Question about Compaq Armada 1750 Notebook
Armada 1750 does not show cd rom
CD Rom drive does not show up in the system. OS is XP Pro. Tried regedit but no filters nor .bak file
  • 3 more comments
  • Roy young Feb 18, 2012
    Hi armada ,
    do you have the drivers for the cd rom ?
  • Khalid Mahmood Feb 18, 2012
    Additional note for Roy Young, pl. Re. Drivers. These were there when it last worked normally. With the entry for CD Rom now missing from the Device Manager,I'm not clear about how else one would determine condition of the Driver(s).Thanks for yr continuing efforts!
    HI ,
    ok , the drivers are in the os . lets try a recovery , in the control panel , you'll find the icon , go back to the date the cd rom was working , you said about 10 days ago
    that should work to solve the problem . if not i have 1 more thing i would like to try
    good luck roy
  • Khalid Mahmood Feb 20, 2012
    Hi,Roy Young,
    I owe you an apology for having referred to re-setting BIOS;actually it was thru the Compaq Setup utility which is activated instead,on pressing the f10 key at start-up.
    Also, I had already tried System Restore prior to raising my question over here.
    In the spate of quick responses I overlooked these two aspects. (It seems there is no key to access the BIOS on the Armada. All you get is the Compaq utility 'Setup' when you try!).
    This site was not accessible over the past 15 hours, hence delay in my comments.
    Regards.
  • Khalid Mahmood Feb 22, 2012
    Roy Young, Hi!
    Not seeing any further advice from you since my last of Feb 20 makes me wonder if there is an undue break in the conversation?
    In the meantime I have discovered that even my floppy drive has stopped working although it seems to be active during POST at boot up. It's showing up in Device Mgr though, and is listed as working correctly.
    Sergeant:
  • 265 Answers
Hi ,
Ok , first , lets try the device manager and see if there is a conflict with another device , so right click on the driver and go to prop. and see whats up ,,,,,,,,,,,,,,let me know ................Rpy
Posted on Feb 18, 2012
    Thanks Roy Young. No Cd Rom showing in Dev. Mgr.
    Device is a TEAC replacing original Matsushita(Compaq). In use for eight mths now. Some ten days back it stopped booting from a Linux CD. It ejects and 'spins' a disc as normal, but stops short of opening anything on screen.Have adjusted BIOS to give priority to boot from CD.Still no luck.
4 Suggested Answers
  • 883 Answers
SOURCE: BOOTING FROM CD ROM DRIVE
try typing:
D:/SETUP
don't forget the colon after D
if this does not work, then try typing:
E:/SETUP
Posted on Nov 15, 2007
  • 243 Answers
SOURCE: compaq armada e500 dvd rom doesn't work
Try cleaning the lense using a lense cleaning disk.
Unfortunately it sounds as the drive is on the way out :(
Dvd are harder for it to read than cds so they are normally the first thing to stop working.
Dvd/cd drives dont require drivers as they are plug and play (aka plug and play!! :)
Best not to update the firmware as if it goes wrong then the drive will be dead.
Posted on Dec 29, 2007
duployen
  • 32 Answers
SOURCE: 101-I/O ROM error and 162-system option not set
sound slike theres a fault with a cd dvd drive or that it's disconnected, possibly the driver is corrupt
Posted on Jun 08, 2009
My dvd rom is not showing in My Computer
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Aug 18, 2012 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
I have an acer aspire t160 I installed a windows xp pro and my cd/dvd rom door will not open . is there something I can do to get it recognized
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Feb 13, 2012 | Lite On LH-20A1H DVD RW Dual Layer Burner
MY CD DRIVE IS NOT DETECTING THE CD ..... I HAVE INSTALLED 2 OS 1,WINDOWS XP IS SHOWING AN FATAL ERROR NOW.......2.FEDORA IS WORKING .... I GAVE MY LAPTOP TO A NEAR BY SERVICE CENTRE HE CHECKED AND TOLD...
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
also
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
only do the registry check if you cant see the drive/s in windows explorer/my computer
or it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 30, 2011 | IBM ThinkPad T41 2373 Notebook
I have loaded windows xp on my compaq presario 2100 notebook pc. the toshiba SD-R2312 CD-RW/DVD ROM is not getting detected due to driver not being there. kindly send drivers file by mail.
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 05, 2010 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Computer does not see cd wp system
you might have to physically unplug the plug you cd rom back in this should activate the found new harware wizard or you might try
make sure that the cd rom is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Nov 23, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
MY COMPUTER IS NOT SHOWING THE CD DRIVER. HOW CAN I EXPLORE THE FILES OF MY CD?
you might have to physically unplug then plug back in this should activate the found new harware wizard or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Nov 05, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
SAMSUNG CD-ROM SC-148 FILES WERE DELETED. WHERE DO I GO TO RETURN THEM?
) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders * HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
Jul 05, 2010 | Samsung SC-148 CD-ROM Drive
How to instal file 'asms The file 'Asms' on Windows XP Professional Service Pack 2 CD is needed" when installing WinXP Pro,
When you install Microsoft Windows XP, you may receive the following error message:
[Files Needed]
The file 'Asms' on Windows XP Professional CD-ROM is needed. Type the path where the file is located, and then click OK.
This issue may occur if the Setup program cannot communicate with the CD-ROM drive.
To resolve this issue, use the appropriate method for your computer.
Hard disk formatted with FAT or FAT32 file system
If the hard disk is formatted with the FAT file system or with the FAT32 file system, follow these steps:
Use a Microsoft Windows 98 Second Edition or Microsoft Windows Millennium Edition (Me) Startup disk with CD-ROM drivers to restart the computer.
Copy the Xcopy.exe tool from the Windows 98 Second Edition CD-ROM, the Windows Millennium Edition (Me) CD-ROM, or the hard disk to the Windows Startup disk. To do this, use the appropriate method.
Insert the Windows 98 Second Edition CD-ROM in the CD-ROM or DVD-ROM drive, and then at the command prompt type the following lines, pressing ENTER after you type each line, where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive:
c:
copy cd-rom:\win98\smartdrv.exe
copy cd-rom:\tools\oldmsdos\xcopy*.*
Insert the Windows Millennium Edition (Me) CD-ROM in the CD-ROM or DVD-ROM drive, at the command prompt type the following lines where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive, and then press ENTER after you type each line:
c:
copy cd-rom:\win9x\smartdrv.exe
extract cd-rom:\win9x\win_17.cab xcopy.exe /L c:\ xcopy.exe
extract cd-rom:\win9x\win_17.cab xcopy32.exe /L c:\ xcopy32.exe
extract cd-rom:\win9x\win_19.cab xcopy32.mod /L c:\ xcopy32.mod
Hard disk
At the command prompt, type the following lines where drive is the drive letter of the hard disk where Windows is installed, and then press ENTER after you type each line:
c:
copy drive:\windows\smartdrv.*
copy drive:\windows\xcopy*.*
Eject the Windows 98 or Windows Millennium Edition (Me) CD-ROM, and then insert the Windows XP Professional CD-ROM.
Copy the I386 folder and all its subfolders to the hard disk. To do this, type the following lines at the command prompt where cd-rom is the drive letter of the CD-ROM drive, and drive is the drive letter of the hard disk, and then press ENTER after you type each line:
smartdrv
xcopy cd-rom:\i386 drive:\i386 /e
Restart the computer, and then start the Setup program again.
When you receive the error message, click Browse, and then type the path of the I386 folder on the hard disk.
Note You may be prompted several times for the location of this folder. If Browse is not available, see the "Hard disk formatted with NTFS file system" section.
If the hard disk is formatted with the NTFS file system and you are upgrading an earlier version of Windows, use one of the following methods.
Method 1
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
When you receive the error message, press SHIFT+F10 to start a command session.
Type regedit.exe, and then press ENTER.
Click HKEY_LOCAL_MACHINE.
On the File menu, click Load Hive, and then load %Windir%\System32\Config\System.sav.
When you are prompted to specify a name, type Test.
Locate and then click the following key:
HKEY_LOCAL_MACHINE\Test\ControlSet1\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the UPPERFILTERS and LOWERFILTERS registry keys.
Repeat steps 6 and 7 for the other ControlSet# keys under the Test hive.
Click File, and then click Exit to quit Registry Editor.
If the path in the error message is the correct drive letter for the CD-ROM drive, click OK to continue the Setup program.
If you receive the error message again, the Setup program cannot correctly read from the CD-ROM drive, or the path information is incorrect. In this case, restart your computer and let the Setup program resume.
Method 2
If you cannot start Regedit.exe at the command prompt, and there is another available partition where you can install Windows on the hard disk, follow these steps:
Install Windows in the other partition.
Start the new installation of Windows, and then start Regedit.exe.
Follow the steps in method 1, but load the System.sav hive from the original Windows folder.
Method 3
If you are not using a retail Windows XP CD-ROM with a hologram (for example, if you are using a burned CD-ROM), try to run the Setup program from a retail CD-ROM with a hologram. To verify this, start the computer by using Recovery Console, and then check the C:\$win_nt$.~ls folder. Look for the Asms folder. If the folder is missing or the files that it contains are zero bytes, the CD-ROM was not burned correctly.
For additional information about how to use Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base:
307654 (http://support.microsoft.com/kb/307654/ ) HOW TO: Install and use the Recovery Console in Windows XP
Apr 27, 2010 | Microsoft Windows XP Professional With...
My Combo Drive is not visible
Please read to the end before atempting this.
Is this XP or Vista. In Windows based computers some times the High and Low filters get messed up in the registry. If the drive is still good and you had not had any issues with it not reading disks then the filter settings may be your problem. Try this:
1) Close all open programs
Note: Vista doesnt come with the run command as a choice so just type REGEDIT in the search bar above Start..
3) Click on the plus signs (+) next to the following folders to open them.
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
(looks like same file name for XP and Visat?)
UpperFilters
LowerFilters
UpperFilters.bak
LowerFilters.bak
5) If you see any of the above keys, right-click on each of them and choose Delete
6) Close the Registry Editor
8) Click Start
9) Open My Computer and check to see if your CD or DVD drive shows now.
Open the device manager for your version of Windows and make sure the Rom Drive is showing and that it is not showing an exclamation mark. If you still do not see the Rom drive then your drive may be defective. Note: you migh have to reinstall some of your CD or DVD playing/burning software. Hope this helps... Dale
Feb 20, 2009 | Acer TravelMate 2300 Notebook
Compaq Armada 1750 Notebook Logo
108 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
