Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint Aquarius 1100 WD61 will not spin - Hotpoint Aquarius WD63 Front Load Washer/Dryer
  • 5 Answers
SOURCE: Hotpoint WD61
1, your pump may be blocked by fluff coins and other debris.
2. more likely bushes worn on the main motor not giving enough umphhh (loverly word) to go through a complete spin....Bushes easily replacable. Job start to finish with parts on hand a machine mechanic 10-15mins top Diy er like me an hour allways have trouble finding the right spanner... Good luck.
Posted on Jan 06, 2008
SOURCE: Hotpoint Aquarius 1100 spin WMA31
I have just had the same problem too, i fixed it by reattaching the belt and making sure that the belt at the motor was flush with the edge of the motor spindle, right at the end, it looks dodgy, but it works
Posted on May 30, 2008
  • 82 Answers
SOURCE: Hotpoint Aquarius 1100 WM63. fills with water...I
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Posted on Jun 28, 2009
active209
  • 14 Answers
SOURCE: hotpoint aquarius wf340g will wash put wont spin
check solaniod valve on water pump
Posted on Nov 06, 2009
barkencoa
  • 3463 Answers
SOURCE: Hotpoint Aquarius 1100 WM63 Not Spinning Clicking Programmer
I would suggest you check the brushes in the motor, as it sounds like they are worn out.
Replace them if they are less than 3 or 4 mm long
This would give you the symptoms you are describing.
Please rate my solution.
Thankyou.
Posted on Feb 09, 2010
I have a hotpoint Aquarius 1100 (WD61) and the door isn't closing tight enough to start the wash.. It looks to me like a faulty connection
Make sure the ****** is not broken or spring gone/ if need be you may require to fit a new door interlock switch.....Easy to do cost around £18...Parts...Good luck
Apr 05, 2011 | Washing Machines
Thankyou.
Feb 09, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I have an Aquarius WD61 washer/dryer. The door will not now open.
No date on this that I can find. Can you move the dial to a different setting? If so, just move it a fraction to see if it will engage. If it does engage, then you will need a new timer, goes under the dial. If it is a computer panel, try resetting it on another load setting and put it on the final spin.
Godd luck
Aug 08, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius Model WD61 Washer Dryer working but it's noisey
If you've just installed it for the first time ensure that transporting locks been removed (big screws under usualy yellow or white plastic covers at the back side of the machine)
Make sure that machine is standing flat on the floor with no swinging whe you try to move it, this can be achieved by adjusting four legs of the machine (one at each corner).
If neither of those helps than you need to identify when the noise appears what machine is doing at that moment. If the noise appears when it's draining, pumping water out, than your machine's pump is wearing out, or if it's noisy when spining (final spin) than bearing of the drum is wearing out.
Update me about your progress
Good Luck
May 19, 2009 | Hotpoint Aquarius WD63 Front Load...
Working but making noise when spinning.
  • Hi,
  • Try these:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion....
Door Locked. Cannot open. Washine inside.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Machine keeps tripping the fuse at the fuse box - WD61 Aquarius Hotpoint
I believe the problem is in the fus(breaker). I would say that it is the thermal fuse in the machine but it usually goes out before the breaker does. The breaker has gotten weak over the years. You have a hi limit on the machine as well but I doubt this is it. Let me know how you do.
Feb 07, 2009 | Hotpoint Dryers
Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
32 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
