Connecting external speakers
Im having trouble connecting my external speakers to my elonex tv it's all connected but no sound coming through
    Sergeant:
  • 265 Answers
Hi ,
go into your settings on the tv and see if there is a section on speakers and try to set it to external speackers ,,,,,,,,,,,,,good luck Roy
Posted on Feb 18, 2012
  • martinjfreem
    martinjfreem Feb 20, 2012
    Good morning Roy thank's for that ive tried everything on the menu page but to no aveil :( ile keep giving it a go many thanks for your reply kind regards Martin.
  • 489 Answers
SOURCE: cant get any sound when connecting external speakers to dell d610
you are try to get sound for external sound. maybe you put the jack in wrong hole ? or your external device isnot working. or your volume is not high.
try these pls. and notice us.
Posted on May 29, 2009
Geekman
  • 32281 Answers
SOURCE: elonex webbook displays anything black as red
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jul 10, 2009
  • 3 Answers
SOURCE: Trouble connecting 3G Mobile Broadband with Elonex
1. Modem may need more power. Get an adapter (might have come with your modem) that combinds power from two USB ports.
2. add an extention USB cable to get it futher away from laptop and possible interference.
Posted on Sep 07, 2009
  • 1584 Answers
SOURCE: IBM thinkpad type 2647 - after installing external
Go to control panel / sounds / audio, and see if the boxes have greyed out writing, if so then the driver needs reloading, if they are all good check all settings.
Meant to ask if volume control icon is showing in the right lower task bar.
Posted on Dec 22, 2009
  • 67 Answers
SOURCE: cant connect to internet with an elonex one+
for support call (0871 90 296 90) or email support@elonex.co.uk info from: http://www.elonex.com/support/contacts.shtm
Posted on Jan 17, 2010
Sound quit on Olevia SyntaxBrillian 232-S12
A common symptom of power supply trouble is disappearing sound
Apr 01, 2013 | Olevia Televison & Video
I'm trying to connect external speakers to a Sharp Aquos LC-C3234U TV but not having any success. Can anyone help?
Apperently this tv has a history of sound board related problems. So if you are trying to connect external speakers because you have no sound from the set then you still will be sound-less. On the other habd if you just want more sound then I would suggest using a surround sound system which will readily connect to your set.
Oct 31, 2012 | Sharp Televison & Video
I dont have any sound on my p50xha10us
Just check this set connected to any external audio devices, such as an amplifier. Use TVs'audio out connections to the audio in connections of the amp, and see whether the amp produces sound. If yes, the fault will be either to the inside speaker of your set, or its audio output card. If there is no sound produced by the amp too, the digital processor section of the TV's main board is faulty. The main board has to be replaced.
Sep 27, 2012 | Fujitsu P50XHA10 50 in. Plasma Television
Good picture no sound
Hello
Check the speakers first. Get this set connected to an external audio amplifier device, such ans an amplifier or so, with its audio out connections at the back of the TV with audio in connections on the back of the amp, and listen whether you can see sound from the external amp. If you can hear sound from the external amp, and not with the internal speakers of your tv, either the speakers may have damaged or it audio output IC had got damaged. if so you have to replace the IC or should replace the audio card o your tV, if the IC is not available at local electronic spare part market.
If you can't hear any audio by external amp, as it has been connected as stated earlier, the mother board [main board] of your tv has the trouble. There is no repair to this digital board, and it should be replaced as card basis. OK.
Feb 08, 2012 | Vizio 42 in. LCD TV
Magnavox LCD tv external speaker
Hello
The jack you describes here "Digital Ouput Device To" means, you can connect these jacks to the output of a digital device, such as DVD or so. It is meant for to get signal into the TV, not ot out.
HDMI [High Definition Multimedia Interface] is a type of connection, which the TV an be connected to any HDMI device from outside. Both the above said are, signal in to TV connections. Not out.
If you want to connect this TV to any amp or any other external audio devices; look for any audio out option is there.
Feb 05, 2012 | Televison & Video
No sound on the tv but everything else works
Hello
Check whether 'mute' function is On. If it is ON, normally a embelm of speaker with a red cross over it will be displayed on the secreen with most of the TVs. You haven't given any details of your tV, brand name, model number etc:- so, i can oly give you general flault description. If mute is OFF, and still there is no sound output from your TV, check its speaker first. If speake is OK, check the set for it audio output, by connecting it with an external amp, by connecting the audio out rCA socet at the mack of the tv, to the audio 'in' of the amp. If there is audio out from the TV, you can heare audio through amp. If there is no audio from amp also, make sure that the sound fliter circuit inside your tV is faulty. If there is sound through amp, and no sound comes by the loudspeaker of the Tv, make sure that the audiou output section circuit inside your tV has the fault; provided speaker is good. OK.
Dec 08, 2011 | Televison & Video
Can't get sound to come from speakers with tv only the radio
You didn't give the brand and model of your TV, and I can't try to find a manual and see what kind of AV connections it has available. So here's some general information.
Many TV sets only have input jacks for external sources like DVD players or cable boxes. When you select an external source, or use the set's internal tuner for TV programming, the video and audio play through the TV. The trouble is that if the set has no audio output jacks, there's no way to get a sound signal out. The TV accepts only inputs
When the TV is part of a home theater system, most people use it just as a video monitor. All AV sources connect to the receiver, and audio is sent from there to the speakers. A video output from the receiver goes to the TV so you can see the picture, and the TV's speakers aren't used. If you have a cable box, FiOS set-top box or satellite receiver for your TV channels, they connect to the receiver too, since they're just another external source.
This doesn't work if you rely on the TV's internal tuner for TV channels, though. This might be the case, for instance, if you have a cable system where a converter box isn't required and your cable connects right to the TV. When you're watching regular TV, then, the sound comes through the set's internal speakers. If there's no audio output available on your TV, that's your only option.
As I said earlier, many TV's have only audio inputs. But some have audio output jacks as well, so the sound has a way out. If yours does, you can connect them to one of the inputs on the home theater receiver. Then when you select that input you'll get the TV sound through the speakers connected to the receiver. Depending on the design of the TV, you may need to leave the TV volume turned up. Some sets have outputs that are follow the TV's volume setting. On others, the output is an independent fixed level. Then you can turn the TV volume down and use just the receiver's speakers if you want.
Check the connections available on your TV and look for a set of "audio out" jacks. Your TV's owner's manual should have a section explaining how to connect it in different ways. If you need a copy, most manufacturers have manuals for download on their website.
Good luck with your sound, and thanks for using Fixya!
Jun 17, 2011 | RCA Audio Players & Recorders
How to connect headphones to this tv.
The only way to accomplish this will require an external amplifier.
Connect the program out to the input of the external amp and use the headphones from there. Disconnect the speakers or turn them off in the audio menu.
Hope this helps,
Dan
Jul 11, 2010 | Panasonic TH-42PX60U Television
Sep 06, 2009 | Computers & Internet
Sound problem
check the menu on the tv to see if the speakers are set to off
I think if you connect it to external amp the tv's speakers must be shut off beofre it will activate the line out audio
Nov 05, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
