Question about Craftsman Garden
Briggs Stratton 625 series 190cc lawn mower: this has been tipped right over and now there seems to be oil in everything and it won't go, what can we do?
This has been tipped right over and now there seems to be oil in everything and it won't go, what can we do?
  • Craftsman Master
  • 2,239 Answers
If the engine has been tipped oil will come through the engine breather and soak the paper filter, remove the filter, remove the spark plug and clean/replace, with the plug out crank the engine a few times to to evacuate any oil in the cylinder, replace the plug and try again ( with the filter still removed ) when it finally starts it will smoke quite heavily so do this out side and on a non grass surface ( oil sprayed from the muffler will kill the grass) it will smoke for some time until all the excess oil has gone, check the oil level in the engine and top up if required.
Posted on Feb 18, 2012
Testimonial: "Thank you very much this has fixed the problem!"
hunter19_46m
  • 7482 Answers
SOURCE: craftsman briggs and stratton 6.50 190cc lawn
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 26, 2010
mowerman1857
  • 389 Answers
SOURCE: white smoke and oil spewing out of troy built
Check your oil level. If it is way over full, smell it to see if it smells like gasoline. If it does, you have a carburetor leaking gas into the engine crankcase. If you recently had the mower over on its side for blade changing or inspection, you have gotten oil up on top of the piston and it should burn off in a few minutes of running. Check your air filter to see if it is soaked with oil, replace it if it is.
Posted on Sep 19, 2009
  • 407 Answers
SOURCE: unable to locate oil drain
Open the spot where you put the oil in.Now turn the mower so that is comes out the hole it went in.It can be messy so use a large bucket.
Posted on May 30, 2011
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
  • 152 Answers
SOURCE: LOOKING FOR A MANUAL FOR A 21" CUT SELF PROPELLED
try putting your serial number and model number here. http://www.troybilt.ca/troybilt/troybilt_manual_search.asp
Posted on Aug 08, 2010
What kind of oil goes in my craftsman 625 model 944.367600
Tecumseh engines usually recommend SAE 30 oil. Briggs engines allow 5W 30 or 10W 30.
Aug 01, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
How to change oil for briggs and stratton lawnmower
There a plug on right side of engine close to bottom. Remove it
to drain old oil.
Nov 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Brand new Briggs & Stratton lawn mower Model 90000 E series won't start.
trry a shot of starting fliud see if it wont start then make sure your getting a spark to
Jun 13, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Oil in cylinder of lawn mower white smoke runs poorly happened after blade was changed
the engine has been tipped the wrong way oil now in chamber and will burn off eventually
Jun 09, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Change oil on 190cc 875 briggs stratton
i just tip mine over and catch it into a can out of the dip stick hole
Mar 27, 2012 | Briggs & Stratton 190cc 875 Series OHV...
There is oil in my air filter and pooled around the top of the yellow part of the mower and now it won't start. Do I have an oil leak somewhere or what?
Perhaps you tipped your mower over to clean underneath it? If you tip it the wrong way, yes, the oil will run up and into the carburetor, then out the carb and into the air filter. An oil leak would not cause this to happen due to gravity. If this was caused by tipping the mower, then let it set upright for a time and let everything run back to where it's suppose to go. It will take a bit to start it, but should work then. I'm hoping this is what your problem is. I hope this helps.
James
May 22, 2011 | Poulan Pro 22inch 625 Series Briggs ...
Just looking for the type of oil I need to use for my poulan pro 625 series
Briggs and stratton sae 30 engine oil or any other reputable brand sae 30 engine oil is fine. Regards Phil
Apr 15, 2011 | Poulan Pro 22inch 625 Series Briggs ...
PP 22inch 625 series 190cc - What Gas/Oil mix should i be using?
I think your mower has a 4 cycle engine. That means the oil goes in the crankcase and the gas goes in the gas tank. No oil mixing needed! If you look at the top of the mower you should see two caps. Each one will be marked with what goes in them.
The oil should be 30 weight non-detergent oil. Available at your local car parts store or Lowes or Home Depot.
Gas is just plain old pump regular.
Oct 09, 2010 | Poulan Pro 22inch 625 Series Briggs ...
Garden Logo
1,279 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
