Question about AEG Washing Machines
Aeg washing machine e320 error - AEG Washing Machines
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Hello my AEG washing mashin d
Posted on Jul 31, 2017
SOURCE: AEG LAVAMAT 74620 - Washing Machine CE error code
read this site: kind regards, w vd vegt
Posted on Aug 28, 2007
  • 6966 Answers
SOURCE: AEG Washing Machine: Door won't close
Hi again,
Any updates/development with your project?
Posted on Jun 21, 2008
  • 4 Answers
SOURCE: error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
Posted on Jul 08, 2008
  • 3230 Answers
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Posted on May 06, 2009
  • 174 Answers
SOURCE: What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Posted on Jul 16, 2010
Hallo i have an aeg washing machine made in the netherlands and is showing e19
I looked up the list of error codes for this washing machine and sorry but e19 is not listed, it skips that one number. Please contact AEG.
Jan 25, 2017 | AEG Washing Machines
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
I received an error EH1 in my AEG electrolux Lavamat L64850l washing machine, how can solve it?
Problems with the electrical power supply, the appliance remains in the alarm state until achieve conditions of work, and stabilizes the voltage and frequency, and the machine resets quenching (controller to the position "0").
Obviously there is a problem in the electrical network so my suggestion is to call your local electrician or try connect power supply from any other room.
May 04, 2015 | AEG Washing Machines
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Aug 24, 2014 | AEG Washing Machines
My Washing machine Brand : AEG and model : 84740 update and problem is when switched on its showing error message C3. And blinking 3 light as well one is 1400 light , and other 2 is washing program
Quote 'German made AEG washing machines (update) C3 indicates float switch fault' unquote.
Sorry- looks like a service call is required ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 28, 2011 | AEG Washing Machines
The cycle is not completing and send an error message E320. I don't know what this means. It is on rinse by this time, so I move the dial around manually to finish off cycle. What is the problem? I had...
go to the manufactures website and download the user manual and look in the trouble shooting guide for a possible answer if you cant find one I would call back the engineer and ask him to give you an answer as the machine worked before he fitted the new rubber, good luck eric
Jan 16, 2018 | AEG Lavamat 74640 Front Load Washer
Error code E320 appears and the machine has failed with this code
Go to the very bottom right of the washing machine, open up the flap; there is a round filter. Open up the nozzle and put a towl down underneath- once the water has stopped coming out, twist the whole filter until it lifts out. Clean this (there may be money and fluff in here) with water. Put it back in. Put the washing machine on a high temperature wash without anything in. This will give it a good clean, and get out any residue from products used. It should work okay after this.
May 10, 2011 | AEG Lavamat 72640 Front Load Washer
My AEG Lavamat 62810 keeps coming up with an error code E60. What is this?
On my AEG Lavamat 62810, when I turn on a wash cycle a motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message. When this happened a few weeks agao running a drain cycle seemed to cure it; now the same thing happens on spin/drain/rinse cycles too. Any ideas?
Aug 06, 2010 | AEG Washing Machines
Jul 14, 2010 | AEG Lavamat 72640 Front Load Washer
Washing Machines Logo
180 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
