAVE ERP-SYSTEM IN FOXPRO FOR DOS...
Dear Walia,
We need to check weather you are getting any error message while trying to access the Network Computers..
Could you please go through the following steps and check weather you are getting any error message or Dos system getting hanged..
Disable the Norton program from the First 2 systems and try to access the Computers with Ping command...
To use the ping command please open the Command prompt and type ping [ip address of the Second system] ...
If u can access the Computers after disable the Norton program means surely it due to the issue with the Norton firewall...
In that case we need to create the New firewall rule for the Norton program to access the Specific Application
Thanks
Alexander Xavier
Nov 30, 2010 | Norton Internet Security 2010 Antivirus +...
My system cant go windows mode
click on command prompt & then type chkdisk. I will run a checkup on your disk & fix problems.
Mar 28, 2009 | EliteGroup P4VMM2 Motherboard
Camera initially hang after 15 to 20 snaps. It does not switch off or any thing.
it would appear to be either the ic or the button itself.. but it does to go to a repair place
Aug 11, 2008 | Olympus SP-350 Digital Camera
WEIRDEST PROBLEM
Your battery may be low on power.
Buy new batteries.
Jul 13, 2008 | Olympus FE-170 Digital Camera
Sluggish response and hanging KJAM
why dont u check that the alarm and clock corresponds?
Mar 18, 2008 | i-mate K-jam Smartphone
Problem regarding the hang of my phone
Nokia 3230 has inbuilt web browser. which does not seems to be fast enough. Try browsing through opera mobile software. if the problem still persists then the might be with your Gprs radio modem. Else the Network provider also responsible. There might be some virus which can also responsible. Some hardware problem may does work. Have a software reset before backup your phone memory to your memory card. if the problem solves after formating then the problem with the OS and phone memory.
Dec 19, 2007 | Nokia 3230 Cellular Phone
Problem regarding my pmp player camera
my chinese mp4 player hang on the first screen. please help
Oct 05, 2007 | Photography
Panasonic HDC-SD1 Camcorder Logo
20 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
