Question about Candy CNW156 Front Load Washer / Dryer
My Candy Alise washer/dryer will not not spin and sometimes shows E:08?
I did a load the other day and it was fine so i put it on dry put the water didnt rinse. i went to put it on another dry cycle and it wouldnt spin and a timer came up. i turned it off, took washing out and tried it with no clothes in.the washer does everything right at the begining but then doesnt start spinning, a few minutes later comes up with E08. the only function is does do is let me drain the water out. please help, its only 2 months old but have lost the manual!
  • deedee_white
    deedee_white Feb 18, 2012
    by spin the DRUM will not turn at all.
gittos73
  • 244 Answers
SOURCE: Hot wash programme won't work.
more than likely that your timer dial has a fault on it to replace your timer dial is alot if u need the 90 degree wash then you really are better off buying a new washer just as cheap to do it this way sorry for the bad news theres nothing you can really do sorry yet again m8
Posted on Aug 14, 2007
SOURCE: Candy CN146
0I have a candy intergraded washine machine ,could you tell me where the filter is please as the wash finish but still has water in, I put the cycle on to the water discharge and it emptys,then i put it onto a spin which works fine. But i need to know the problem
Posted on Nov 11, 2008
danforddan1
  • 192 Answers
SOURCE: not enough water to wash load
May be the filter inside the filler hose;s are clogged. Take the off the back of the washer and clean them out.check the faucets you never no. good luck DFD
Posted on Apr 22, 2009
beltronic205
  • 1466 Answers
SOURCE: model is Candy Alise 1200
Short circuit on machine Disconnect the heating element located at the back of machine pull off the two wires then try switching on for fault, hope it clears......
Posted on Jun 13, 2011
  • 1010 Answers
SOURCE: candy washer dryer filling water dry cycle then empty
Could be the circuit board at fault
Posted on Mar 31, 2013
Candy Alise 1000es
Hello, Here is the location for the manual that you need. Candy Alise 1000 ES User Instructions
Aug 25, 2014 | Washing Machines
Where do I find Candy Alise 1000es Instruction Manual for Washer Dryer
You can find the instructions for your machine on a site called manuals lib (library) there you can download a PDF file for free.
Lost engagement ring in washer dryer
Check the hoses at the base of the water pump.They could stil be there.
Jan 06, 2014 | Candy Washing Machines
Candy Washer/dryer Stalls
Have you checked the drain hose connection? Make sure the bung is clear in the trap
Aug 07, 2012 | Candy CNW136 Front Load Washer/Dryer
My Kenmore H2t front load washer won't drain and
Hallo there
So it will not do what it is told. This happened to my Candy machine the other day. It was finished and I opened the door, out came water and I got 5 towels on the floor to dry up the water. Closed the door again and put empty water on, it emptied the water, stopped the machine and put spin on and it made it.
My experience ,learned the hard way, to wait long enough after the machine stops as well as between changing programs.
I this will be of some use to you.
Kolbrun
Apr 15, 2012 | Kenmore Washing Machines
I have the Candy Alise washer-dryer, It is 3 years old. The lock door sensor light is not coming on when the door is shut, the door seems to be shutting properly and making the click noise when it closes....
There is likely to be a problem with the 'door closed' sensor, unfortunately requiring a service engineer's attention I suggest ;-0(
Good luck,
John C
Apr 06, 2011 | Candy Washing Machines
Candy CMD146 Washer/Dryer
This machine has selfcondensing system. The condense water is beeing pumped out with the cooling water. The watertap MUST be open during drying. It also may be caused of overloading. The most W/D combos is just able to dry just the half of a full load in one time.
Jan 10, 2008 | Candy CN146 Front Load Washer
Candy alise 1000 formula stainless
Click on brand name (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Or click on "washing machines" above to find your brand.
Jan 01, 2008 | Washing Machines
Candy CN146
Nov 01, 2006 | Candy CN146 Front Load Washer
Candy CNW156 Front Load Washer / Dryer Logo
421 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
