Question about Motorola Walkie Talkie 2-Way Radio
Motorola walkie forgot how to change channel and freq. on the xtn model xv1100
  • Motorola Master
  • 1,654 Answers
With the radio turned off, hold in the PTT and the Monitor button at the same time. Continue to hold these in while turning the radio on. Wait for the radio to finish making sounds before releasing the PTT and monitor button. Then simply press the menu button to walk through programming each of the features. When you have reached the end of the user programmable features you will notice the radio has a different chirp to signal you are done. Then simply turn off the radio to leave programming mode.
Posted on Oct 26, 2008
Motorola manuals download
You will need a programming cable and computer software from Motorola.
May 19, 2014 | Motorola Walkie Talkie 2-Way Radio
How to set channels to be thesame on all motorola xtn series radios
Here is a link to the user guide for the XTN style radio.
Programming instructions begin on page 18. You will need to set the frequency and interference eliminator code (PL code) the same on all the radios.
When you enter programming mode, you can use the menu button to walk you through the various options you can program.
Best regards.
Nov 21, 2012 | Motorola XTN 2-Way Radio
Yes. First you will need to know what is programmed in your newer RDV2020, both the frequency and PL code. Using the instructions in the XTN series user guide you can reprogram your XV1100 to match your RDV2020. If you are uncertain how your RDV2020 is programmed, contact your local Motorola dealer or the vendor who you purchased the unit from.
Here is the link to the XTN series user guide. See programming instructions beginning on page 18.
Best regards.
Dec 23, 2011 | Motorola XV1100 (1 Channel) 2-Way Radio
Can i Program My Motorola XV100 (XTN series) To be a sanner??
No, your XV1100 is a one channel radio with a particular list of frequencies available. It can only do one frequency at a time. Sorry.
Here is a link to the user guide:
Best regards.
Sep 14, 2010 | Motorola XV1100 (1 Channel) 2-Way Radio
I can't retune the channels on my motorola xtn
Sorry, but the XTN446 has only the 8 channels pre-programmed by the manufacturer.
Channels 8
Codes 121
Frequencies 446.00625 MHz
446.01875 MHz
446.03125 MHz
446.04375 MHz
446.05625 MHz
446.06875 MHz
446.08125 MHz
446.09375 MHz
Here is a copy of the spec sheet:
Best regards.
Mar 27, 2010 | Motorola XTN 2-Way Radio
How do i change the frequency and or channel
The instructions for getting into programming mode are on page 18. A synopsis is this:
1) Hold in the PTT button and the MON button while turning on the radio. Continue to hold them in until the radio is no longer making noise.
2) Press the Menu button one time. This is your Freq. Use the plus or minus button to change the freq. Press the menu button to lock in your selection.
3) The next number is your Code. Use the same method to select your code and lock it in.
4) Continue through the menu, making your selections according to the user guide. When you are at the end of the programming cycle the radio will emit a different chirp. When this occurs, shut of the radio and turn it back on normally. You are done programming.
Best regards.
Feb 24, 2010 | Motorola XV1100 (1 Channel) 2-Way Radio
No user manual for the RDV2080d
Here is a link to the programming software
And here is a link to the user guide
The RDV2080 VHF with display would be compatible with the XTN series radios which have a model name starting with XV, as in VHF. Typically the RDV2080 ships on the default frequencies found in the XV2600. So if you have not changed your XTN frequencies/PL code they may match out of the box.
On a sidenote: The Motorola CP110 VHF is also compatible. It is an industrial version of the RDX radio. It has a few more channel capability and a replaceable antenna. It looks just like the RDX models, and it is the replacement radio for the CP100 and/or XTN.
All of the above mentioned models are repairable.
Jul 20, 2009 | Motorola RDV2080d Two Way Radio
Programing radios
The XTN will not work with the spirit. The PL tones are worng.
Feb 21, 2009 | Motorola Walkie Talkie 2-Way Radio
Motorola xv1100 speaker low
The XTN radio is capable of both narrowband (12.5k) channel spacing and wideband (25k) channel spacing. If a radio is programmed to narrowband and another to wideband, one will transmit softly to the other, while the other transmits loudly back. If this were the cause of your problem, it is easy to resolve by reprogramming the radios to match one another. When in programming mode be certain when you get to the channel spacing step to choose the same word on each radio, either hi or lo.
If this does not solve your problem, you are experiencing another issue we commonly see in the repair facility. It is called low receive audio. This is repairable in most cases.
You might wonder what causes this problem. We most often see it when the end-user runs at full volume for long periods of time. Cut back the volume a little bit and you might save your radio from the repair shop.
Mar 05, 2008 | Motorola XV1100 (1 Channel) 2-Way Radio
Radio Communications Logo
247 people viewed this question
Top Motorola Radio Communications Experts
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
